Is Lazy Recapping a Problem?
  • bgavin
    • Jan 2007
    • 1355
    I recapped a KG7 board that needed (1) cap done (cuz I'm out of stock).
    It has an Alpha PAL8045 on the processor, so I got lazy and left the board populated.
    It no work.
    Just curious, did I shoot myself in the foot by recapping with the board populated?
  • Harvey
    • Apr 2007
    • 264
    Re: Is Lazy Recapping a Problem?
    Populated? What do you mean by that? You left the RAM & CPU etc. in, or you just changed the one cap?
    • Scenic
      o.O
      • Sep 2007
      • 2642
      that Alpha PAL8045 heatsink is screwed onto the board (instead of using clips).. so i guess he was too lazy to undo all that stuff and left the heatsink + CPU on...
      • ss627
        Super Member
        • Mar 2008
        • 52
        Wouldnt be surprised if the flexing broke a solder joint somewhere.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Try clearing CMOS by removing battery
          • stevo1210
            • Oct 2006
            • 4156
            I've recapped boards whilst leaving the CPU and RAM attached and it still worked fine, and I've done this multiple times as well.
            • bgavin
              • Jan 2007
              • 1355
              By populated, I mean leaving the CPU and memory in their sockets.
              The single cap changed out was EC15, 3300/6.3 single cap close to the ATX connector, East of the CPU, and North of the NB.
              I suspect this one might be a VRM for the memory sockets.
              It is not part of the VRM cluster for the processor.
              When I get time to diagnose it, I'll do the CMOS thing, strip the memory, etc. Other work is far more pressing, so this one goes on the back burner.
              I was just curious if anybody here has gotten burned by recapping with the processor and memory in their sockets.
              • Gianni
                • Jul 2008
                • 681
                • Italy
                bgavin I have recapped few boards till now and I left most of them populated without any problem.
                Only on 2 I have removed the CPU HS because was easier to replace some caps.
                Ciao
                Gianni
                "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                H. J. Brown
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  i often leave the cpu in to protect the pins.
                  sometimes the hsf too.
                  i would double check your work if it worked before.
                  as for emergency stuff i once fixed a mission critical industrial motherboard by shutting it down,ripping the only vrm cap i could get to off the board,and soldering 1 fujitsu 820@2.5 poly in its place.this machine was being used to work on a gov project so critical that if someone handled the part they had to let it settle to the specified temp before machining further.
                  the board was crashing during the operation and they could not take the downtime for me to do it right.it ran fine and everyone forgot it for several months till a scheduled downtime.the poly was not damaged.
                  this was a fujitsu-siemens custom board and it was buried well.
                  • yanz
                    • Nov 2004
                    • 910
                    80% of my work were done by leaving the CPU in their socket. though i failed last week, one bx motherboard can't be installed again with windows after recapping. before, it was fine. sad.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      check your soldering and clear cmos.
                      boards that worked before a recap but not after are usually something stupid.
                      • bgavin
                        • Jan 2007
                        • 1355
                        I'm out of stock on 3300/6.3 caps, or I would just pull it and use another cap.
                        It took me about 10 days to get my refund from Wai Fong, with their system problems and all.
                        I'll retry ordering those MCZ again through Wai Fong, but this time I will skip FF and use IE6.
                        CMOS clear was no help.
                        I get long continuous beeps when it powers up.
                        Swapped out the CPU, same error.
                        Same noise, with/without memory sticks installed.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          i always remove everything except for non-removable chipset heatsinks. less things to worry about damaging. dont be lazy. it will only lead to more work in the end.
                          sigpic
                          (Insert witty quote here)
                          • theone111
                            by theone111
                            3. Problem: TV shuts down
                            07-22-2024, 10:36 AM
                          • Zeonalbasta
                            Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                            by Zeonalbasta
                            i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                            The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                            09-13-2024, 01:17 PM
                          • Gibon378
                            Problem with stopping audio and video for no reason
                            by Gibon378
                            PC Specs:
                            • CPU: Ryzen 5 1600
                            • GPU: GTX 1080 Palit JetStream
                            • MOBO: ASRock ab350 PRO4
                            • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                            • PSU: XFX 650W (don't remember what model)
                            • OS SSD: ADATA SP920
                            • OS: Windows 10 21H2
                            Problem description:
                            Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                            11-19-2022, 09:41 AM
                          • perzyk23
                            Lenovo T580 - LCD Panel problem - error 0288
                            by perzyk23
                            Good morning,
                            I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                            10-25-2024, 12:42 AM
                          • lazaro.089
                            Asus Zephyrus M16 / GU603ZW problem
                            by lazaro.089
                            Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                            CPU: Core i9-12900H
                            Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                            Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                            The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                            08-26-2025, 06:33 PM
