I Need Advice on the purchase of a Multimeter
    Hi i am new to the forum and new to electronics, i am attempting to fix my first monitor and i want to purchase a multimeter that will do the job.
    Could anyone give me some suggestions on a multimeter that i can use for testing components. I would like to know what functions i am looking for in a multimeter for doing general work on boards. I would like to purchase a meter of ebay (convenient) that is in the low to mid range.
    So if anyone could let me know what type of meters there are to buy and what there pros and cons are it would be appreciated.
    A cheap meter would be ideal atm ( under 50$ ) but if its not going to be good for the jobs ahead ill spend more.
    Re: I Need Advice on the purchase of a Multimeter
    I would suggest a Mastech Ms8264 or the identical Sinometer Ms8264. Some people say the sinometer is a less quality item. I cannot comment on that since I have not worked with one. This meter is a decent low cost meter that will do everything you need short of testing capacitors. That requires a seperate esr meter.
      Indeed as i have learned reading the threads, Could i also get a recommendation on a good cheap esr meter.
        I'm partial to Fluke DVM, but nothing wrong with a Tenma DVM from mcm electronics for someone just getting started
        Ron Driver,BSEE,CET,ISCET,NESDA
          Not the cheapest but my favorite is the ESR-micro v4.0. It displays both parameters at the same time. Also on the multimeter the ms8264 has a manual function dial, if you want an auto-ranging meter then the model is Mastech MS8268. Auto-range meters are a little slower at getting a stable reading.
            Same here on Fluke based on experience with everything else I've purchased and destroyed. I can't kill this Fluke had it 12 years. However you don't want to pay $300 for something that your never going to use it everyday, theirs a Fluke 119 ranging around $100 that might do everything you want.
              1) Your fellow countryman, Dave Jones over at eevblog.com, has a $50 multimeter shootout
              http://www.eevblog.com/2010/06/04/ee...eter-shootout/
              2) A buyer's guide is also at
              http://www.eevblog.com/2010/04/14/ee...-buying-guide/
              3) Martin Lorton buyer's guide
              http://www.youtube.com/watch?v=jC_Qh...ure=plpp_video
              4) If you are patient, you can get some good deals on used multimeters off ebay (like I have).
              --- begin sig file ---
              --- end sig file ---
                I'll contest the above as a not being true as a general statement.
                I have now used about 15 different multimeters both autoranging and manual from different manufacturers.
                Some autoranging multimeters inlcuding my Fluke 27 are slow to display a reading since it only updates the screen 2 times/sec. Others like my Fluke 83III are lightning fast at displaying a reading (4 times/sec). I also have some manual ranging multimeters that are very slow (worse than 2 times/sec).
                For troubleshooting lcds, I think an autorange multimeter is more efficient than a manual. While troubleshooting, I may have to measure the large filter cap (165V DC), the 5V standby, secondary voltages like 24V DC and some voltage regulators at 1.8V DC. For an autorange multimeter, I just leave it on the DC V setting. For a manual range multimeter, I have to switch the dial 4 times (200V, 20V, and back to 200V to 2000mV) in the above scenario.
                  I think you made a typo, there is no Fluke 119, but you can get a brand new Fluke 117 off USA ebay like these 2 auctions (now ended)
                  http://www.ebay.com/itm/280899544934
                  http://www.ebay.com/itm/140770155470
                    There is also a Fluke 179, which if you are patient, can be purchased in the $100 range off ebay.
                      From
                      https://www.badcaps.net/forum/showpo...67&postcount=4
                      Originally posted by walking View Post
                      Unless you're going to later "fix" heart monitors or passenger aircraft systems don't spend more than $20.
                      I managed to get a Fluke 27 for $20. Although it is probably more than 20 years old, it is as accurate as my other Fluke multimeters and MORE accurate than the non Flukes.
                      PS. I'm not a Fluke fan boy, but it is the easiest multimeter to purchase used as there are quite of few them versus every other brand. I have managed to get 6 used Flukes for under $50 each (sometimes well under).
                        From
                        https://www.badcaps.net/forum/showpo...27&postcount=5
                        Originally posted by scampo77 View Post
                        you need to look for 2 things fixing monitors. for the meter you need to find is a true RMS meter. these are far more accurate and far more stable.
                        We, the regulars, rarely, ever ask people to do any sort of AC measurement. So for troubleshooting lcd/TV purposes, a true RMS multimeter is not required.
                        We usually ask for DC voltage and resistance measurements 99% of the time. We also rarely ask for current measurements.
                        when measuring a voltage regulator that is +- 10% and it is 1.8v the difference between 1.86v and 1.78v can really help you when diagnosing these things.
                        I hope you mean 1.0% (one) percent. And voltage regulators found in lcds/TVs are usually DC voltage regulators so no true RMS is required.
