Still problems with Hakko 936?
  • jfcarbel
    • Oct 2010
    • 28
    In FAQ it states:
    (we are getting some reports about the hakko 936 being difficult to use for capacitor replacement due to not great heating
    I just bought this one based on great reviews I see on the internet. I am wondering if the older manf. dates had issues and this has since been corrected?
    BTW- A good FAQ entry might be what common cap sizes and types one should keep around that are very common in repairs.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Still problems with Hakko 936?
    Hakko 926 & 936 work great for mobo work.
    [Electrically the same. Different plastics.]
    Mann-Made Global Warming.
    - Dr Seuss
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      i think those reports from users who didnt know what they were doing
      • shovenose
        Send Doge Memes
        • Aug 2010
        • 6575
        Oh great. (sarcasm)
        So it is ok for psu work right? Because im going to get one soon. And i want to make sure itll work!
        • yyonline
          • Jul 2009
          • 692
          I have the 937. The 936/937 are identical spec-wise, so I'd expect they would perform similarly. It can sometimes take awhile to heat up some boards with lots of copper planes, but I haven't yet run into anything on a motherboard it won't solder... I have the medium sized iron, and usually use a 2.4mm chisel tip for cap work. The smaller tips don't hold enough heat for multilayer boards. Overall I'd highly recommend the 937 (and by its similarity the 936).
          Edit: for PSU work, which are usually single layer boards, it solders things instantaneously.
          • Deft
            • Sep 2010
            • 55
            I will testify that the Hakko 936 is a-ok for cap replacement. I'm in agreement with willawake about some people not knowing what they are doing.
            • bigbeark
              • Jan 2010
              • 661
              As one of those who experienced some difficulties with the 936, and therefore don't know what I'm doing, let me clarify.
              You need the medium-sized chisel tip, the pointed ones won't cut it.
              It is extremely important to keep the tip really clean. The tip surface is some kind of cast iron (?) and you must get it really clean, some people use brass or aluminum sink scrubber (Kurly Kate) to remove the oxidation. You then "tin" the tip with your solder at full heat. Then you turn down the heat to the temperature that works for you on your particular board. Fequently clean the tip with the wet sponge.
              Try to use solder with lead in it. A lot of the ROHS stuff does not flow well.
              Apply some new solder on top of the old solder, then heat the pins to remove the caps. Applying new solder first really helps the old stuff melt.
              Multi-layer PCBs really suck up the heat, and you need all the power the 936 can muster on these boards.
              The 936 is an excellent unit, now available at lower prices. It is the minimum iron I would consider for motherboard work
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Those difficulties are the same with any kind of iron.
                ""you need all the power the 936 can muster on these boards.""
                I haven't experienced this at all and I have three units.
                There are three iron/handle options for 926/936. - #900[ ],, #907[ ],, #908[ ]
                For mobos you want the middle one which is #907[ ].
                If you have the 907 perhaps your heating element is defective or worn out.
                Replacement elements are available and so are complete handle assemblies.
                Complete assemblies are usually the better deal.
                I took the risk a few months ago and got some new 907 handles from here.
                http://www.vendio.com/stores/cantonm...ir/lid=2873570
                Shipping was free. Ship time 2-3 weeks to USA.
                I was afraid they were going to be cheap knock-offs but when they got here they are genuine Hakko.
                [The included tip is a pointed one and it sux. Get a chisel tip. Chisel tips are better no matter what kind of iron.]
                Also, after I bought those a couple ebay sellers dropped their price on them.
                Might be better deals on ebay now.
                - Dr Seuss
                • severach
                  • Aug 2007
                  • 1055
                  It's not the solder that makes the old solder melt so well. It's the flux that comes with the new solder. I apply flux to all the joints to desolder which allows the work to be done with much less heat. This makes small irons much more effective and the tips stay clean.
                  Before fluxing the solder that was easy to remove was the solder that still had some flux inside. The clean solder was tough. Now it's all easy.
                  sig files are for morons
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Actually it does help.
                    Lead-Free solder has a higher melting point than Leaded solder.
                    A blob of melted solder carries the heat to the joint faster than just the tip and when the solders mix [Leading the Lead-Free] it lowers the over-all melting point of the joint.
                    - Dr Seuss
                    • larrymoencurly
                      • Oct 2004
                      • 960
                      When solder won't melt even when pressed against the tip, the tip may need cleaning. It happened to me a few times with my adjustable 10-60W iron with no temperature regulation.
                      The Goot PX-201 is slightly cheaper than the Hakko 936, can put out 40% more power, and is slightly cheaper.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        "40% more power."
                        Nope. - Spec games in ads...
                        It says 70 watt 'consumption'.
                        That's at the wall socket, not watts of the element.
                        They don't even list the watts for the element.
                        For a 936 Hakko states consumption is 60 watts and 50 watts at the element.
                        70 watts vs 60 watts is not 40%.
                        Goot looks to be largely Hakko knock-offs so I imagine in reality they are the same element. I don't have a problem with knock-offs as long as you know what you are getting and Goot doesn't give up the watts for the element....
                        The other thing is the Goot tips apparently run $5.50-$8.50 each [+ shipping].
                        Hakko tips are around $2.00-$2.50 each [with shipping] if you shop.
                        I wonder if Hakko tips fit Goot??
                        That might be Goot for the Goat to know..
                        - Dr Seuss
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          You've got to be careful with knock off iron companies too.
                          Hakko uses printed ceramic heating elements. They are more efficient (you get more heat from less current) and they have faster thermal recovery than wire wound elements.
                          They are a bit more expensive to manufacture and more complex to produce. Which is why you won't find Chinamart using them.
                          Nothings cheaper to manufacture than a wire wound element which is basically a Nichrome wire wrapped around a piece of ceramic.
                          I remember some Hakko knockoffs I found awhile back they looked just like the real thing accept they had crappy wire wound elements that died prematurely. To make matters worse Hakko elements didn't work with the station because the temperature detecting thermistor which is fused inside the ceramic element had a different resistance.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            That's a very good point.
                            I did look for that and the Goot does 'claim' it is a ceramic element so I didn't mention it.
                            I think I had to look at replacement element ads to find that claim though.
                            - Dr Seuss
                            • severach
                              • Aug 2007
                              • 1055
                              Originally posted by PCBONEZ
                              Actually it does help..
                              Solder in the joint is little to no help. No mixing happens until the solder melts and the part is moved. Work is complete and the solder was late to the party.
                              The flux on the part interacts with the solder on the gun to provide rapid heat transfer. Each part steals a bit of solder so the gun needs to be refilled occasionally. Desoldering a large number of parts requires only a small amount of solder. Solder on the part is wasteful, worthless, and results in poor quality work.
                              • willawake
                                Super Modulator
                                • Nov 2003
                                • 8457
                                • Greece
                                goot is not hakko knockoffs. if you see their products they are very well made and expensive too. if you see very cheap goot products like the solder accessories they are counterfeit.
                                goot PX-201 is not the competitor to Hakko 936. PX-201 is intended as a portable soldering station, this is clear with the heat insulation cap included.
                                goot PX-501 is probably 936 competitor
                                http://gsmserver.com/shop/equipment/...ng_station.php
                                by the way that is european site not us
                                in the end hakko has much better distribution and indeed USA branch. they are both old jap companies.
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  You are the only one I've run into that has difficulty with the technique.
                                  Works great for most everyone else.
                                  - That's why it gets brought up so often.
                                  First sentence true. - Second one not.
                                  Through hole joints are not 'instantaneously apart' as soon as the solder melts. There is a little working things around that has to go on. The mixed solder not only RE-melts faster switching from + to - lead as you rock the cap out, it keeps the solder melted longer when you are bouncing back and forth like that.
                                  Melted solder does rapid heat transfer much better than flux.
                                  Flux does not mix with solder, it floats on top like oil on water.
                                  It's job is to carry oxidation out of the solder and prevent O2 from getting into the solder.
                                  It is deliberately made to NOT mix and heat drives it out so it isn't going to affect anything except the surface layer of the solder.
                                  Adding some leaded solder gets lead to ALL the solder in the joint once it melts.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I don't know 'who's on top' but Goot and Hakko are definitely knock-offs of each other.
                                    Too many of their products [and design details of others] are identical to say otherwise.
                                    The 'idea stealing' probably bounces back and forth like Gigabyte and Asus.
                                    - Dr Seuss
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      Does anyone in the USA actually HAVE a Goot [or other knock-off] with the same tip style as a Hakko 907 iron?
                                      We can swap some measurements and if it looks good I'll mail you a Hakko tip I don't like and the question as to tip interchangeability will be answered.
                                      Because it's one I don't like anyway, you can either keep the tip or mail it to someone else with some make/model where tip interchangeability with Hakko is a question.
                                      - Dr Seuss
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        I've seen Sunko soldering stations in Australia (don't wish to enquire where!) and if I remember correctly, the Sunko text was similar to the Hakko text.
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • redwire
                                          Hakko 950 SMT hot tweezers but no base or stand
                                          by redwire
                                          I got gifted a Hakko 950 SMT hot tweezers but no base or stand.
                                          Any suggestions for building one?
                                          "The 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 soldering stations." Apparently it has two heaters in parallel "24V 50W", one RTD temperature sensor 43-58Ξ© at room temp. 5-pin DIN.
                                          I don't have any of those, have a 470-2 (no RTD in) and a FX-888A.
                                          04-17-2025, 03:01 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • rumpumpel1
                                          Lenovo X13-Yoga Gen 1: hibernation problems
                                          by rumpumpel1
                                          I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
                                          11-03-2024, 12:31 AM
