Was testing this Eico 320 and noticed though it mostly worked, it seemed to behave weirdly. The amplitude showing up on my scope is really unpredictable - as I change the frequency, amplitude changes...
As my scope is only around 20MHz and this signal generator is 150KHz-34MHz, and 17MHz to 102MHz in harmonics, I expect there probably is some weirdness...
The signal generator clearly works as it easily swamps out a radio reception if it's nearby. FM stations get swamped out to silence when a harmonic is set...
... so most of the caps actually work. And I don't hear any hum...
So which to replace first if any?
