Recommended replacement cap & voltage
  • aurgathor
    • May 2012
    • 16
    I have an older SFF Dell (GX620) that I want to turn into a router, but it has a few *really bad* looking electrolytic caps (4x 2200uF 6.3V & 1x 1800uF 6.3V) that need to be replaced first.
    Questions:
    1. What are some the recommended caps for these values? (I will probably order from digikey)
    2. Looks to me there is enough space for slightly bigger caps -- would I gain anything with respect to longevity by using 10V caps instead of 6.3V caps? (I guess I probably need to look at the current voltage with a scope since I do not know the nominal voltage of that rail)
    • 31267
    you could probably use 1500 or 1800uf 6.3v polymers
