Finally built the Bob Parker "Blue" ESR Meter
  • volkswagenvan
    Volks
    • Mar 2009
    • 35
    Re: Finally built the Bob Parker "Blue" ESR Meter
    Originally posted by stj
    doesnt esr on batteries vary with charge?
    i know on 18650's i salvage that they look a lot better after a full cycle
    I never tried testing 18650's.
    Just lead acid, nickel metal hydride and nickel cadmium's.
    Can't recall really checking for charged verses dead.
    Lots of charged verses charged to compare their health is all.
    • volkswagenvan
      Volks
      • Mar 2009
      • 35
      Those minor upgrades add up to ease of use!
      The longer leads would keep me from dragging my Blue around so much!
      Nice job on the holder!
      • volkswagenvan
        Volks
        • Mar 2009
        • 35
        bcstedt,..
        About your FA error code.
        Lots of reading gives me this from Bob Parker. (Don't try out the self-diagnostic function unless you really need to. And don't use a 9V battery with the diagnostic function because it will report an 'F2' fault which probably doesn't exist. It must be powered by 5.5v to work properly.)
        As far as errors and faults check here. http://www.bobparker.net.au/esr_meter/esrprob.htm
        Lots of good Info on errors and problems with the Blue ESR Meter from Bob himself!
        • jayjr1105
          • 281
          Originally posted by volkswagenvan
          I kinda made one from the old Bob Parker meter.
          Thanks for the printout. Doesn't look as "professional" as the original but 10 times more useful.
          Ryzen 3600x
          16GB Patriot 3600MHz
          MSI B450 Gaming Plus
          MSI Air Boost Vega 56
          Acer 32" 1440P Freesync
          Rosewill Capstone 750W
          Hakko FX-888D Station
          FX-8802 Iron
          MG Chem .8mm 63/37 RA 2.2%
          • volkswagenvan
            Volks
            • Mar 2009
            • 35
            Glad to help... looks more professional in color. lol
            I know i love mine now!
            • jayjr1105
              • 281
              I should have printed it out at work on our $3000 copier instead of my monochrome $80 home laser printer. It looks good enough and I didn't use sticker paper either. I was just really careful with packing tape and used a razor to trim the excess.
              Ryzen 3600x
              FX-8802 Iron
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Interesting the "old" table seems to include some compensation to limited testing frequency, but the "new" graphs do not...
                Now to attach a table to the AVR transistortester ... heh...
                • volkswagenvan
                  Volks
                  • Mar 2009
                  • 35
                  Looks Good Enough to do the job jayjr !
                  Everybody can use it if you want. Its not to fancy but it works!
                  I remember typing the omega / ohm symbol was a pain for me!
                  The colors just looked kinda cool. I saw similar on the net and they got added at the end.
                  I have two printers that i use. One HP Laser Jet P1006 for cheap black and white and
                  a HP Office Jet Pro 8210 for color printing.
                  • jayjr1105
                    • 281
                    Originally posted by redwire
                    What ESR chart did you go with?
                    I've heard measuring battery ESR can also be done if you add a series DC blocking capacitor. Good for many testing different batteries, LiIon and car batteries with the Blue ESR meter.
                    This guy seems to think the meter can check batteries charged or not.
                    https://youtu.be/toq3msUeQ40?t=207
                    Ryzen 3600x
                    FX-8802 Iron
                    • volkswagenvan
                      Volks
                      • Mar 2009
                      • 35
                      AnaTek worked with Bob Parker to get the Blue ESR Meter assembled for sale.
                      I would trust anything he says because he would know!
                      As for ESR getting better with charge cycles,... It could happen.
                      I have seen old caps that have just sat around in equipment unused get better
                      after some time back in service. Reform I guess.
                      You got me playing with battery's at my desk now!
                      New AA alkaline 1.5 volt reads .00 on the Blue while Old almost dead ones removed from my belt flashlight read 1.0 ohms. Same brand from the same package!
                      Interesting!
                      Another interesting thing is if you put one sharp tip test lead on the bottom of a cheap
                      AA battery you can touch the positive and negative through the plastic at the same time producing a red glow hot enough to make a small blister on your finger!
                      Never done that before! Ok,...I`m done testing stuff now. LOL
                      • redwire
                        • 3910
                        Some (good) battery blue ESR measurements:
                        AAA Panasonic alkaline, 0.11 ohms, 0.13 ohms
                        AAA Ikea alkaline, 0.07 ohms
                        AAA chinese alkaline [weak almost dead] 0.2 ohms
                        AAA Energizer lithium, 0.22ohms, 0.24 ohms
                        AAA Ikea Ladda NiMH 900mAh charged, 0.06 ohms. Discharged, 0.06 ohms
                        AAA Eneloop NiMH 750mAh charged, 0.17, 0.23
                        9V Energizer Industrial alkaline, 1.2 ohms
                        9V Duracell alkaline, 5.0 ohms I just want to take a leak?
                        12V 7.2Ah gel-cell good 3yrs on standby, 0.03 ohms
                        AA Ikea Ladda NiMH 2,450mAh new, 0.03 ohms
                        AA Eneloop Pro NiMH 2,450mAh used, 0.06 ohms
                        AA Ikea alkaline, 0.05 ohms
                        AA Duracell alkaline weak, 0.77 ohms I just want to take a leak
                        AA Duracell Procell alkaline weak, 0.70 ohms I just want to take a leak
                        AA Duracell Procell alkaline weak, 0.13 ohms
                        I think the main advantage to using ESR is it doesn't depend on state-of-charge, so dead or alive it checks the plate's active surface area and cell interconnects etc. which go downhill with corrosion.
                        But I really need to build a new blue ESR meter with an extra digit of resolution.
                        • volkswagenvan
                          Volks
                          • Mar 2009
                          • 35
                          Very interesting! No burnt fingers?
                          I found more reading material, The new blue ring tester is interesting as well!
                          Bob Parker's Electronic Stuff http://bobparker.net.au/index.html
                          Anatek Instruments https://muut.com/anatek-forum/#!/ana...ct-discussions
                          • Bob Parker
                            Technician
                            • Feb 2007
                            • 182
                            bcstedt,..
                            I know that this is one year late. Before using the diagnostic function in the Blue ESR meter, a few things have to be done first (which are in the instructions): "Before doing the self-test, it's very important to first set VR1 to the center of its adjustment range, short out R30, 100R and make sure that the meter's supply voltage is in the range of 6.2 – 6.8V. Do not use a 9V battery for this test because it will cause a false F2 warning!" If you don't short out R30, you will get a false "FA" fault code. I hope this clarifies things a bit.
                            It is a good shrubbery. I like the laurels particularly...
                            • volkswagenvan
                              Volks
                              • Mar 2009
                              • 35
                              Thank`s for the info Bob!
                              It's never too late to learn something. Example = "Kombi vans" Lol
                              Thank`s for the clarification!
                              • Bob Parker
                                Technician
                                • Feb 2007
                                • 182
                                In case anyone's wondering why it's necessary to power the Blue meter from an unusual voltage and short out R30 before invoking the diagnostic function, it's because the microcontroller's firmware was designed for the Dick Smith Mk2 ESR meter which has a different voltage regulator and there's no R30. I knew that if I changed the firmware to suit the Blue meter, there would be endless mix-ups between the different microcontroller versions.
                                • volkswagenvan
                                  Volks
                                  • Mar 2009
                                  • 35
                                  Interesting and Good call on keeping the same firmware.
                                  I hope to never have to use the diagnostic function but my biggest fear is doing
                                  something stupid someday and making my Blue meter a Blue brick!
                                  Hopefully that will never happen. I can replace and repair everything but the Zilog!
                                  Your Blue meter is so popular that I would find a replacement with no problem if needed.
                                  You made yourself quite a good piece of test equipment! Thank`s for sharing your Meter with the world!
                                  • Bob Parker
                                    Technician
                                    • Feb 2007
                                    • 182
                                    So far I haven't heard of even one microcontroller failure due to connecting the Blue meter to charged high voltage capacitors. In fact the late John Bachman at Anatek who I collaborated with actually tried connecting one of the meters to bigger and more highly charged capacitors until it started blowing tracks off the PCB, but the microcontroller survived.
                                    I only designed the ESR meter to help with my own repairs. I submitted it to a local magazine as a construction project, and the editor gave me a look like "Why would anyone want to measure a capacitor attribute which no one has ever heard of?". But kit sales just exploded and have stayed high for 1/4 of a century.
                                    I'm sure that Andy at Alltronics who makes the kits now would help out if anyone needed a replacement microcontroller IC. He's that kinda guy.
                                      • 31020
                                      how much current does the blue meter use?
                                      just wondering because there is a cheap(free) source of very compact 500ma lion pouch cells
                                      • jayjr1105
                                        • 281
                                        I can check in a little bit for you. I currently use a 9v lithium which is just two lithium cells making it about 8.4v fully charged. Seems to work fine.
                                        Ryzen 3600x
                                        FX-8802 Iron
                                        • Bob Parker
                                          Technician
                                          • Feb 2007
                                          • 182
                                          The current consumption jumps all over the place depending on how many segments of the displays are on. It's about 15mA at idle but can get up to maybe 40mA.
                                          According to Energizer's data, the 522 alkaline 9V battery has a capacity of around 600mAH at that level of discharge, so a 500mAH Li-Ion battery could be expected to last a similar amount of time.
                                          Hope this helps...
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                            Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
