Soldering
  • RJARRRPCGP
    • Jul 2004
    • 6304
    Soldering
    I have been hearing about stuff called flux. What is flux used for?
    Also, what is tinning?
    ASRock B550 PG Velocita
    Ryzen 9 "Vermeer" 5900X
    Arc A770 16 GB
    eVGA Supernova G3 750W
    Alienware AW3423DWF OLED
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    Re: Soldering
    flux helps the solder flow. it is inside the core of most solders. you can also get a tin of it to spread on wires and contacts where you want the solder to flow. I dont consider it necessary for recapping.
    tinning is when you add a bit of solder to the tip of the soldering iron before you start soldering. it is recommended.
    you might want to read around the subject :
    Elecraft Builder Resources (Click on Soldering Tutorial)
    http://www.elecraft.com/Apps/K2info.html
    Apogee Kits Downloads (Click on ApogeeKits Free Illustrated Guide to Electronics Soldering)
    http://www.apogeekits.com/downloads.htm
    The Basic Electronics Soldering & Desoldering Guide
    http://www.epemag.wimborne.co.uk/solderfaq.htm
    • arneson
      • Sep 2005
      • 1267
      Re: Soldering
      Flux is a state of change.
      It holds the space time continume together, hence the Flux Capacitor, usually installed in a DeLarian.
      Jim
      • RJARRRPCGP
        • Jul 2004
        • 6304
        Re: Soldering
        I thought that flux gets rid of impurities.
        Arc A770 16 GB
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          Re: Soldering
          In soldering of metals, flux serves a threefold purpose: it removes oxidation from the surfaces to be soldered, it seals out air thus preventing further oxidation, and by facilitating amalgamation improves wetting characteristics of the liquid solder.
          lol i guess i should be doing the reading. i was 1/3 right.
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Re: Soldering
            Then when done soldering, how should I remove the flux?
            Arc A770 16 GB
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              Re: Soldering
              yes.some flux is corrosive.
              • gonzo0815
                • Feb 2006
                • 1600
                Re: Soldering
                Normaly elektronic flux should`t be corosive at all, but anyway, you could use no clean stuf, to be sure.
                • ngorge
                  • May 2006
                  • 5
                  Re: Soldering
                  How about soldering paste? Is it flux or is it for tip tinning? How is it properly used?
                  • Galvanized
                    • Mar 2006
                    • 468
                    Re: Soldering
                    If you read this thread, willawake has posted links that will answer your question. Buy tooling and practice. There are several threads here on soldering irons.
                    When any of us are new to a subject, we have homework at hand.
                    • Fullmetal Chocobo
                      • Mar 2006
                      • 11
                      Re: Soldering
                      While we are on the subject of flux, what are ya'lls feelings towards liquid flux? Onboard the ship, and in my wiring mods I do, I've always used it, considering it so much more useful that the paste form.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        Re: Soldering
                        as long as it is non corrosive its fine if you need it and clean it away afterwards.rosin=safe
                        zinc chloride=not good!
                        • PeteS in CA
                          • Aug 2005
                          • 3583
                          • USA, Unsure of Planet
                          Re: Soldering
                          Definitely clean it. Some water-washable fluxes are pretty conductive.
                          PeteS in CA
                          • yanz
                            • Nov 2004
                            • 910
                            Re: Soldering
                            i hate flux/paste. it will only flow the solder too much in my experiences..
                            • chth96
                              Is it good to use chemistronic flux off es835b for flux remover?
                              by chth96
                              I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                              Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                              11-17-2023, 07:25 AM
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                            • Ady2017
                              SMD fuse soldering advice please
                              by Ady2017
                              Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
                              11-07-2025, 12:03 PM
                            • piernov
                              NVidia bumpgate
                              by piernov
                              Just archiving everything related to bumpgate since most stuff has disappeared from Google. Maybe people will finally take the time to read some of it and stop shouting "reflow gpu" at every occasion but rather try to understand what the real issue is…
                              Interesting parts about the failure analysis are "Why Nvidia's chips are defective" and "Why Nvidia's duff chips are due to shoddy engineering"
                              May complete this post at a later date with more details.
                              Basically issue is a combination of thermal dissipation of the chip with hotspot,...
                              03-27-2021, 10:34 AM
                            • Azurain
                              Elitebook 840 G5 Bios Chip Soldering Question
                              by Azurain
                              I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                              Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                              04-14-2023, 06:58 PM
