Your most useful test equipment.
  • Fritter
    • Jun 2023
    • 21
    • England
    Hi All,
    For some background, I passed an OND in electronics in the 80's. Life took me elsewhere, and I've finally got around to using it practically. My interest is in vintage electronics.
    My question is, other than a multimeter, what is the most used and useful piece of test equipment ?
    Thanks !
    • 31012
    Re: Your most useful test equipment.
    define "vintage"
    • Fritter
      • Jun 2023
      • 21
      • England
      Not valves.
        • 31012
        an electric desoldering station.
        like a ZD915
        CPC has them on special offer sometimes
        and a scope - a fast one, 50MHz+
        • Fritter
          • Jun 2023
          • 21
          • England
          Thanks.
            master hoarder
            • May 2008
            • 12170
            Multimeters - you got that right!
            And yes, I said it in multiple form, because I always find it handy to have at least one for measuring voltage and another for measuring current. With that said, since I only have 2 hands and can only hold so many probes at once (don't ask how silly I've been with this before ), I also find it very handy to have a good stash of alligator clips / jumper cables of various sizes. Also a large assortment of resistors and heating elements - useful for discharging caps, measuring/limiting current, test-loading PSUs, signal checking/probing, and etc.
            Another one is one of those cheap transistor testers / ESR meters found everywhere online. I use it mainly for testing electrolytic capacitors and rarely start a more intricate troubleshooting project without it. If you're going to be working on old stuff, you really ought to have one, as you will often find a lot of capacitors (not just electrolytic, but sometimes also paper/wax and/or other types) can be out of spec.
            As for soldering iron... old stuff doesn't care much. A simple 30-40 Watt plug-in type with a good copper tip will be just dandy. But a T-12 tip -based iron would be nice to have any day, of course.
            • Fritter
              • Jun 2023
              • 21
              • England
              Thanks ! And apologies for the tardiness.
              • chth96
                How Can I test PWM DM0365R?
                by chth96
                Hello
                I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
                So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
                I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
                I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
                06-18-2025, 04:14 PM
              • SolomonMan
                Vintage BK Precision 1403 Oscilloscope....
                by SolomonMan
                All,
                Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                12-03-2023, 10:39 PM
              • khelane
                test active pfc power with lamp test
                by khelane
                Hello
                I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
                Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
                Is there a way...
                06-03-2025, 01:00 AM
              • chronic519
                Mats / mods: detected and repaired GPU fault. Cant seem to test after!
                by chronic519
                Hello.
                GPU came in, green lines. Spent lots of time using to get the Mats / mods drive working (found on youtube).
                Found issue with a RAM block
                Replaced, green lines gone.
                Trying to test again, assuming getting the false positive. Originally had over 1K on a single bank. Now getting tosses low between banks.
                Used a good card to test and same results low errors 32+.
                I am just search for some form of command to do a full test on the GPU.
                I just ran the mats command with my good GPU and passed after roughly 40 min.
                The repaired one, ran...
                05-20-2025, 07:56 PM
              • alltvrepairs
                Lg TCon test pins for screen test
                by alltvrepairs
                i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                Appreciate your help....
                06-13-2025, 06:33 AM
