I have been hearing about stuff called flux. What is flux used for?
Also, what is tinning?
ASRock B550 PG Velocita
Ryzen 9 "Vermeer" 5900X
Arc A770 16 GB
eVGA Supernova G3 750W
Alienware AW3423DWF OLED
flux helps the solder flow. it is inside the core of most solders. you can also get a tin of it to spread on wires and contacts where you want the solder to flow. I dont consider it necessary for recapping.
tinning is when you add a bit of solder to the tip of the soldering iron before you start soldering. it is recommended.
In soldering of metals, flux serves a threefold purpose: it removes oxidation from the surfaces to be soldered, it seals out air thus preventing further oxidation, and by facilitating amalgamation improves wetting characteristics of the liquid solder.
lol i guess i should be doing the reading. i was 1/3 right.
Then when done soldering, how should I remove the flux?
Arc A770 16 GB
How about soldering paste? Is it flux or is it for tip tinning? How is it properly used?
If you read this thread, willawake has posted links that will answer your question. Buy tooling and practice. There are several threads here on soldering irons.
When any of us are new to a subject, we have homework at hand.
While we are on the subject of flux, what are ya'lls feelings towards liquid flux? Onboard the ship, and in my wiring mods I do, I've always used it, considering it so much more useful that the paste form.
as long as it is non corrosive its fine if you need it and clean it away afterwards.rosin=safe
zinc chloride=not good!
Definitely clean it. Some water-washable fluxes are pretty conductive.
PeteS in CA
i hate flux/paste. it will only flow the solder too much in my experiences..
days are so short when you actually do something..
