ESR meter for a novice
This topic is closed.
Re: ESR meter for a novice
When you amplify something by 10 you also amplify THE ERROR by 10.
.Mann-Made Global Warming.
- Dr Seuss
Devid enough with the link laden blocks of text nonsense this is your only warning.Last edited by Krankshaft; 12-05-2010, 06:38 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by eccerr0rMost analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and... -
by jorpecHi
Thnaks -
by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer... -
by sam_sam_samI have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing... - Loading...
