ESR meter for a novice
This topic is closed.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    #41
    Re: ESR meter for a novice
    I'm sorry but i have to back up devid21 on this one - i have designed a PCB for the same meter, built it, and it works just fine. It IS accurate enough on a larger meter movement such as that found in older multimeters, besides, if you feel you need more accuracy, you can always hook a DMM set on the 200mV scale in parallel with the analog meter. Then all you need is to make a nifty table to decode the DMM's voltage reading into resistance values.
    I can notice bad caps even when operating it into a VU meter, because when the cap is in good condition, measuring it is accompanied by a rewarding click sound as the meter hits the peg due to overshoot. If the cap is anything less than perfect, the meter won't click even if it does go full scale.
    A working TV? How boring!
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Don't get your tools from Playschool.
      The upper and lower ends of the movement are inaccurate and being more precise doesn't make it more accurate.
      Mann-Made Global Warming.
      - Dr Seuss
      • devid21
        Banned
        • Sep 2010
        • 82
        #43
        Sorry,Bob,the scheme from a russian site
        On other sites have long been ampty.
        If you have time,make this ESR meter
        It measure on the sine wave.
        The lower limit of measurement:20-30 milliohms
        Com you compare with your ESR meter.
        Good luck
        http://www.remserv.ru/cgi/magazine/i...1/measure/1855
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Originally posted by devid21
          Rus Mike wrote:
          The criteria is about-more than 1000uF-ESR<0,1ohm,100-1000uF-0,2-0,5ohm is normal.
          In that case Rus Mike doesn't know his ass from a hole in the ground.
          - Dr Seuss
          • smason
            • 1652
            Good luck
            Huh?
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Originally posted by smason
              Huh?
              Ignore that one. He's just a twit that doesn't know what low ESR is, yet, he insists on handing out advice about how to measure it.
              - Dr Seuss
              • devid21
                Banned
                • Sep 2010
                • 82
                #47
                Before you send a message,check your ass.
                • Bob Parker
                  Technician
                  • Feb 2007
                  • 182
                  OK, I've done that. Now what?
                  It is a good shrubbery. I like the laurels particularly...
                  • smason
                    • 1652
                    ROFL!! I just sprayed coffee on my keyboard.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Don't need to.
                      I know where mine is.
                      - Dr Seuss
                      • devid21
                        Banned
                        • Sep 2010
                        • 82
                        #51
                        And why do you ask to send its meter?
                        Can you also imagine ordered?
                        Do i need this digital toys?
                        A simple analog ESR meter does too.
                        • devid21
                          Banned
                          • Sep 2010
                          • 82
                          #52
                          You can check the capacitors without measuring ESR.
                          http://members.iinet.net.au/~geoffg/Measuring_ESR.html
                          • Bob Parker
                            Technician
                            • Feb 2007
                            • 182
                            I'm delighted that someone here understood what I meant. I hope your keyboard's OK.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              Further evidence you are a clueless wonder.
                              Yes, you can check caps without measuring ESR,,
                              - however, you won't know if the caps are any good.
                              The link you provided shows how to measure ESR with an o'scope.
                              He -IS- measuring ESR.
                              - But with equipment MORE expensive than an ESR meter.
                              The whole point of having an ESR meter is to avoid needing a scope to check ESR. - DUH!
                              - Dr Seuss
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Definitively understood here too Bob.
                                Didn't spray coffee, but did call the wife in to share it..
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  When you get better at English I might understand your imagined points/implications.
                                  There are currently NO commercially available or DIY plans/kits for an analog ESR meter that is capable of measuring ESR on low ESR caps.
                                  Th3_uN1Qu3's project in the other thread is interesting but what he is proving is that it costs more $$ in parts and time to build an analog ESR meter for low ESR than it would cost to just to buy a digital meter kit.
                                  - He's already spent much more $$ in hours lost than buying a kit would have cost.
                                  At this point he still doesn't have a working prototype and when he does it STILL won't be as accurate as a digital meter for low ESR.
                                  [Young people with no real worldly responsibilities are like that. I know, I was one of them once.]
                                  - Dr Seuss
                                  • devid21
                                    Banned
                                    • Sep 2010
                                    • 82
                                    #57
                                    Designers for children(KIT) had never used
                                    All ESR meters always do myself.
                                    And who are you do this to give me advice?
                                    • PCBONEZ
                                      Grumpy Old Fart
                                      • Aug 2005
                                      • 10661
                                      You have repeatedly demonstrated that you have no idea what Low ESR even is.
                                      Your ESR meters are for General Purpose caps and you repeatedly recommend such meters for Low ESR measurements.
                                      - That doesn't work.
                                      If you are going to participate on a site that's primary 'theme' is Low ESR applications then you should at least learn what Low ESR it is and refrain from handing out advice until you understand it.
                                      - Dr Seuss
                                      • devid21
                                        Banned
                                        • Sep 2010
                                        • 82
                                        #59
                                        When do at least one ESR meter with his hands,then continue the discussion.
                                        • PCBONEZ
                                          Grumpy Old Fart
                                          • Aug 2005
                                          • 10661
                                          I have.
                                          - Dr Seuss
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • eccerr0r
                                            lowest current galvanometer/analog meter (passively powered!)
                                            by eccerr0r
                                            Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                                            On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                                            04-16-2025, 12:41 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
