desoldering station suggestion aoyue 474+ vs aoyue 474++ vs csi 474a
  • clearchris
    • Dec 2013
    • 687
    Re: desoldering station suggestion aoyue 474+ vs aoyue 474++ vs csi 474a
    I looked at the csi model. Looks ok, but really, its a gamble, just like when i bought the ++. There were people here who thought it was a really bad idea.
      • 31198
      csi has a few irons - one is a hakko FX951 rippoff that looks pretty good.
      http://www.circuitspecialists.com/le...g-station.html
      and in a nicer case:
      http://www.circuitspecialists.com/so...-bk3000lf.html
      these are a bit special because the element,and sensor are combined in the tip - they are the best type of design.
      watch this link, it shows how fast these iron's work.
      https://www.youtube.com/watch?v=u588...ature=youtu.be
      if you get the nicer one,
      you can build this later!!!
      http://dangerousprototypes.com/forum...p=61175#p61175
      • shelby5041
        • Feb 2009
        • 1505
        • united states of america usa
        well should i invest in a digital soldering station maybe from csi and also a desoldering digital station?....or do they make combo soldering desoldering stations
        what i have now is pretty sad...lol
        an upgrade is needed i believe....
        • shelby5041
          • Feb 2009
          • 1505
          stj what about this one?
          http://www.circuitspecialists.com/csi_premier_75w.html
          as compared to the one from csi you suggested
            • 31198
            no, that's shit.
            i'll put this simply.,
            there are 2 basic types of iron - not talking about the controller here, just the iron.
            there is the traditional type with a tip that slides onto or into the element.
            most are old hakko 900 series clones inc the one you just linked and most aoyue etc.
            then there are professional irons that have a special all-in-one tip that contains the sensor and element in one.
            these heat up faster and can work on large joints like motherboard capacitors that traditional irons have problems with.
            they are hakko T12/T15, pace and JBL mostly, but the T12/T15 has been cloned and the tips are very cheap.
            i would only buy that type of iron now.
            watch that video i linked.
              • 31198
              watch this comparison of the 2 irons on the same base.
              https://www.youtube.com/watch?v=cVrMjr0eCC4
              • 1supertech
                • Apr 2012
                • 384
                The problem with cheap de soldering station are the life span of a tip is very short
                spend a bit more and get a hakko 808 or new version
                  • 31198
                  tips are cheap, and it's down to how you treat them.
                  • shelby5041
                    • Feb 2009
                    • 1505
                    #29
                    hi thanks but no way in hell im going to spend 250.00 on a desoldering iron such as hakko 808
                    this is a hobby for me....not serious or career
                    im looking at the csi brand from circuit specialist or blackjack/aoyue from sra
                    i do apprdciate all input as i am dumb when it comes to this subject and just want to make a good decision
                    • clearchris
                      • Dec 2013
                      • 687
                      I wouldnt say the problem with cheap/clone tips is lifespan. My problem with cheap tips is that they transfer heat poorly. I put some ebay tips on my hakko 888 and they are all but worthless. They take too long to heat up, then you solder a joint or two and the tip is cold again.
                      Those ebay tips will last forever, because they dont get any use...
                      • shelby5041
                        • Feb 2009
                        • 1505
                        #31
                        hey stj tips are not cheap with the soldering station unit you recommended ..they are 12.00 each as compared to only 4.00 each for other style....
                        i really dont care about how fast it heats up....not important to me....is it that important to have the tip and sensor all in one piece?
                          • 31198
                          you can get those T12/T15 tips on ebay for about the same as you listed for the M900 type tips.
                          and yes,the all in one type can solder stuff that is too big for normal irons.
                          like multi-layer boards and huge copper area's like on pc powersupplies.
                          the speed is important because when the iron touches the joint it loses heat, and the controller has to get it back up to temperature as fast as possible or the solder wont melt.
                            • 31198
                            not a problem on the T15 tips even if they are clones.
                            the 888 uses the old 900 series tips.
                            try cutting one in half - see if they are copper core or not.
                            and put a bit of silicone grease on the element before you fit the tip.
                            it helps transfer heat and reduces sticking when you need to remove the tip.
                            btw, everybody needs to read the thread properly before posting.
                            the bit about tip life was refering to de-soldering units.
                            • pfrcom
                              Oldbie
                              • Jun 2006
                              • 1230
                              Originally posted by stj
                              jbl
                              jbc ?
                              better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                                • 31198
                                my mistake, yes jbc
                                bit difficult to solder with a speaker!
                                  • 31198
                                  http://www.ebay.com/itm/390685073859
                                  tips under 4$
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    #37
                                    oh ok.....well on ebay the other style tips sell for 1.00 lol if u go to sellers like the one you posted for the all in ones
                                    anyways i will consider it..but they charge a lot for shipping so i will keep looking for a unit for about 60.00 that has free shipping and digital display
                                    i like the csi2900 but no free shipping so its actually 75.00 shipped not 59.00
                                    and will look for a desoldering station with digital display with free shipping
                                    i dont want to fork out 145.00 for a desoldering station such as the aoyue 474a++
                                    want to keep it under 100.00 total
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      #38
                                      what about this....if i get the good soldering station csi2900 awill it possibly be good enough to use solder wick to remove the almost impossible ipm chips on plasma tvs that are on multilayer boards with metal pads on top and bottom of board..??
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #39
                                        i actually have one of these but have never used it...
                                        http://www.sears.com/weller-174-port...&mktRedirect=y
                                          • 31198
                                          portasol - it's good that you never used it.
                                          it means you never ruined any boards!
                                          i had one of those bastards - no good for soldering, only setting fire to things!
                                          have you got a 24v psu that can generate atleast 3amps by any chance?
                                            03-31-2024, 02:12 PM
                                          • caprider
                                            Desoldering station/gun above ZD-915/474A++ ?
                                            by caprider
                                            I've been looking for a desoldering station (with sucker pump) for THT in the 100€ +/- price range.
                                            After reading and and watching a lot of reviews, I've noticed that ZD-915/ZD-8915/474A++ kind of .... well, suck. With different design faults making them get clogged way to easily, real difficulties to open the sucked solder tank, 12V cooling fan powered at 18V and so on. Another funny thing is that the same models are sold by a lot of different brands with just a different color and sometimes just different label. I can't even find the manufacturer that makes...
                                            01-15-2022, 04:56 PM
                                          • armini
                                            18VDC PSU completely dead - ZD-915 desoldering station
                                            by armini
                                            Hi everyone!
                                            Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                            Due to a lack of time, I set it aside and didn't look at it.
                                            Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                            According to replies in 18VDC PSU has dropped to...
                                            04-25-2023, 07:49 AM
                                            07-01-2024, 06:34 AM
                                          • rippergr
                                            Desoldering station ZD 915 no indications, no heating
                                            by rippergr
                                            Hello all,
                                            I tried to power on my desoldering station ZD915 today and altough the LCD has power and it's on I don't have any indications on the screen and the gun is not heating at all.
                                            I open it up and I don't see any visual fault anywhere.
                                            Does anyone has any clue what should I check?
                                            10-24-2023, 11:46 AM
