Test equipment and 1PPS inputs
  • japlytic
    • Oct 2005
    • 2086
    You've most likely seen test equipment with an external reference clock input, but I think a 1PPS input (or support for it) should also be included considering it is easier to route a 1PPS signal over long distances than a 10 MHz signal.
    When routing the 1PPS signal and serial port data from a GPS receiver on the rooftop, I prefer fibre optic cables over coaxial or twisted pair since fibre optic cables are immune to ground loops, electrical safety issues and EMI, along with using a power supply with a high degree of isolation.
    1
    Yes
    0%
    0
    No
    0%
    1
    • 31084
    Re: Test equipment and 1PPS inputs
    how is that usefull?
    1 pulse per second means your going to have to start looking at how clean the leading edge is, and what PLL is going to sync with it?
    • Curious.George
      • Nov 2011
      • 2305
      • Unknown
      Depends more on how consistent the edge is and how tightly you want to lock to it (and over what period). Obviously, a higher frequency reference gives you more opportunities to lock in a shorter period of time.
      I've long been using a software PLL to frequency lock (not PHASE lock!) to the AC mains in most of the products I design. I bandpass filter the AC line frequency to eliminate glitches, noise, etc. (this is relatively easy to do algorithmically; a fair bit more difficult with analog circuitry!) and capture the "(local CPU) time" of each transition. Then, slowly (once locked) use this to tweek the local time-of-day clock -- taking advantage of the long-term frequency stability of the AC mains and relying on the stability of the CPU clock for the short term.
      (Obviously doesn't work well for devices that see lots of short-term environmental changes that can screw up the CPUs short term stability.)
      NTP (and PTP) use similar algorithms.
      • redwire
        • Dec 2010
        • 3910
        Utility/Power generating industry I worked in uses master GPS 1PPS sync pulse for all the datarecorders. Regulations demand you have data which is time-synchronized to the grid (phase accurate), so they can track outages back to root cause. Otherwise, you never know which breaker tripped first.
        Example is Arbiter Systems 1092C GPS clock popular in big substations etc.
        The problem was long cables cause delays and soft rise/fall times when sending the 1PPS pulse all over the plant. So you get 10's usec error from that, even with proper termination resistors.
        For S/W PLL, as I have seem those algorithms fail. They are also used in pipeline industry, where 1PPS is used to sync interrupters for cathodic protection.
        The S/W bug was to only move the PLL if the sync pulse was within a time window, say 100msec. Noise, interference would sometimes knock the S/W PLL outside that window and it would never re-synchonize. Caused a lot of grief, having to reboot equipment to get it to synchronize.
        • Curious.George
          • Nov 2011
          • 2305
          • Unknown
          Termination won't compensate for propagation delays through copper (~1ns/ft). Hence the need for a GPS receiver at every client *or* an active time distribution protocol (e.g., PTP)
          Not a very smart algorithm, then! :>
          For the line frequency clock (very different from a PPS signal!) to be effective, it must, by its very nature, expect the "reference" to drift out of that window with some regularity (because short term stability of the mains frequency isn't well controlled). Also, it has to accommodate the reference disappearing for variable lengths of time (i.e., power outages and/or folks just turning devices OFF!) So, you have to know when to open the window and "hunt" for the reference as well as whether or not to rely on things that look like they might be the reference.
          PTP is now used rather extensively (and inexpensively) for wired connections between "smart devices". I use a variant of it to ensure I have precise time synchronization throughout my network (because I use the network's idea of time to synchronize audio, video, and the ordering of "events and actions" in a distributed whole). With it, I can synchronize the clocks on nodes to better than a microsecond (because the network traffic is traveling down the same conductors as the "clock information", you can actively measure the propagation delays involved and compensate for them).
          • japlytic
            • Oct 2005
            • 2086
            Although not a piece of test equipment (but a piece of digital communications equipment), a Tandberg MT5600 DVB-T modulator can have the internal reference oscillator disciplined by a 1PPS input.
            • Fritter
              Your most useful test equipment.
              by Fritter
              Hi All,
              For some background, I passed an OND in electronics in the 80's. Life took me elsewhere, and I've finally got around to using it practically. My interest is in vintage electronics.
              My question is, other than a multimeter, what is the most used and useful piece of test equipment ?
              Thanks !
              06-07-2023, 12:23 PM
            • chth96
              How Can I test PWM DM0365R?
              by chth96
              Hello
              I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
              So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
              I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
              I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
              06-18-2025, 04:14 PM
            • khelane
              test active pfc power with lamp test
              by khelane
              Hello
              I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
              Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
              Is there a way...
              06-03-2025, 01:00 AM
            • chronic519
              Mats / mods: detected and repaired GPU fault. Cant seem to test after!
              by chronic519
              Hello.
              GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
              Found issue with a RAM block
              Replaced, green lines gone.
              Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
              Used a good card to test and same results low errors 32+.
              I am just search for some form of command to do a full test on the GPU.
              I just ran the mats command with my good GPU and passed after roughly 40 min.
              The repaired one, ran...
              05-20-2025, 07:56 PM
            • alltvrepairs
              Lg TCon test pins for screen test
              by alltvrepairs
              i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
              Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
              Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
              Appreciate your help....
              06-13-2025, 06:33 AM
