desoldering station suggestion aoyue 474+ vs aoyue 474++ vs csi 474a
  • shelby5041
    • Feb 2009
    • 1505
    • united states of america usa
    i am novice and just want something better than my 10.00 radio shack sucker....it doesnt work on lead solder at all
    and i do not want to spend a lot of money
    the 3 i have listed here seem to be knockoffs of higher end brands which is ok for me.....
    but can someone suggest
    aoyue 474++ digital version $145.00 shipped amazon
    aoyue 474+ analog version $165.00 shipped
    csi 474a seems to be a knockoff of the knockoff aoyue 474+ its $116.00 shipped
    • 31198
    Re: desoldering station suggestion aoyue 474+ vs aoyue 474++ vs csi 474a
    digital versions are always best.
    not even knowing what country your in, i cant recomend anything specific.
    • shelby5041
      • Feb 2009
      • 1505
      thanks.....the aoyue 474++ is digital display
      i live in USA
      i have seen lowest price 145.00 free ship at amazon
      the csi 474a is basically a knockoff non digital version of the aoyue 474++ and is $116.00 shipped
      do you think its worth $30.00 more to get a digital version vs non digital version assuming both products are equal otherwise ?
      • clearchris
        • Dec 2013
        • 687
        I have the ++ model and Im very happy with it. Takes a few minutes to heat up but once it gets hot you are good to go. It really speeds up the repair process, Id never go back to a hand pump.
        I posted some teardown pics on here a few months back if you are interested.
        • shelby5041
          • Feb 2009
          • 1505
          the only concern i have with digital anything is the electronics go bad after use
          analog things seems to last forever and digital seem to fail way sooner
          is this a fact?
          • shelby5041
            • Feb 2009
            • 1505
            hey clear chris do you think the model u have would remove an ipm from a y or z board plasma tv?
            they are a pain...double sided board metal pads on both sides and lead free solder
            nightmare
            • shelby5041
              • Feb 2009
              • 1505
              i had to use a dremel and cut chip body out then cut legs off.....
              • clearchris
                • Dec 2013
                • 687
                I wouldnt expect any knockoff clone to last forever.
                • clearchris
                  • Dec 2013
                  • 687
                  I havent done any TV work, but sometimes I preheat with a hot air station if there are large ground planes, etc. Also, Ill flow pb solder and sometimes chipquik into joints if needed. I dont think a desolder tool is a silver bullet for all situations. Its really useful though.
                  A lot of times Ill also have my iron in the right hand desolder tool in left, especially if its tight quarters.
                    • 31198
                    the digital version lets you properly see the temperature, that's important when soldering / desoldering
                    not what you pointed a knob at, but the actual tip temperature second by second.
                    • shelby5041
                      • Feb 2009
                      • 1505
                      thanks.....i know ....not much of anything made today lasts more than a couple yrs..they are made to break....but in the old days things were made to last forever...and not break...when repuation mattered lol
                      now everyhting is considered disposable lol
                      im just concerned on the digital display version....maybe would be better for me to get the control knob version....i dont need anyhting fancy.....unless having the digital display temp is that much better or a must have?
                      • shelby5041
                        • Feb 2009
                        • 1505
                        oh ok....thanks stj...
                        im novice though so not even sure what temp display would even mean to me since i have no clue...i would just turn it up until it melted solder....lol
                        is this something a pro would benefit from and not someone like me?
                        • shelby5041
                          • Feb 2009
                          • 1505
                          and correction is aoyue 474a+ and 474a++ ...not 474+ and 474++
                          • clearchris
                            • Dec 2013
                            • 687
                            Different solders melt at different temperatures. Lead free solder melts at a higher temperature than pb solder (37/63 melts lowest) and chipquik is a secret alloy that melts really low. I almost always melt some 37/63 in to dilute the lead free solder to make it easier to remove.
                            You want to solder at the lowest temp you can to reduce burning components. Digital readout helps.
                            • shelby5041
                              • Feb 2009
                              • 1505
                              yes thats true...but all elecronics made since mid 2000's are lead free and that the huge problem i have....what i have just doesnt work on lead free solder
                              and yes i have used too much /long heat and broken pads due to this.....because i have to keep the soldering iron on so long to try to melt the solder it ruins the pad sometimes....so u think its really worth me spending the extra 30.00 to get the digital readout version?
                              • shelby5041
                                • Feb 2009
                                • 1505
                                the solder i use is like 60/40 and it melts fast..i do not use lead free solder when i solder.......and have no issues soldering i have issues desoldering.lead free solder
                                • clearchris
                                  • Dec 2013
                                  • 687
                                  Im going to bring this out of PM to the forum so you can hear it from others too.
                                  Shelby is using a radio shack 30watt firestick.
                                  To be honest Im amazed you are fixing plasmas with that at all. A 30 watt iron isnt enough to do lead free solder work. No way I would throw down money on a desolder station before I upgraded to a proper iron.
                                  Hakko fx-888d (70 watts) can be had for 80$ or so. It heats up in 20 seconds. You solder wick.will actually work when you have heat behind it. Then melt pb solder in and watch it melt much easier.
                                  A desolder station is a luxury. A good iron is essential.
                                  My 2c.
                                  Edit: next roll get the 37/63. It melts noticably lower than 60/40.
                                  • shelby5041
                                    • Feb 2009
                                    • 1505
                                    yes i struggle a lot with what i have but it was sufficient for lead solder pre 2006/7 tvs
                                    but now its a pain in the ass...with lead free
                                    i appreciate your help.......i really dont like solder wick...its a pain in the butt....and messy ....i really like the pump idea....thats why i was considering the desolder station
                                    can you look up the csi474a and let me know what u think...maybe this is what i should get...its 116.00 shipped...and is same manuf as your aoyue474a++
                                    • shelby5041
                                      • Feb 2009
                                      • 1505
                                      and i will look into the 37/63 suggestion
                                        • 31198
                                        i love Pb3
                                        just need a digital iron to set the temp - i like 310 for most work.
                                          03-31-2024, 02:12 PM
                                        • caprider
                                          Desoldering station/gun above ZD-915/474A++ ?
                                          by caprider
                                          I've been looking for a desoldering station (with sucker pump) for THT in the 100€ +/- price range.
                                          After reading and and watching a lot of reviews, I've noticed that ZD-915/ZD-8915/474A++ kind of .... well, suck. With different design faults making them get clogged way to easily, real difficulties to open the sucked solder tank, 12V cooling fan powered at 18V and so on. Another funny thing is that the same models are sold by a lot of different brands with just a different color and sometimes just different label. I can't even find the manufacturer that makes...
                                          01-15-2022, 04:56 PM
                                        • armini
                                          18VDC PSU completely dead - ZD-915 desoldering station
                                          by armini
                                          Hi everyone!
                                          Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
                                          Due to a lack of time, I set it aside and didn't look at it.
                                          Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
                                          According to replies in 18VDC PSU has dropped to...
                                          04-25-2023, 07:49 AM
                                          07-01-2024, 06:34 AM
                                        • rippergr
                                          Desoldering station ZD 915 no indications, no heating
                                          by rippergr
                                          Hello all,
                                          I tried to power on my desoldering station ZD915 today and altough the LCD has power and it's on I don't have any indications on the screen and the gun is not heating at all.
                                          I open it up and I don't see any visual fault anywhere.
                                          Does anyone has any clue what should I check?
                                          10-24-2023, 11:46 AM
