desoldering station suggestion aoyue 474+ vs aoyue 474++ vs csi 474a
    • 31198
    Re: desoldering station suggestion aoyue 474+ vs aoyue 474++ vs csi 474a
    kit
    http://www.ebay.com/itm/271852285421
    or built
    http://www.ebay.com/itm/121539282922
    • shelby5041
      • Feb 2009
      • 1505
      • united states of america usa
      #42
      no i do not stj
      • clearchris
        • Dec 2013
        • 687
        Stj: thats pretty cool. I have wanted a second iron so i can have one iron with a chisel and one with a finer tip for smt, thats pretty affordable. Even cheap enough you could get a pair and run hot tweezers.
          • 31198
          yea, but soldering tweezers arent cheap afaik.
          what you could do is get a couple of the kits, and a big case wih a single transformer to run both.
          • shelby5041
            • Feb 2009
            • 1505
            #45
            what temp range can i control temp at using digital sildering or desoldering stations?.....0 to 900f?
            if i want to set tip to produce 95f can i?....is it truely variable?
              • 31198
              upper limit is usually 450c but even that will destroy the tips
              you never need more than 350c for soldering, maybe 400c for desoldering.
              minimum is down to the controller.
              you just have to read the seller's info.
              and yes, it's variable.
              the microcontroller pulses the power to the iron while monitoring the sensor to get the iron to give the dialed in temperature.
              the ebay conversion kit i linked for example says
              Temperature adjustment range: 200C-480C Maximum Power: 70W
              btw, we dont use F in europe, so i only know centigrade
              • shelby5041
                • Feb 2009
                • 1505
                #47
                i want something with more control ...i want truely variable if they make them and not too costly
                well obviously not 0f .but maybe start at 100f to max....
                • shelby5041
                  • Feb 2009
                  • 1505
                  #48
                  i figured that...how about 50c to max
                    • 31198
                    no idea, but why? no solder melts at 50c
                    • shelby5041
                      • Feb 2009
                      • 1505
                      #50
                      ok......thanks....
                      • lookimback
                        • Aug 2013
                        • 1489
                        I wouldn't buy anything by Aoyue. They sell cheap garbage that will break, like the first time you use it, and parts won't be available. Go with Hakko, you won't regret it.
                        ------------signature starts here------------
                        • shelby5041
                          • Feb 2009
                          • 1505
                          #52
                          hi...hakko too costly......but i dont want something that will break in one day.....the aoyue has pretty good reviews......why u say it breaks?
                          and im novice....o would use it once in a while not 10hrs a day 5days week
                          • lookimback
                            • Aug 2013
                            • 1489
                            This is my Aoyue nightmare. https://www.badcaps.net/forum/showthread.php?t=44489
                            First one the motor started seizing up after about a week, but I really only used it a couple times for a few minutes until the day it died. That day I'd used it for about 3 hours. Returned it for a replacment. Heating element died in less than a week. Replaced the element, it died again after a day of use. Granted, I had the heat all the way up to 450°C, but if it can be turned up that high, it should be able to handle the heat. I noticed the pump housing was cracked when I changed the first element. Tossed it in the corner under the workbench. Forgot about it for a few weeks. Then I had a board like yours which needed to be repaired and spent way too much time fighting with the damn lead free solder and cheap solder suckers. Decided to fix it again, but forgot about the pump housing being cracked. Now if have a paperweight. I'm going to contact Aoyue directly and see if they have the pump. If not then I'll modify it and add an external pump. For what I have invested, I could have bought the Hakko. Aoyue will never get a penny from me again. Except they will get the cost of the pump if they have it. Then I might sell this and get the Hakko.
                            • shelby5041
                              • Feb 2009
                              • 1505
                              #54
                              well i appreciate the real life feedback on the ayoue....
                              even good brands like hakko will have bad reviews....just not as many
                              • lookimback
                                • Aug 2013
                                • 1489
                                It's entirely possible that I never would have had a problem if I didn't have the heat cranked all the way up. I think the heat is what made the motor go in the first one. But, it's a bad design if you can turn it up so high that it burns out the element or overheats the motor.
                                • shelby5041
                                  • Feb 2009
                                  • 1505
                                  #56
                                  yep....i bought a 180 watt soldering gun for the hell of it from harbor freight...its a pos.....the tips cant take the power of the gun...tip lasted me 1 use and blew apart lol....only paid 10.00 for it.....
                                  • lookimback
                                    • Aug 2013
                                    • 1489
                                    I'm not much for cheap tools. I've lost too much money on them. I do have a cheap hot air station which I've had for nearly 2 years and I can't knock it. It's a Kendall 852D++ and was only about $110. The iron doesn't regulate the heat good anymore, but I worked this thing daily from August of 2013 until I got my Hakko FX888D last month. Probably if I replaced the element with the spare which came with it, it would be fine again. I just use it for a second iron when I have SMD components to remove. Two irons makes stuff easier.
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      #58
                                      the kendal is rated pretty high on amazon ....75.00 free ship
                                      • shelby5041
                                        • Feb 2009
                                        • 1505
                                        #59
                                        stj highly recommends buying a soldering iron that uses full length tips......not the type that are short and screw into element...which is most common
                                        whats ur opinion
                                        • clearchris
                                          • Dec 2013
                                          • 687
                                          Agreed. Same thing happened to me. Then i replaced the tip and the gun itself overheated, melted and burned.
                                            03-31-2024, 02:12 PM
                                          • caprider
                                            Desoldering station/gun above ZD-915/474A++ ?
                                            by caprider
                                            I've been looking for a desoldering station (with sucker pump) for THT in the 100€ +/- price range.
                                            After reading and and watching a lot of reviews, I've noticed that ZD-915/ZD-8915/474A++ kind of .... well, suck. With different design faults making them get clogged way to easily, real difficulties to open the sucked solder tank, 12V cooling fan powered at 18V and so on. Another funny thing is that the same models are sold by a lot of different brands with just a different color and sometimes just different label. I can't even find the manufacturer that makes...
                                            01-15-2022, 04:56 PM
                                          • armini
                                            18VDC PSU completely dead - ZD-915 desoldering station
                                            by armini
                                            Hi everyone!
                                            Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                            Due to a lack of time, I set it aside and didn't look at it.
                                            Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                            According to replies in 18VDC PSU has dropped to...
                                            04-25-2023, 07:49 AM
                                            07-01-2024, 06:34 AM
                                          • rippergr
                                            Desoldering station ZD 915 no indications, no heating
                                            by rippergr
                                            Hello all,
                                            I tried to power on my desoldering station ZD915 today and altough the LCD has power and it's on I don't have any indications on the screen and the gun is not heating at all.
                                            I open it up and I don't see any visual fault anywhere.
                                            Does anyone has any clue what should I check?
                                            10-24-2023, 11:46 AM
