Still problems with Hakko 936?
Re: Still problems with Hakko 936?
"40% more power."
Nope. - Spec games in ads...
It says 70 watt 'consumption'.
That's at the wall socket, not watts of the element.
They don't even list the watts for the element.
For a 936 Hakko states consumption is 60 watts and 50 watts at the element.
70 watts vs 60 watts is not 40%.
The Goot TP100AS desoldering iron looks a lot like the Hakko 808 but costs about twice as much. Even more expensive is the Denon SC-7000Z, but it can also blow hot air. OTOH here's definitely a knock-off:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=260632822749
Who has Hakko tips for $2.00-$2.50? I don't think I'll be needing any soon because my wife included extra ones when she bought me a 936 for my birthday, and I don't solder much.Last edited by larrymoencurly; 10-25-2010, 08:15 AM.Comment
That's how I know to look for it in ads.
My first attempt at a solder station said 80 watts for the input so I was thinking like 60 at the tip.
Nope, wire wound element, was more like 40 at the tip and the tips were crude/rough [not smooth].
I used it like 3 times. Put it put it back in the box and bought a Hakko.
- That would be the Black RadioShack station that is sold in Blue by Farnell that has grabbed stj's attention.
[It's JUNK stj. - I tried one!]
The handles are bulk [no box, probably to cut shipping cost] but the tips are in factory packaging [sealed bags.].
http://www.vendio.com/stores/cantonm...chString=hakko
[Don't miss the 'next' at the bottom. He has 71 Hakko items listed.]
Sometimes I see his ads on eBay but not all the time.
Unless he's changed his shopping cart the stated price includes shipping. I thought the cart was going to add shipping but it didn't.
I think this is the same guy. Also uses another name.
http://shop.ebay.com/kitmanlaw2008/m....c0.m270.l1313
http://cgi.ebay.com/Hakko-907-936-Ir...item563de222ab
This guy also has Hakko tips cheap from time to time but none currently listed. Haven't bought from this one so can't say if they are legit parts or not.
http://desc.shop.ebay.com/coldfusion...eDesc=1&_rdc=1
.Last edited by PCBONEZ; 10-26-2010, 12:16 AM.Mann-Made Global Warming.
- Dr Seuss
the rough coating on the cheap bits is a protective coating that comes off when you use it.
incidentally, i like to swap irons & bases, that can be done in most cases.
as long as the iron & base both run 24v and use a thermocouple.
my chinese blue base that came with the cheap 48w weller-clone iron is now hooked to my xytronics 60w iron that has a suspicious resemblance to a hakko.Comment
- Dr Seuss
well it's not on xytronics bit's anyway, they are iron-plated copper.
why not try putting a hakko iron on your black chinese base?
and slide the holder-section forward to unlock it so you can throw it in the bin.
the fugly holder-section is the real letdown on the blue unit.
i binned mine straight away & used a seperate stand i had.Comment
What chinese base?
That went in the bin when I got 3 used Hakko bases on eBay for $40.
Only had one complete handle. [And several partials.]
I just recently got around to getting two new handles for the other bases from that cantomade dude so for $70 I now have 3 running Hakkos.
- Dr Seuss
You're not talking about that crap digital variable station at Ratshack that had an iron and used tips they didn't even sell did you?
You couldn't even buy replacement tips for that piece of crap online.
You shouldn't mix and match irons with stations the characteristics of the heating element and the sensing thermistors have to match.
If not your temperature regulation will be in the crapper.
If the iron you're swapping is designed for your station fine but you can't just plug in anything with the right connector.Last edited by Krankshaft; 10-27-2010, 11:01 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
That's the one. [I think.]
Actually it's 'parked' on the 'get around to sell' shelf collecting dust.
You can get tips for them from Sears and Frys.
Uses the same tips as Sear's Craftsman 40 watt.
I agree, you can't go swapping handles around randomly between brands.
Might have different thermistors as well as completely different pin-outs.
- Dr Seuss
pinouts are all different even from the same manufacturer - so are the choice of connector,
but i found there are 2 basc types of iron,
thermocouple, and thermister.
thermister ones you cant play with,
but thermocouples are the same and you can mix them around - i'v done it without problems loads of times - so have friends.
as long as the element isnt one of the newer ones that run over 24v you'l be fine.
one guy i know even built his own iron from a weller TCP (magnastat) by replacing the thermal switch with a thermocouple and using one of those blue bases.
we checked it with a digital thermocouple temp meter and it's running spot-on.
if i was stateside i'd buy that radioshack base off you.
(you can bin the iron - LOL)Last edited by stj; 10-27-2010, 05:56 PM.Comment
on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
i don't understand the reasons of the white stripe at the bottom of the screen below the task... -
by HondamanRecently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
(I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...-
by redwireI got gifted a Hakko 950 SMT hot tweezers but no base or stand.
Any suggestions for building one?
"The 950 is compatible with the Hakko 936, 937, 939, 703, 926, 927 and 928 soldering stations." Apparently it has two heaters in parallel "24V 50W", one RTD temperature sensor 43-58Ω at room temp. 5-pin DIN.
I don't have any of those, have a 470-2 (no RTD in) and a FX-888A. -
by clabrNeed help to solve some problems with this laptop.
After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
Before this had happened I observed some other problems:
When I tried replacing original mecanical HDD with a SSD HDD could not get them... -
First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...09-11-2025, 10:28 AM - Loading...
