Re: What an analog ESR meter will and won't do
Analog meters can't read the 0.10-0.01 ohms range accurately [+/- .01 ohms or so] and that is what is needed for modern low ESR work.
Those numbers might be on the meter face but if you are using the bottom or top 1/4 of the scale on analog test equipment then you aren't using the meter ranges properly.
The highest accuracy is in the middle of the scale.
Analog meters are better for a lot of things but low ESR isn't one of them.
At ohms that low it takes too much meter current to move the needle and still get an accurate reading.
I am retired, 40 years in the Electrical trade, and have always used an anolog triplet 630-A. It has served well for testing Caps, resistors and diodes. It is powered by two batteries, one 30 volt and one 1.5 volt.
All me crazy but I feel an anolog meter always tells the truth. The digital meter some times show untrue readings. This is my story and I am sticking to it!!Leave a comment:
I used a base drive transformer scavenged from an ATX supply. I'll have to look at it to tell you the pinout however... I used 1N5819 diodes in place of 1N4148. Also one of the 10 ohm resistors (doesn't matter which one) was replaced with a 1.8 ohm one to provide a lower impedance for the measurement signal. You can do better if you really make an effort to minimize series resistance of the secondary winding of the transformer, but it may not fit on a small core like an EE16 or EE19.
Other ways of generating a low impedance signal are valid too of course, but the transformer method has the advantage of being simple, and you can use a single dual opamp for the whole thing.
Thanks.Leave a comment:
@all: ther are no Fluke multimeters which can be used as ESR meter because they measure resistance by applying a DC current through resistor.
Earlier, when I compared the ESR meter with the Fluke, I was measuring a pure resistor out of circuit. On that kind of measurement, it does not matter which method you use, the result is the same. Then I've compared the values.Leave a comment:
If you're not feeling up to it, don't, but it might be a good resource.Leave a comment:
Other ways of generating a low impedance signal are valid too of course, but the transformer method has the advantage of being simple, and you can use a single dual opamp for the whole thing.Leave a comment:
I wonder how hard it would be to DIY an esr meter then.... a digital one would be a pain as it would take an analog to digital converter and then lcd display drivers in addition to the transformers and whatnot needed to go from 120VAC to what was needed, plus the circuity to measure resistance.
it would be epic though.
The hard part is doing it well. Input protection is really important on an actual tool. Accuracy, too.Leave a comment:
I'm sure you've all seen those analog ESR meters which use a microamp meter (or really, any meter with a needle, mine for example uses a cheap dB meter), and some of you may wonder whether they will be enough for finding bad caps that aren't bloated.
Short answer: Yes.
I have built this one: http://ludens.cl/Electron/esr/esr.html and with a few small modifications it can easily spot differences of 0.1 ohms, the other end of the scale being at roughly 15 ohms. This makes a good all-rounder, and it's suitable for checking high voltage capacitors as well, which generally have a few ohms ESR.
What this type of meter won't do is spot a cap that is low-ESR and not yet bad, just out of its tolerance. It does not have enough resolution for that (unless you've got your hands on a really big meter movement). If you work only on computer stuff with ultra low ESR caps, you're better off buying a digital ESR meter, but i bet 95% of capacitor problems can be diagnosed with one of those analog meters built from scrap parts...
Most of the non-commercial digital ESR meter designs i've seen so far are pretty dodgy, so if you really want a digital one, i'd say buy it. Or wait for me to design one.
Just use a low frequency signal generator (10-100 kHz) and a scope. Here is one reference: http://www.anatekcorp.com/ttg/tiptrick.htm#Scope%20ESR
I used this method in the 1980's when I was a high school student.
I have the Badcaps ESR Meter from MiLuElectronics in ?Romania?, and the ESR-micro V4.0 from www.radiodevices.ru which is sold in the US on the www.prc68.com website at the bottom of the products page (no relation to seller).
The version of the MiLu meter I have does not have any protection for charged caps other than the thin trace on the board may fry and save the electronics (comment on
that issue seen in tekscopes, tekscopes2, or hpagilent Yahoo group). I have simply been careful since I saw the warning. Newer units may incorporate one or two additional parts to fix this. Several designs available on the web have this protection. I have had it for about two years and it has worked well for me.
The ESR-micro displays the resistance and capacitance on the LCD. It has different beeps including a unique sound for a cap with ESR of over ~3. It will display "only" for
the C value if there is no capacitance. The measurement method is similar to the Bob Parker Blue ESR meters. I have had this one for two weeks and like it so far.
I started with a DIY ESR meter based on several schematics available on the web. My junk box didn't have exactly what anyone else had used... I coupled an LCD to
a dual op-amp design with an input protection circuit. Just calibrate it with a real resistor of known value.Last edited by jcotton; 09-08-2011, 11:32 AM.Leave a comment:
ESR meters are AC ohmmeters. They work by passing high frequency AC instead of DC thru the tested component. The idea is that a resistor will still be a resistor in AC, but for a capacitor (which cannot pass DC from one side to another, so it just charges up with it), you will instead see how much resistance there is when passing the AC signal - ie, the ESR.
it would be epic though.Leave a comment:
ESR meters are AC ohmmeters. They work by passing high frequency AC instead of DC thru the tested component. The idea is that a resistor will still be a resistor in AC, but for a capacitor (which cannot pass DC from one side to another, so it just charges up with it), you will instead see how much resistance there is when passing the AC signal - ie, the ESR.Leave a comment:
Me neither. How do they work?Leave a comment:
I haven't seen an AC ohmmeter. Does the Fluke 289 have the same function?Leave a comment:
Wait--there's a Fluke portable meter that does ESR?
I'm happy with my analog ESR meter, but a digital version would be handy at times. A open-source digital ESR meter that uses a standard two-line LCD display, has good input protection, and is based on an AVR would be great. Haven't found one of those yet, though.Leave a comment:
c'mon then, get a move on - I'm wanting to build my own, hopefully after somebody else (you?) has built and tested it first...Leave a comment:
I have another device that deals with caps to make first (shh... surprise), i just have to convince myself to start building it.Leave a comment:
If the input circuitry is well-separated from the microcontroller and the code well-commented, porting it to an AVR would be an interesting project for me. Not that I need another project, but still.Leave a comment:
by eccerr0rMost analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and... -
by jorpecHi
I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
I wonder how i can accomplish this so the meter would be precise at any temperature ?
Thnaks -
by budmUNI-T UT210D/210E Digital Clamp Meter AC/DC Current Voltage Multimeter Temp Tester.
Is it any good? Any body has one?
https://www.ebay.com/itm/UNI-T-UT210.../303564557647?
https://www.ebay.com/itm/UNI-T-UT210.../303570930240? -
by narfhi all,
first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
what i've found so far:
- the PSU does its job and supplies 12V to the mainboard via the connector.
- shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
- not far away, there's the first cap with a resistance of 0.7 ohms.... -
by HalfchipIt's an MS8301A made by OKE. bought it at Home Depot....
- Loading...
