Favorite solder mixes
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    well, as many know, solder comes in many mixes... the most common being either 60/40 and 63/37.
    Vote on your favorite mix.
    I personally used to like 60/40, but I now find 63/37 to perform much better due to the lower melting temp and lack of a semisolid state.
    edit- on another note, if i have to use lead-free for something, i find that 99/0.7 (sn/cu) seems to work well... not as good as leaded, but if leaded isn't allowed, then you do what you have to do.
    15
    60/40
    0%
    5
    63/37
    0%
    8
    Other
    0%
    2
    sigpic
    (Insert witty quote here)
  • c_hegge
    • Sep 2009
    • 5219
    Re: Favorite solder mixes
    I can't comment, since I've only ever had 60/40, but it works well for everything I solder
    • Agent24
      I see dead caps
      • Oct 2007
      • 4957
      • New Zealand
      Both seem the same to me, or I haven't used 63/37 enough to notice the difference.
      -David VanHorn
      • mockingbird
        • Dec 2008
        • 5484
        I think you have it mixed... The 63/37 HAS the semi-sold state - that means to say - that it will stay fluid for a few seconds even after the ehat source is taken away. I started using 63/37 exclusively now. Either way is ok, I guess.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4957
          • New Zealand
          No, 60/40 is definitely the one with the semi-solid state.
          -David VanHorn
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            I voted for 60/40, but in reality I'm not really quire sure what I'm using because the leaded solder I have was given to me by my uncle (and if I'm not mistaken, that stuff is leftover from when he was into electronics way back in the day). I works pretty good, though, and the joints come out nice and shiny.
            I also have a spool of lead free solder (95 SN, 5 Sb), 3mm dia, and no flux inside. I use that with no-clean flux when soldering SMT stuff.... Works very well actually. Sometimes i used it for recaps as well, especially on multilayer boards, since the flux goes down in the vias, and then the solder follows it and sticks to it.
            Most of the time, the joints look fairly shiny too. It's only if I don't heat the component enough or if I move it while the solder is cooling that the joint will look dull.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              I voted other since I don't know.
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Page 3.
                Lots of other handy info too.
                Mann-Made Global Warming.
                - Dr Seuss
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16956
                  60/40 is my preferred....but 63/37 is also fine. Either will work for motherboard repair. I've found that 63/37 is a tad easier to work with on some of the poorer RoHS mixes, as the 63/37 melts at a little lower temp and seems to make reflowing a little easier....would be helpful to those using lower wattage irons.
                  <--- Badcaps.net Founder
                  Badcaps.net Services:
                  Motherboard Repair Services
                  http://folding.stanford.edu/
                  Team : 49813
                  Join in!!
                  Team Stats
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4957
                    • New Zealand
                    Originally posted by PCBONEZ
                    Page 3.
                    I wonder why they don't want people to use water soluble fluxes?
                    -David VanHorn
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Most of them are corrosive and the byproducts [corrosion] can be conductive so if not properly cleaned up after it can lead to problems.
                      The biggest problem is probably the tight spots under SMD parts where proper cleaning is difficult.
                      In other words, though not advertised or thought of that way, they are basically an acid flux.
                      [From here: http://www.residues.com/faqs_fluxes.html ]
                      Q. What are the dangers associated with water soluble fluxes?
                      A. Water soluble fluxes (WSFs) are more aggressive in their ability to strip oxides. The degree of aggressiveness depends on the activators used. A WSF, as a corrosive material, does not know when to stop stripping oxide. Consequently, if you don’t clean the flux residues off, then it will continue to eat away the base metal. Electrical leakage currents and metal migration are also common failures with incomplete WSF removal. If you have a crappy cleaning process, expect to see many failures in accelerated testing and in the field.
                      - Dr Seuss
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4957
                        • New Zealand
                        Oh really? Didn't know that. That might explain some things...
                        -David VanHorn
                        • delaware74b
                          • Apr 2009
                          • 628
                          I am using up the last of RadioShack's 'silver bearing' (62%-tin, 36%-lead, 2%-silver) solder I got a few years ago. I also have a 1-lb spool of Kester 60/40 that I purchased with my Weller soldering station last year.
                          Stupidity should be a crime, especially for drivers. I have NO patience for them.
                          • corrize
                            Best way to solder LVDS connector for beginner (and qfn) ?
                            by corrize
                            Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                            I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                            I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                            See the test :
                            https://youtu.be/bNAzC-EvqHs?t=1767
                            With hot air from bellow the board, that's...
                            03-09-2023, 02:57 AM
                          • myth77
                            UV solder mask - high temp resistent, recomendation?
                            by myth77
                            Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                            Is there any solder mask...
                            03-28-2022, 04:04 AM
                          • petemanuk
                            BGA solder balls not connecting - help pls
                            by petemanuk
                            So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                            I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                            I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                            11-16-2022, 05:21 AM
                          • acedogblast
                            by acedogblast
                            11-02-2024, 05:13 PM
                          • sircastor
                            Solder not reflowing - what am I doing wrong?
                            by sircastor
                            I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
                            For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
                            03-03-2024, 02:44 AM
