Peak ESR Meter wrong values HELP
  • Shodan486
    • Nov 2009
    • 203
    Hi
    Link
    This one is a big shit... I've bought this quite spectacular ESR meter, really didn't bother about the quality cause I trust english products, but maybe I am mistaken - It just simply shows strange values or doesn't even bother to detect some. Example: I am measuring a IN-CIRCUIT 16v 1000uF cap, and I get ESR 0.41 ohms and C is 6050uF ?!?!? Now what the hell? another story - I get a In Circuit / Leaky message, which means it can't measure the capacitance (still can't see the reason) or the cap is leaking...wel,l I don't think it's true when I KNOW the board is good and runs...I tested this item I am having in my hands for only few hours on quite a number of mobos and it acts the same... I only measured a 100uF cap with quite precise results (106.82uF) but the ESR was only 0.41 ohms...The very problem is the capacitance - Am I missing something or let's face it - It's broken.
    BUT! It quite correctly works on OUT-OF-CIRCUIT state. I have bunch of rubycons 3300uf and 1800uf and those show their nominal state, some of them actually +/- 200uf, which I assume is still OK. Just any experiences would help, tomorrow I'll contact the seller and ask him the same thing here.
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
    • 31028
    Re: Peak ESR Meter wrong values HELP
    you cant meter esr in circuit usually because there are other things in the circuit that mess with the readings.
    specially with motherboards & psu's
    for example, your 1000uf cap - was there 6 of them in the same area?
    they are probably all connected together!
    • seanc
      • Nov 2008
      • 1319
      What STJ says.
      You've accurately described mine, it works fine thank you very much.
      • Shodan486
        • Nov 2009
        • 203
        that's quite a good idea, it seems, that you're right, I can easily measure a row of 4 caps of the same type, BUT - How come I cannost measure just a random 1500uF cap for, let's say a DIMM subsystem? That's just an example, VRMs can be measured, the little tiny ones are almost totally accurate, but unable to measure just a random cap for the AGP, that's another example...Share your knowledge anybody please, me desperate
          • 31028
          because your metering more than the cap, your also metering the chips!!
          and probably some ceramic caps too.
          • Shodan486
            • Nov 2009
            • 203
            So I keep measuring various stuff and something bothers me: Is it possible to always get 0.40 -0.45 ohms on ALL caps I've tested, doesn't matter if they're in or out the mobo, doesn't matter it's Rubycon or Jackcon, I always get numbers ONLY within this gap?...Now what the heck?
            • 370forlife
              Large Marge
              • Aug 2008
              • 3112
              Measure out of circuit.
              • Shodan486
                • Nov 2009
                • 203
                As I said - no difference...a brand new Rubycon out of mobo shows the same value as a stupid Jackcon soldered on a mobo...
                • seanc
                  • Nov 2008
                  • 1319
                  What does the Jackon show off of the mobo? Is it bulging?
                  • Shodan486
                    • Nov 2009
                    • 203
                    Both are in a good shape, can't tell the age, but as for those rubies, I bought them about 3 months ago, but again, I can't possibly know when they were manufactured. The Jackasscon board is a Athlon XP (can't remember because I was even tryin' to use his one to get some other data, it was his board), but it matters not because it is quite impossible to get such very close readings, not to mention numerous identical ones, on many boards from variojus vendors (I got plenty, trust me)...I really don't quite know, but I have discovered a calleague who too is in possession of a ESR meter, so we're gonna compare. Still feel free to add anything...
                      • 31028
                      are they the same voltage & uf?
                      • Shodan486
                        • Nov 2009
                        • 203
                        nope....Rubycon Ultra Low ESR 3300uF 6.3v and Jackcon 3300uF 10v
                        • Toasty
                          • Jul 2007
                          • 4171
                          Try measuring a resistor. Try a 10Ω and a 0.1Ω. Do they read correctly (or close)?
                          Did you do the "Probe Compensation" step? Page 10 of User Manual.
                          veritas odium parit
                          • barry wilkins
                            • Aug 2009
                            • 172
                            Very strange ?
                            Glad I designed and built my own ESR meter .
                            One of the problems is with the applied ac waveform ,it has to be kept low around 100mV to stop the circuit reading anything else in the circuit
                            Barry Wilkins
                            • Toasty
                              • Jul 2007
                              • 4171
                              Shodan486 - Was this ever resolved?
                              veritas odium parit
                              • Shodan486
                                • Nov 2009
                                • 203
                                I know this is a bit old, just browsing history ...but what did you mean by ''chips'' ?
                                • Per Hansson
                                  • Jul 2005
                                  • 5895
                                  • Sweden
                                  He means anything else in the same circuit as the capacitor
                                  When you measure in circuit you measure not only the capacitors, but resistors and ceramic capacitors in the same circuit aswell
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    I know the ads say these meters can check caps 'in circuit' but that only works if there are no resistors, diodes or other caps in parallel.
                                    ESR meter works the same as a regular ohm meter but instead of a DC test signal it uses a small sine or square wave at approx 100kHz.
                                    The voltage is too small 'to turn' on any IC chips and they's where they come off saying it's okay to use in circuit.
                                    As toasty said you can use a resistor to check an ESR meter because resistance is the same be it DC or 100kHz.
                                    Not a bad idea to keep a few values of +/-1% tolerance resistors around to spot check the ESR meter [and your ohm meter too.]
                                    Mann-Made Global Warming.
                                    - Dr Seuss
                                    • Shodan486
                                      • Nov 2009
                                      • 203
                                      Thanks BONEZ, you even answered my repetitive question of damaging something on the board when using the meter inappropriately. And one more annoying question : I happened to obtain another of these PEAK stuff and this one acts weird - it is waiting for me to put the probes on the desired target...so when I put them on the spots, it measures the cap correctly...but sometimes nothing happens, it's waiting for the ''measured component'' while probes on it. This definitely points to a meter malfunction of some sort, I'm not questioning that (probe compensation done numerous times), I'm questioning if this kind of malfunction of the meter can damage the measured PCB motherboard? Because when I saw it first time, I said to myself ''Nah, that can't be, let's try it again'' - can this ''let's try it again'' kill something?
                                      Anyways, what's gonna happen when I try measure the CMOS battery itself? Still socketed on the mobo?
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        It think maybe the no reading is oxidation on probe tips or on the device leads or solder pad.
                                        No, trying again won't hurt anything.
                                        Use a DC volt meter to check the CMOS battery.
                                        CMOS batteries aren't rechargeable except on some really old stuff and occasionally in laptops.
                                        - Dr Seuss
                                        • proxneo
                                          Recapping Sony ICF-SW55 - verifying cap values
                                          by proxneo
                                          Dear reader
                                          I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
                                          At the moment, I have selected replacements based on the following list of values:
                                          3 x 470uF 10VDC
                                          3 x 4.7uF 35VDC
                                          4 x 47uF 50VDC
                                          8 x 22uF 6.3 VDC
                                          1 x 220uF 6.3VDC
                                          5 x 100uF 6.3VDC
                                          Which...
                                          06-21-2023, 12:38 AM
                                        • chth96
                                          by chth96
                                          03-09-2024, 10:03 PM
                                        • marce002
                                          UT210E clamp meter amps measurements wrong
                                          by marce002
                                          Hello all
                                          I have an UT210E clamp meter that went wrong doing amps measurements in continuity DC, it shows an offset of around 4/5A when first set, (lever at DC 10A) at 2A DC shows fixed 0L always......,,,,,, and also does not allow me to (zero button) , and as i said it is even worse in the 2A !! setting which do nothing and shows "0L"... when you can measure DV in 20A after achiving a ZERO with many RESET ZERO times , you can measure with a lot of offset..... eg 1A current is measured at around 650 mamps, . Similarly, a 4A current is shown at around 3A. |O
                                          05-08-2020, 11:52 AM
                                          12-31-2023, 06:04 AM
                                        • rashidjafar
                                          Nvidia GTS 250M Laptop graphics - Inductor and Capacitor values
                                          by rashidjafar
                                          I am looking for capacitor & Inductor values for my TOSHIBA Qosmio X500-110 - mobile graphics - Nvidia GTS 250M Laptop.
                                          Values for :-
                                          PC43 : Capacitor [3x1.5mm]
                                          PL7 : Inductor [2x1mm]
                                          PC39 : Capacitor [1x0.5mm]
                                          Any ideas would be appreciated.
                                          I can get Capacitor values from nearby components but wanted to know the max ratings also I dont have equipment to measure inductors....
                                          Yesterday, 05:10 PM
