ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
    • 30977
    Re: ESR meter upgrades
    no, arduino is pre-programmed and the code is loaded by com-port.
    you need a usbasp programmer
    http://www.ebay.com/itm/321509199187
    • xelectech
      retired tech
      • Nov 2014
      • 238
      Ok, thanks...how about this one with a 10 to 6 pin adapter? Just looking to save a little DIY time, if possible...
      http://www.ebay.com/itm/USBASP-10-to...-/181215336077
        • 30977
        instead of spending $5,
        why not just spend half that!
        http://www.ebay.com/itm/310635615426
        you even get a spare!
        • xelectech
          retired tech
          • Nov 2014
          • 238
          Looks good, thanks!
            • 30977
            updates.
            trendy now does opto's
            8 & 16MHz builds included.
            • upsss
              • Mar 2016
              • US
              #106
              update:
              btw, i'm willing to compile this for the T3 / T4 boards if asked.
              Hi I would like to try your latest firmware compiled for the T3/T4 tester version which I have and I added the rotary encoder.
                • 30977
                ok, try this.
                i need you to go into the menu and check the encoder works o.k. and in the right direction.
                then go into the contrast menu and find the best contrast value.
                finally, use a meter to check the battery voltage while it's on the lcd to see how close they are.
                • xelectech
                  retired tech
                  • Nov 2014
                  • 238
                  updates.
                  For some reason I was thinking there was only 32Kb of room for the program, am I way off
                  base?
                    • 30977
                    no, 32k flash, and 1k eeprom.
                    why?
                    • xelectech
                      retired tech
                      • Nov 2014
                      • 238
                      why?
                      well, because, the size of the update files you've been putting up here started out at a bit below 32k in size, but kept getting progressively bigger, so it seems that either you've found a way to compress the files when loading them or I totally misunderstand what the update files are about.
                        • 30977
                        hex files.
                        they are just over twice the size of the binary data because they contain address and checksum info.
                        also, each zip contains 2 versions and i now included the source files i modded.
                        • xelectech
                          retired tech
                          • Nov 2014
                          • 238
                          hex files.
                          Oh, ok, I hadn't tried unzipping one yet, I'll try that and see what I see - Thanks
                            • 30977
                            i'm not sure why 3 people downloaded the T4 code without posting answers to my questions afterwards - that code is not tuned or complete!
                            • xelectech
                              retired tech
                              • Nov 2014
                              • 238
                              say stj, I'm wanting to change from the atmega168 that's in my d-i-y esr meter kit to an atmega328 - from what reading I've done, it sounds like it should be doable once I have some kind of programming setup, what do you think? I was thinking of getting the 328 IC from digikey...
                                • 30977
                                the 328p is a direct swap.
                                they are probably cheaper on ebay though.
                                • xelectech
                                  retired tech
                                  • Nov 2014
                                  • 238
                                  Well, I tried ebay, wasted 2hrs. trying to find a seller who'd ship to a po box - then, went through the 'checkout as a guest' all the way past entering my debit card # and they wanted a different debit or cc #. It's worked fine on 2 other occasions, and I know how much my balance is, so wonder wtf...
                                    • 30977
                                    what tester is it?, foto's pls.
                                    • xelectech
                                      retired tech
                                      • Nov 2014
                                      • 238
                                      https://www.badcaps.net/forum/attach...6&d=1454416833
                                      https://www.badcaps.net/forum/attach...7&d=1454416833
                                      A couple of pics above, here's the so-called manual below:
                                      https://www.badcaps.net/forum/attach...2&d=1454418309
                                        • 30977
                                        then you need a 16MHz crystal and a pair of 22pF caps that can fit between the crystal pins and that center hole.
                                        • xelectech
                                          retired tech
                                          • Nov 2014
                                          • 238
                                          Ok, thanks, I think I saw a suitable crystal at digikey for less than a dollar the other day.
                                          Now it's time to do a youtube crash course on avr programming now, I've watched a few from newbiehack.com and think Patrick Hood-Daniels does a pretty good job of explaining things.
                                          BTW, sometimes I behave like such a clown, yesterday when I was shopping on ebay I forgot to enable cookies - I still can't buy from ebay today, but that may now be because I made so many tries wo/ cookies yesterday, what do you think?
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
