Weller WTCP - recommended?
  • fluffy
    • Jul 2010
    Hiya. I'm new to electronics, but I would really love to get into it. I want to buy a soldering station, and after reading this FAQ on the forum, and this advice from the completely awesome Lady Ada, I'm pretty convinced that Weller is the way to go. There is a Weller WTCP for sale cheap in my local newspaper, which is important since I'm a stereotypical starving student. The forum FAQ recommends 60W, Lady Ada recommends 40W, so I kind of figured this 50W one was a happy medium.
    Could anyone recommend if this is a good choice? I want to use it to replace bad capacitors on motherboards and monitors, but also to do some general electronics projects with an arduino microcontroller.
  • MXM
    • 430
    • Unknown
    Re: Weller WTCP - recommended?
    i got that one and if the temp on the room is ok it works fine, my problem comes with the temp of this place which is always low since there are racks in here and a lady in her change. Some members expressed that temp control is not really neccesary good nor needed so, u could also look for other options not involving temp reg.
    But yes, i'd recommend it.
    peace
    We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
      • 31197
      TCP aka MagnaStat should be in a museum.
      fix your profile so we know where you are.
      • smason
        • 1652
        I bought mine in 1978 , still working great! Yes that means I'm almost as old as PlainBill!
        • fluffy
          • Jul 2010
          Sorry for coming back so late to say this (job interview on the other side of the country and all), but I want to thank you all for your input. It looks like it's a good product even if it's old, so I'm buying it.
          I usually don't take orders without a previously agreed upon safe word, but okay just this once.
          • tmcw
            Drying Oven - Preset Temp Fail
            by tmcw
            Here's an unusual one...
            This is a Gallenkamp oven, used in a laboratory space, goes up to 220 Celcius, but is usually maintained at about 115 Celcius. Used for drying glassware, molecular sieves, and so on. Oven is in excess of 20 years old.
            It heats up fine, there is an orange light on the front that indicates that the unit is heating, and when it reaches the preset temp, the orange light goes out. All good so far.
            However, after the preset temp is reached, the temperature continues to rise, power to the heating elements isn't cut off.
            01-21-2021, 03:11 AM
          • foshland
            MSI MAG Z390 Tomahawk BIOS temp, allways at 0ºC and CPU goes protection 800Mhz
            by foshland
            Hi to all, my motherboard (bought second hand as faulty, but now working after cleaning the ram slots) have a strange failure that shows 0 Celsius degrees in BIOS, because of that, the CPU goes to protection mode and gets stuck at 800Mhz.
            Since its a 8-9 Intel generation, I know the CPU temp is the hottest temp of the cores (as i have read in intels documentation) so its not a diode or sensor on the board.
            External temperature (motherboard temp) is working OK, 27ºC more or less
            In windows, all the software I have tested shows correct the Core temps
            12-16-2023, 09:08 PM
          • mosfetratus
            concerning gtx675m vram temp
            by mosfetratus
            Is 98C vram temp are safe? Less demanding games goes 80ish.
            Funny thing, there were old non stock thermal pads very botched, so i replaced them. After, temperatures remained the same, but performance (fps) improved significantly. With both thermal pad application GPU core temp was similar.
            furmark goes about 104C, amperage keeps rising so do temps.
            01-30-2025, 08:41 AM
          • aurgathor
            Recommended replacement cap & voltage
            by aurgathor
            I have an older SFF Dell (GX620) that I want to turn into a router, but it has a few *really bad* looking electrolytic caps (4x 2200uF 6.3V & 1x 1800uF 6.3V) that need to be replaced first.
            Questions:
            1. What are some the recommended caps for these values? (I will probably order from digikey)
            2. Looks to me there is enough space for slightly bigger caps -- would I gain anything with respect to longevity by using 10V caps instead of 6.3V caps? (I guess I probably need to look at the current voltage with a scope since I do not know the nominal voltage of that r...
            08-25-2024, 05:14 PM
          • clearchris
            Old Weller 100/140 Watt Soldering Gun
            by clearchris
            Someone gave me two of these 100/140w weller soldering guns. Yes, I know it runs current right through the tip, but might be nice to really get some heat into some big wires that need to be soldered.
            So, worth a place on the bench, or chuck it?
            10-04-2023, 01:27 PM
