Soldering BGA by hand...
Re: Soldering BGA by hand...
I've dead-bugged a 10 pin DFN before. 0.5mm pad pitch. Maybe about 0.2mm or so between contacts....
Yeah I did that by hand. Took a while, but I was successful!
I had to use the wire strands from some stranded wire... was the only wire I had that was thin enough!Muh-soggy-kneeComment
by bpjlHello,
When starting the SEF 551.10 reflow oven, the following problem occurs:
It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer... -
by bpjlHi,
We continue to struggle with the SEF 551.10 reflow oven. After we managed to start it in october - the topic here -> https://www.badcaps.net/forum/troubl...he-reflow-oven everything promised to be good. But...
While soldering with lead paste somehow goes, but we cannot force the stove to raise the temperature
that he would dissolve the unleaded binder. I even doubted what this bastard shows on screen and passed through it a thermocouple...03-16-2025, 09:26 AM -
by tmhobadcapI heard somebody suggested a way of repair faulty led light bulb which I have never heard of. The way is to put the led light bulb inside a microwave oven and turn on the microwave oven for a few seconds. He said that faulty led light bulb is usually caused by poor solder joint between the led and the pcb. Putting the bulb inside the microwave oven for a few seconds will heat and reflow the solder joint making it works again.
Is that possible? I do not want to try this unless I have a spare microwave oven.
(I do not mean to suggest somebody to try this. It may be... -
by Ady2017Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...1 Photo
by Olvin1Hello everyone,
I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
• A detailed temperature profile for reflowing this specific CPU
• Step-by-step guidance for a safe and effective reflow process
• Tips on what to watch out for during the procedure
If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...08-01-2025, 01:59 PM - Loading...
