Soldering BGA by hand...
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Deadbug style:
    http://www.chiaki.cc/Pyxis2010/index.htm
    http://dangerousprototypes.com/forum...php?f=2&t=4683
    -David VanHorn
    • 31015
    Re: Soldering BGA by hand...
    in the time that took, he could have got a job, and used the money to have a pcb made.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4951
      • New Zealand
      But this way he didn't need a reflow oven...
      -David VanHorn
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        That's crazy... I wouldn't even dead bug a DIP... Then again I try to fabricate my own boards...
          • 31015
          i did a "dead bug" on a 32pin tqfp package once so i could program the bootloader on it.
          i only needed about 12 wires though.
          • keeney123
            Lauren
            • Sep 2014
            • 2536
            Mathematicians who like fractals and numbers would love doing such integrated soldering and reinventing the wheel because it is fun.
            • ben7
              Capaholic
              • Jan 2011
              • 4059
              I've dead-bugged a 10 pin DFN before. 0.5mm pad pitch. Maybe about 0.2mm or so between contacts....
              Yeah I did that by hand. Took a while, but I was successful!
              I had to use the wire strands from some stranded wire... was the only wire I had that was thin enough!
              Muh-soggy-knee
              • bpjl
                SEF 551.10 - Error starting the reflow oven.
                by bpjl
                When starting the SEF 551.10 reflow oven, the following problem occurs:
                It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                10-17-2024, 06:30 AM
              • bpjl
                SEF 551.10 - How to raise the temperature of the unleaded soldering furnace?
                by bpjl
                We continue to struggle with the SEF 551.10 reflow oven. After we managed to start it in october - the topic here -> https://www.badcaps.net/forum/troubl...he-reflow-oven everything promised to be good. But...
                While soldering with lead paste somehow goes, but we cannot force the stove to raise the temperature
                that he would dissolve the unleaded binder. I even doubted what this bastard shows on screen and passed through it a thermocouple...
                03-16-2025, 09:26 AM
              • tmhobadcap
                Can a microwave oven be used to reflow solder joint?
                by tmhobadcap
                I heard somebody suggested a way of repair faulty led light bulb which I have never heard of. The way is to put the led light bulb inside a microwave oven and turn on the microwave oven for a few seconds. He said that faulty led light bulb is usually caused by poor solder joint between the led and the pcb. Putting the bulb inside the microwave oven for a few seconds will heat and reflow the solder joint making it works again.
                Is that possible? I do not want to try this unless I have a spare microwave oven.
                (I do not mean to suggest somebody to try this. It may be...
                10-30-2020, 08:38 PM
              • tony359
                Reflow equipment
                by tony359
                Hello all,
                I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
                I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
                Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
                12-25-2021, 01:29 PM
              • Azurain
                Elitebook 840 G5 Bios Chip Soldering Question
                by Azurain
                I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                04-14-2023, 06:58 PM
