How to clean oxidation from BGA pads?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    I have about a dozen motherboards here that need new LGA 1151 sockets
    I am able to remove the old socket but I have a problem with some sort of oxidisation that is getting onto some of the BGA pads and I am struggling to clean it off. Even dragging a solder ball around with my T12 doesn't shift it. See attached video
    I assume that I need to get all these pads clean before attempting to solder the replacement socket? So how do I get them clean and shiny?
    Another problem - So far I have not been able to fit a new socket successfully.
    After soldering and checking for continuity from the LGA pins to 0V or Vcore it is obvious that only some pins are soldering. if I remove the socket again it is obvious that many of the balls did not melt because a lot of the PCB pads are still 'flat' with no solder on them. And this is when I get this oxidation problem even worse.
    After a bit of experimentation I created a profile that will desolder LGA sockets from gaming motherboards, as the one I use for standard motherboards wouldn't do it.
    But that profile will not attach the new socket properly. I then created a profile that is 10C hotter on the final ramp up and it still isn't soldering the new sockets. IIRC, with this profile, the probe near to the LGA on the top of the PCB is getting up to around 260C-265C on the final ramp up.
    I will have to try a hotter profile for sure, it seems my probe isn't reading the actual temperature at the LGA to PCB junction. But how much more heat?
    Also should I apply flux to just the PCB or to the PCB and the LGA socket? I'm using NC-559-ASM from Aliexpress. Can too much flux be as problematic as not enough? What is the correct amount?
    video https://youtu.be/uMiCsbOJ-ZU
    The cleaning liquid is Iso Propyl
    Pics
    Profile 'LGA Gamer' used to remove
    Profile 'LGA Gamer Mount' used to solder.
    Questions Questions lol
    Rich
    Follow me on YouTube
    Learn Electronics Repair
  • diif
    • Feb 2014
    • 6978
    • England
    Re: How to clean oxidation from BGA pads?
    Are you using flux when you remove the old socket ?
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      Yes mate - I have some Topnik TK83 liquid flux that I try my best to run under the old socket by holding the PCB vertically and rubbung the apllicator brush under the edges
        • 31265
        if you put the flux on the socket contacts and heat it with air it should run down onto the board,
        soldering profiles for the sockets are on intel's site but you may have to search a bit.
        • diif
          • Feb 2014
          • 6978
          • England
          Maybe try some Topnik AC81 it's a more active flux and use a pipette or syringe with needle to ensure the area is flooded.
          You can scratch the surface with the tip of an iron if your careful.
          • dicky96
            Sun Seeker
            • Mar 2017
            • 1825
            • Spain
            That AC81 flux seems really hard to get, I can't find any sellers on ebay that post here, or on Aliexpress. The only way I'm likely to get some is to order to the UK and get a friend or family to bring it here when they visit - which is gonna be no time soon!!
            So to clean this PCB ready to fit a new socket I am going to have to scrape that residue off? Would very fine emery cloth or something similar do the job?
            I think the problem with soldering the new socket is that it isn't in full contact with the PCB so the balls don't conduct the heat from the PCB and melt like they do when using the same profile to remove the old socket.
            Rich
            • R_J
              • 9610
              I've seen them use flux and solder wick under the iron tip to clean the pads, but you need to be carefull not to damage them.
                • 31265
                that flux is probably sold at TME
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  @R J
                  OK I will give that a go with various fluxes I have
                  @stj
                  I will give them a try - not that the postal service seems to be actually functioning here at the moment - I have had one delivery on Tuesday this week, the only one in 3 weeks. On the plus side diesel is 90 cents (0.9 euro) a litre here now. Shame that Correos (post office) is not open for me to go collect my mail
                  • clearchris
                    • Dec 2013
                    • 687
                    For cleaning off residues and oxidation, I really haven't found anything better than brake cleaner and a q-tip. Just make sure you clean it all off before soldering, the fumes when burned are highly toxic. And be careful when you spray it, it comes out very, very fast. If you splash it, and it ends up in your eyes, you will go blind for about 5 minutes or so. At least my vision came back, um, I mean, my friend was fine after having that happen to him.
                    • Deusjevoo
                      • Sep 2010
                      • 21
                      To clean pads use a GEL FLUX, not liquid. Liquid evaporates and looses activation too fast.
                      To get rid of that oxidation higher activation (gel) flux types can give better results but they have to be cleaned off thoroughly as they're more acidic.
                      Reason for the the dark pads can also be a bad finishing, hard to fix sometimes.
                      But using gel flux and touching it with some solder, even rubbing it slightly but don't sratch, can help. Or soak a solder wick with solder, add gel flux to the pcb and go over it with soaked solder wick eventually cleaning again.
                      Gel fluxes:
                      Good no clean ones which often help out switching between them:
                      Amtech NC-559-TV, NC-559-V2-TF, Amtech Syntec, Amtech VS-213A-TF
                      Very agressive one for oxidized pads: Amtech NWS-4400-HA-LF must be cleaned !!!
                      Other brands will have same types of flux probably.
                      Even many so called "fake" Chinese fluxes can do a good job.
                      I often use Kingbo for cleaning, cheap and does a good job, even reballing not a problem althoug I do use Amtech for it mostly, NC-559 or VS-213A, most often Syntech now.
                      Kingfull Kingbo seems ok.
                      • dicky96
                        Sun Seeker
                        • Mar 2017
                        • 1825
                        • Spain
                        OK here is another board. This socket came off cleanly on the first attempt using my LGA GAMER profile that I created for the previous board, Gigabyte Aorus Z270-X. This board is an Asus Strix B250F Gaming.
                        I added some videos, sorry they are not very exciting. Also sorry there is no sound on these videos, I'm normally quite chatty but I need to get a microphone and with this lock down getting anything but food is a pain the the ass. However if you could watch through them hopefully you can tell me if I am doing this right or wrong.
                        1. Examine PCB after LGA1151 socket removal
                        looked like I may have lifted one pad but hoping it was just oxidation on that pad
                        https://youtu.be/TeVRJc3HWaM
                        2. Examine PCB after using T12 with BC3 tip to drag a solder ball around the pads. I use piece of desolder braid with NC-559 flux to have a closer look at that iffy looking pad
                        https://youtu.be/4VxMLnpMtmE
                        3. Examine PCB after using solder braid with NC-559 gel flux to clean all the residual solder. Then cleaned the PCB with iso propyl. That iffy looking pad looking better now but somehow seems slightly recessed compared with all the other pads
                        https://youtu.be/DC7dCK1UZvA
                        That iffy pad looks OK now but I would like to check to make sure it has continuity to wherever it should connect. Hopefully the LGA1151 pinout will help me but of someone has the Strix B250F boardview that would be great.
                        • Spider1211
                          • Oct 2019
                          • 532
                          • Mauritius
                          Use your 559 instead of the liquid flux. Paste is a bit more tricky to run under chips/sockets that liquid, but does a better job since it does not run as much. Liquid is better suited for reflow rather than desoldering.
                          Yes, definitely. Shiny depends on the solder you are using (lead/unleaded).
                          1. Apply generous amount of flux & flush old solder with new solder (preferable same as the new chip you plan on soldering back).
                          2. Wick solder from the board.
                          3. Clean using IPA and feel for sharp peaks using a swap. (You could also use light at an angle to see uneven surfaces)
                          For desoldering/cleaning you can use to you heart content, but for soldering apply a thin film using a soft brush. Too much flux will cause the part so shift when its bubbles.
                          To clean oxidation on pads you could very lightly scrap it off using a rounded edge blade (if there isn't too many) but risk pulling pads. What works great for me is this soldering grease(see attached picture). Not sure if they still sell those, but all you need to do is apply it to the affected area and using a pointed soldering tip (I use a T12-KU) with solder on it and apply light downward pressure (no scraping) and voila! as good as new.
                          Although you need to clean it after use, I did not notice and corrosion due to the flux being left on the board (scrap board)
                          • dicky96
                            Sun Seeker
                            • Mar 2017
                            • 1825
                            • Spain
                            This is what I have available at the moment
                            Post is really slooooow to order anything else right now
                            • Deusjevoo
                              • Sep 2010
                              • 21
                              @spider1211 Think that Felder Lotferr is for plumbing or metal soldering, not for electronics. Wouldn't use it for that.
                              • Spider1211
                                • Oct 2019
                                • 532
                                • Mauritius
                                @Deujevoo I don't use it for soldering, only for removing oxidation. I was initially using it for tinning my soldering iron tips (back in the days when I had crappy soldering iron), but found it works exceptionally well for removing oxidation on BGA. I always clean the area I used it on before soldering any chip even though I never had issue with leaving it on as mentioned.
                                @dicky96 Slow is better than nothing. We are at a complete stop here :/ , no postal service working due to curfew.
                                Try them on oxidised pads on scrap boards and see which works best.
                                • clearchris
                                  • Dec 2013
                                  • 687
                                  I can't imagine. I'm getting so many things done during my sequester, but it's mostly because of the mail.
                                  • dicky96
                                    Sun Seeker
                                    • Mar 2017
                                    • 1825
                                    • Spain
                                    It is true, I am getting around to doing a lot of things in the workshop myself and improving my skills and knowledge .
                                    But the reality here is everywhere is closed down for the duration, including all shops, bars, cafe's, restaurants, takeaways (delivery or collection) hotels, indoor and outdoor public spaces, parks beaches, hiking trials etc. Week 5 of lockdown starts tomorrow - supermarkets open for food sales only, nothing else. I got stopped at three police roadblocks last week but have the documents to work as self employed (internet, TV, satellite). But I can't even get my hair cut or my van fixed lol and now it has broke down. And post? No chance unless it is sent priority next day UPS or Fedex. Then you will recieve it in 10-14 days. I had three packages arrive in over a month, the rest I have no idea where they are.
                                    • Spider1211
                                      • Oct 2019
                                      • 532
                                      • Mauritius
                                      Even priority mail is out here. I have a DHL package that came in on the 19th of March and was scheduled to be delivered the following day. Surprise surprise, lockdown start that very next day -_-. Lockdown was supposed to be lifted on 15th of April but as of 2 days back, it has been extended till 3rd of May.
                                      Adding insult to injury, I am running low on flux and therefore cannot do much of anything (especially smd related).
                                      I also wanted to start prototyping a low cost ventilator design but there is no way I can procure parts.
                                      • dicky96
                                        Sun Seeker
                                        • Mar 2017
                                        • 1825
                                        • Spain
                                        @Spider
                                        Don't they have a lot of trees where you are?
                                        https://hackaday.com/2012/09/19/diy-...from-the-tree/
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • petemanuk
                                          BGA solder balls not connecting - help pls
                                          by petemanuk
                                          So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                          I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                          I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                          11-16-2022, 05:21 AM
                                          Multifix 425-01 and 450-01 Rework Flux Datasheet
                                          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                          - No Clean Formulations
                                          - Low residue
                                          - Range of activity to deal with different component solderability
                                          - Halide free
                                          - Suitable for dispensing
                                          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                          Both products are supplied in syringes or cartridges for application by dispensing....
                                          10-07-2024, 06:02 AM
                                        • dbuergi
                                          Restore solder pads for SMC on MacBook A1466
                                          by dbuergi
                                          i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
                                          Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
                                          As written i want to improve skills so it doesnt matter if it takes longer.
                                          12-29-2024, 10:24 AM
                                        • chth96
                                          Is it good to use chemistronic flux off es835b for flux remover?
                                          by chth96
                                          I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                                          Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                                          11-17-2023, 07:25 AM
