My very first Rework flux by KINGBO Japan
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    In the world of the ones who have master the job of rework/reflow/reballing, this product is considered as good enough, or better said as acceptable for high quality soldering.
    Now its time to find out even by self how it measure up against common soldering cream, so to create my very own impression about it.
    IPA it does dissolve it.
    I guess that all that I need to evaluate is activation temperature and drying time.
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: My very first Rework flux by KINGBO Japan
    All i can say is that you won't regret buying it. Yes, IPA dissolves it easily.
    It's also good for cleaning nasty residue left by other fluxes, which IPA alone won't clean. Apply over nasty flux residue, heat, and then clean off with IPA.
    A working TV? How boring!
    • vmartins45
      • Jul 2013
      • 8
      • Portugal
      Is not bad, but Amatech is must better.
      • clearchris
        • Dec 2013
        • 687
        Whats IPA?
        I have recently started using "brake and carb cleaner" to clean flux. Works great, its cheap and available at any auto parts store. Downsides are sometimes it takes a while to dry and if you burn it, you get phosgene gas, whch will kill you. Woohoo.
        Btw, is this suitable only for bga type work, or also good for general purpose soldering?
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          Originally posted by clearchris
          Whats IPA?
          Isopropyl alcohol
          • clearchris
            • Dec 2013
            • 687
            Ahh. Must be good stuff because in my limited experience, IPA dissolves no flux I have found.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              I use it for everything.
              Fake Amtech is crap, and the genuine one is just too expensive for my taste. Kingbo is reasonably priced and does the job - so i'm sticking to it. Pun not intended.
              • Kiriakos GR
                Banned
                • May 2012
                • 940
                • Greece
                Did you try to dissolve some of it with IPA so to make your own cocktail of liquid flux ?
                • clearchris
                  • Dec 2013
                  • 687
                  Got mine on order today. We shall see. Id be thrilled to not have to use brake cleaner.
                  • EdoNork
                    • 6
                    Any trusted seller for Europe?
                    • Kiriakos GR
                      Banned
                      • May 2012
                      • 940
                      • Greece
                      My item came from eBay, one local professional friend of my ordered some quantity for him self and ordered one more just for me, and gave it to me as gift because we cooperate from time to time and we exchange favors by helping its other in a technical level.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        • Romania
                        Got mine from ebay as well, no complaints. IIRC i got it from e-best trade.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          As for brake cleaner or carb cleaner, should read the labels. Some of the companies that sell their carb/brake cleaners in California, USA will reformulate to remove chlorinated organics. The ones that contain Methylene Chloride is the one to avoid as this is the chemical if burned will generate phosgene. Some of the brake/carb cleaners I bought do not contain Methylene Chloride and are safer.
                          Unfortunate Methylene Chloride is a great solvent and can remove a lot more crap than other organic solvents. Acetone is usually the replacement and it's nowhere as good as Methylene Chloride.
                          (Yeah, I buy this stuff for its intended use, I just so happen to use it for electronics just because I had it )
                          • EdoNork
                            • 6
                            eBay them. I asked because eBay is full of badly copied products.
                            Thank you.
                            • Kiriakos GR
                              Banned
                              • May 2012
                              • 940
                              • Greece
                              In this case I will offer two clues which possibly will help identifying authenticity.
                              a) inner plastic sealing cover
                              b) The cream color looks as to was butter.
                              • coss
                                • Feb 2013
                                • 4
                                • Portugal
                                All this "kingbo" flux is too confusing for me.
                                Who is the "original" manufacter? Why cant i find the company website?
                                Is there a product datasheet?
                                Also,
                                why there isn't any reliable supplier that sells it?
                                .... maybe the original is not so original....
                                • tron
                                  • Apr 2009
                                  • 47
                                  Also,
                                  http://www.bgamods.com/forum/viewtop...baeb7&start=20
                                  • Kiriakos GR
                                    Banned
                                    • May 2012
                                    • 940
                                    • Greece
                                    Somesort of industry which makes large scale OEM production, for industrial soldering systems.
                                    Because a company which work with large OEM customers usualy does not need fame from other sources.
                                    No one makes public his actual chemical composition, they are not stupid.
                                    Also,
                                    For some one accepting buying such a potentially hazardous product, which is for industrial use, you do make very lightweight questions.
                                    This product is to be used by grownups professionals which are organized to handle the risk.
                                    And if we are having this conversation today is because this product solution have been tested and it does the job.
                                    Even car paint is dangerous when inhaled, but they are professionals out there painting all day long.
                                    I am not teaching today loyalty to trustful suppliers, the rule of thump is that if you discover a reliable one, you stick with him for ever.
                                    • coss
                                      • Feb 2013
                                      • 4
                                      • Portugal
                                      I´m not saying the product isn't good, it could be the best, i don't know, never used it.
                                      The fact that it is oem produced doesnt explain the lack of the "brand" information.
                                      What i look in a datasheet is not the product composition, but its specifications and properties. something like this
                                      I would need to see a datasheet/specsheet/official website information to assume that.
                                      Industrial or not, you don't find (very) strange there isn't a offical distribuitor for it? Not even an address or phone number in the label?
                                      • Th3_uN1Qu3
                                        Believe in
                                        • Jul 2010
                                        • 6031
                                        • Romania
                                        It could very well be a fake, since it constains the same typo found on all Chinese fluxes, including the very common Amtech fakes: "State of Colifornia." However, if it is a fake, it's a really good one.
                                        • Peter_1402
                                          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                          by Peter_1402
                                          Hi Everyone,
                                          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                          1. Soldering iron works great
                                          2. There is a burnt mark on the hot air gun handle.
                                          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                          Reed switch tested ok with a magnet.
                                          From the above test, I can conclude...
                                          07-12-2025, 11:50 AM
                                          Multifix 425-01 and 450-01 Rework Flux Datasheet
                                          REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                          - No Clean Formulations
                                          - Low residue
                                          - Range of activity to deal with different component solderability
                                          - Halide free
                                          - Suitable for dispensing
                                          - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                          Both products are supplied in syringes or cartridges for application by dispensing....
                                          10-07-2024, 06:02 AM
                                        • chth96
                                          Is it good to use chemistronic flux off es835b for flux remover?
                                          by chth96
                                          I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                                          Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                                          11-17-2023, 07:25 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • estabilito
                                          Tips geting oxidized when using wick
                                          by estabilito
                                          Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                                          i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                                          Temperature: 350-365celsius
                                          station: jbc cd-2bqe
                                          Wick: edsyn
                                          flux: warton hf rework jelly
                                          Do you have any tips?...
                                          04-12-2025, 11:55 AM
