MacBook Air A1932
  • TOMÁŠ
    • Oct 2022
    • 18
    • Spojené království
    MacBook Air A1932
    Hi, I've never worked with a MacBook before, so I need some advice.
    I have a MacBook Air A1932 (820-01521). When I plugged in the charger with an amp meter, it showed 19.7V and 1.9A, which indicates that it's charging, but when I press the power button, it doesn't turn on. So, I disassembled it, disconnected the battery, and plugged in the charger again. It showed 19.6V and 0.04A, and pressing the power button had no effect—no current draw at all. Then, I removed the motherboard, connected the charger again, and got the same results. I took a multimeter and checked all the coils, and everything seemed fine.
    Based on what I found online, I measured the following:
    - PPBUS_G3H: 12.62V
    - PP3V3_G3H: 3.3V
    - PP3V3_G3H_RTC: 3.3V
    - PP5V_G3S: 5V
    - PP3V3_G3S: 3.3V
    - PP1V8_G3S: 0V / 1.8V
    - PP1V8_S5: 1.8V
    - PP3V3_S5: 3.3V
    - PP1V1_SLPS2R: 1.1V
    - PP1V1_SLPDDR: 1.1V
    - PP1V8_SSD: 1.8V
    - PP0V9_SSD: 0.9V
    - PP1V_PRIM: 0V
    - PPVCC_PRIM_CORE: 0V
    I didn't touch anything, but suddenly I felt some heat near the PD controller, and the charger showed 5V and 0.4A. A thermal camera pointed to the PD controller, so I replaced it. The heat is gone now, but I still get 5V and around 0.3A. I'm here hoping someone can help me with advice. Otherwise, I plan to replace the second PD controller as well. I'd really appreciate any guidance. Thanks!
    Also forgot to mention all coils still fine.
  • mon2
    • 14996
    This may be your case:
    https://repair.wiki/w/MacBook_Air_A1...cycling_repair
    reference:
    https://repair.wiki/w/MacBook_Air_A1932
    Review this article:
    https://logi.wiki/index.php/CD3215_Bootup_Sequence
    • TOMÁŠ
      • Oct 2022
      • 18
      Thank you, will have a look Sunday.
      • bouch
        unlock macbook air A1932 2019
        by bouch
        hi
        i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
        i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
        i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
        have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
        I need help or information?
        Does anyone have the minat2 activator 1.4 software?
        Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
        Thank yo...
        03-12-2025, 10:14 AM
      • nikolayu
        MacBook Air A1932 internet recovery loop
        by nikolayu
        I have A1932 that is going to internet recovery every time.
        i tried nvram and smc reset but it looks that MacBook is not reacting to that.
        i tried to restore it through DFU but it restarts in the middle of process and Apple Configurator does not show any error, just stays like in progress.
        keyboard is working because I can connect to WiFi but internet recovery always fails with 2100 or 2003 error.
        also won’t open option to boot from usb device.
        and I noticed that is not possible to turn off the MacBook. It’s always turning on by itself.
        07-22-2025, 02:55 AM
      • Arshad alam4659
        macbook air a1932 sign out of find my
        by Arshad alam4659
        Today I receive a MacBook Air A1932, its apple ID has been deleted but when I am resetting it is showing a message(sign out of find my ) customer's have no apple id he bought this MacBook from someone else can someone help me remove this message...
        04-09-2025, 12:37 AM
      • astroboypaul
        Macbook A1932 Some Keys Not Working
        by astroboypaul
        Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
        Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
        06-10-2024, 05:32 AM
      • Clarify4082
        Macbook Air 2018 A1932 Bootloop
        by Clarify4082
        I have a A1932 Macbook Air with Bootloop.
        I already replaced the battery with a new one and reset NVRAM and SNC.
        When I start the Macbook the Screen is coming on (no Logo) and switches of after a few seconds. If I start without the trackpad and keyboard it stays on longer.
        If I use diagnostic (Option+D), recovery (Option+R) I always get the Apple logo and it go into online-Recovery. Even if I boot the installer from a USB-stick it ends up in online-recovery. Sometimes it crashed short after entering the wifi password, sometimes it loads the recovery...
        01-07-2025, 09:41 AM
