ESR meter upgrades
This is a sticky topic.
    • 30970
    Re: ESR meter upgrades
    what cpu is in it?
    • jellytot
      • Mar 2015
      • 42
      • Ireland
      #1122
      Atmega 644p
        • 30970
        good - because the replacement software wont fit a 324
        this is actually built for a 1284 but it should work i think
        it expects a 20Mhz crystal
        changed config files are included for viewing
          • 30970
          i forgot to say,
          you need to reprogram the 8 pin microcontroller that controls power, or replace it with a small circuit
          • jellytot
            • Mar 2015
            • 42
            • Ireland
            #1125
            Thank's Stj have you found this better than the original.
              • 30970
              yes,
              lots of new features.
              but the biggest thing was the circuit for power.
              the original 8pin microcontroller seemed to not go into sleep-mode sometimes and was draining the battery
              • Rado108
                • Jul 2023
                • Croatia
                #1127
                Which ESR meter would you reccomend for testing caps in vintage solid state audio gear? Do i need LCR so i can measure at different frequencys?
                  • 30970
                  vintage and solid-state arent 2 words you often hear together.
                  you mean 70's and 80's ?
                  • chth96
                    by chth96
                    03-09-2024, 10:03 PM
                    12-31-2023, 06:04 AM
                  • jorpec
                    by jorpec
                    Hi
                    Thnaks
                    01-23-2023, 10:37 AM
                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                    12-14-2023, 07:45 PM
                  • irepair559
                    ps4 1215 model Changed port and encoder still no video?
                    by irepair559
                    hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                    Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                    ps4 seems to boot fine blue light then solid...
                    01-01-2023, 12:41 AM
