Not a repair, only a purchase advice ask for
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4543
    • Italy - Milan
    Hi, briefly for a purchase advice i would like to know from experts if recent LG still suffers processor soldering problem, like almost every LG led tv i know. Thanks.
  • Biruslapio
    • Nov 2013
    • 552
    • Brasil
    Re: Not a repair, only a purchase advice ask for
    Some incomplete info I know of LG TVs.
    Bag BGA or processor:
    LG series from 2009
    LD some models
    LV
    LM
    UF higher end models
    Horrible panel:
    F
    J
    H
    Bad Backlights:
    F
    J
    H
    The whole F, J and H series are a fiasco, backlight that turns blue over time, and panel dies like flies, develops horizontal lines or flickering.
    Seems that from UM series forward LGs have been solid, at least compared to Samsung, their NU series have terrible backlights. RU, TU and expensive QLEDs have been having panel problems. I haven't seen any LG UM models or newer with any fault for sale around here.
    Easy to figure out when you search the motherboard for a select model and check the price, usually if it has bad BGA there will be listings offering to "repair" the board, and a working one will cost at least 70% of what the TV is worth.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4543
      • Italy - Milan
      thanks, which of them are now on the market?
      • Biruslapio
        • Nov 2013
        • 552
        • Brasil
        being sold new?
        LB 2014 < backlight problems
        UJ 2015
        UH 2016
        UJ 2017
        UK 2018
        UM 2019
        UN 2020
        UP 2021, being produced and sold for now.
        For Nanocell I'll use a single model as example:
        SJ8500 2017
        SK8000 2018
        SM8600 2019
        NANO85 2020 - NANO86 in some countries
        NANO85 2021
        The "U" is for ultra HD (4k), for 1080p/768p LG uses "L" prefix, like LF or LJ
        Bottom tier LED TVs have reached stagnation, there's nothing new since 2017, same peak brightness, panel types vary from manufacturer, lg 55 inch is IPS or ADS, they're similar, some 60 inch models uses VA.
        Even high tier, most of them are 4k 120Hz, the only difference between them is having a higher peak brightness with mini-led or 8k panel, which has no use right now.
        • aggadaway
          ASUS ProArt Display PA278CV
          by aggadaway
          Hello all,
          I'm looking for some help with an ASUS ProArt Display PA278CV that's no longer working after a lightning strike. The graphics card connected to it also failed, which points to some sort of surge.
          The monitor powers up and the on-screen display (OSD) menu works perfectly fine. However, it displays a "No Signal" message regardless of whether I use the HDMI or DisplayPort inputs. Since the menu system is functional, I suspect the issue is with the input circuitry rather than the main power supply or the display panel itself. I've already tested the power...
          09-02-2025, 11:00 PM
        • Scaff
          Dell Inspiron 7506 2-in-1 HELLCAT 19859-1 - No power
          by Scaff
          I've had trouble with the power on this device since I got it. It always shut down with no warning and would often fail to power up. Dell's advice has been to disconnect the power and battery, wait, then reconnect and boot. Letting the battery run down completely also helped. I had them come out at one point and they said they replaced the board. This helped for a while but then it just stopped powering on. At this point it's well out of warranty. I missed the chance to get them to come out again because life. Current situation is it shows zero signs of life with both barrel...
          06-08-2025, 01:46 AM
        • Ady2017
          SMD fuse soldering advice please
          by Ady2017
          Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
          11-07-2025, 12:03 PM
        • prodigy83
          MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
          by prodigy83
          My reference only: TT10141.
          Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
          Mosfet specs are as follows:
          Chip markings:...
          03-12-2024, 01:38 PM
        • chazzo
          CH341 programmer advice, including jumpers seemingly reversed
          by chazzo
          I’d appreciate some very basic advice on CH341x programmers. I know this topic comes up from time to time, but stuff changes, so I hope a refresh is in order. In particular, I see some unexpected things happening with jumper positions.
          [My plan is to learn to read and write 24CO2 EEPROMs via I2C. The first target is the one in my Uni-T clamp meter, but before tackling that I have some brand-new EEPROMs to practice on.]
          I have two basic Chinese programmers. One is the blue board with a CH341A and two rows of pin headers. To my untrained eye it looks like all the others....
          10-12-2025, 08:15 AM
