UT210E clamp meter amps measurements wrong
  • marce002
    • May 2018
    • 316
    • Argentine
    Hello all
    I have an UT210E clamp meter that went wrong doing amps measurements in continuity DC, it shows an offset of around 4/5A when first set, (lever at DC 10A) at 2A DC shows fixed 0L always......,,,,,, and also does not allow me to (zero button) , and as i said it is even worse in the 2A !! setting which do nothing and shows "0L"... when you can measure DV in 20A after achiving a ZERO with many RESET ZERO times , you can measure with a lot of offset..... eg 1A current is measured at around 650 mamps, . Similarly, a 4A current is shown at around 3A. |O
    What can be wrong?
    video with the issue: https://youtu.be/Wrffkx4lpA0
    What is wrong with this clamp? I have a ut210E nice for small DC measurements. One day stopped working... 2A shows always OL and in 20A shows an offset of 5A!!! Until reset several time I can get 0amps but measure is wrong
    Marcelo J
  • clearchris
    • Dec 2013
    • 687
    Re: UT210E clamp meter amps measurements wrong
    Your red probe doesn't look like it's pushed all the way in. Check the plugs, make sure there's nothing in there, etc. Recently, I had to take apart my meter, clean up the insides and resolder the banana jacks. Your meter doesn't look particulary new either. Otherwise, not sure.
      • 31283
      did you use it for high current like car starter motor??
        Did you open it up and inspect the board?
          • 31283
          it does not use the probes, it has a hall-effect sensor in the clamp
          • redwire
            • Dec 2010
            • 3912
            First check if the iron jaws are magnetized, they probably need degaussing.
            Small chance the Hall sensors offset/cal has gone bad. There are three trimpots on the main board VR+, VR-, VR4 but I'm not sure which one is Hall offset. There are two sensors and you would have to measure voltages to troubleshoot.
            Found this UT210E schematic which shows them.
            OP crossposted here: https://www.eevblog.com/forum/testge...sg3058496/#new
            • marce002
              • May 2018
              • 316
              • Argentine
              Thanks a lot redwire... did not measure nothing strange at all .. only low current apps in rc models most of the time at 2a.... First check if the iron jaws are magnetized, they probably need degaussing... but how can i check iron jaws for magnetizement?
              I would like to never have to touch the inside trimpots..
              Marcelo J
              • redwire
                • Dec 2010
                • 3912
                You can accidentally magnetize the jaws just going close to a magnet, your RC motors could do it if you bumped a motor.
                Take a small steel screw or nut or washer (that is not magnetized at all) and see if it "sticks" to the jaws. That can show if they are magnetized.
                You need an AC field or current (not a magnet) to fix, and to fade out to zero. I use a cassette or bulk eraser or CRT TV demagnetizing coil.
                It could also be done wrapping many turns of wire in the jaws and pass AC current (so the turns*amps= ~100 for say a bad 100A offset).
                Then I run AC current (meter is off) and then slowly open the jaws and pull them away, so the AC field is slowly reduced to zero. A series PTC thermistor could work too.
                I wouldn't touch the trimpots either, until you know the jaws and hall sensors are OK.
                • marce002
                  • May 2018
                  • 316
                  • Argentine
                  thanks redwire, you are the kind of person that make a forum interesting..... i will try to do something of this and will coment soon. my offset is 5A dc , so if any idea of #turns (in a say 2cm diameter core cilinder) and maybe
                  use coaxial tv cable (internal copper with its cover)... the only power supply that i have is a 220v to 12v 5a AC from a car battery charger
                  Marcelo J
                    "I have an UT210E clamp meter that went wrong doing amps measurements in continuity DC"
                    I guess I read it wrong, I thought OP has the meter in Continuity mode and use the probes to test the current.
                    • Garbologist
                      • Nov 2022
                      marce002 did you ever figure this out? Mine is doing the exact same thing and after probing it with the aid of the circuit diagram linked in the post above, I think maybe the op-amp chip may be bad. It’s a 4 op-amp chip which appears to be a Chinese copy of the OPA4330, and is configured as an instrument amp for the current probe.
                        • Jul 2011
                        • 6070
                        I also had a dc clamp meter and it would not read correctly after a couple of years of use so just never got a replacement for it but if I were to get a replacement one what brand is is a good one that would not require an arm and a leg to buy i
                        • Garbologist
                          • Nov 2022
                          There is a write up on repairing this issue over on the EEVblog forum: https://www.eevblog.com/forum/repair...re-and-repair/
                          • Kudeta
                            A2289 Board 820-01987-A Dead?
                            by Kudeta
                            Hello everyone, I think I am the worst repair guy here is my story...
                            I am trying to repair my daughter's board bought 3 months ago she dropped the macbook pro Board 820-01987 Resulting in no Backlight no Image.
                            I had fan spin and normal voltage and Amps at this point with the board out.
                            I tried to take some measurement on the display cable.
                            Unfortunately I felt a quick hot sensation when I did this... I know I know...
                            This is where I am at:
                            When I plug in the A2289 I Get 20.4V and takes 0.13A jumping...
                            10-19-2020, 08:14 AM
                          • Stephen
                            A2991 Logic Board issue, 20volts 0 amps help!
                            by Stephen
                            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
                            09-10-2025, 03:16 PM
                          • Stephen
                            A2991 logic board issue, 20volts 0 amps help!
                            by Stephen
                            09-10-2025, 03:15 PM
                          • bimole
                            Weird behavior on 3.3V rail of a CORSAIR CX600
                            by bimole
                            A colleague gave me an apparently ill CORSAIR CX600.
                            He told me that he heard a banging noise, and smelt the magic smoke.
                            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                            It's another story on the 3.3V rail...
                            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                            02-13-2025, 04:49 AM
                          • marce002
                            UT210e clamp revival eeprom
                            by marce002
                            Hi
                            I was trying to flash the chip in the board with my ch341a programmer, wiring as documented by https://www.youtube.com/watch?v=fX-Fhq9R4uY
                            it did not read anything so desoldered the chip from the clamp and put into my programmer board and also not reading real data, it only brings emptyness...
                            maybe i ruined the memory? turning the clamwith no chip shows Error and a beep wich is correct.
                            put chip back to the clamp, and shows some random numbers like calibrating and offers a 0.000 DC display and nothing else can be selected...
                            10-05-2023, 01:28 PM
