Hey guys i want to get a new multimeter cus the one i have is giving me issues (mastech mas830L) and since i have no idea what a good one would be i was wondering if someone could give me some advice on which one to buy. I mostly like to tinker with tvs (LCD/Plasmas) and various computer components.
new multimeter
Re: new multimeter
I recently got an Agilent 1242B, very happy with it and its about the best i could find to my specs and budget. However as ipman said, give us more details on what budget you have what you are going to use it for, what kind of circuits are you gonna measure. What kind of measurements do you do, like do you need to measure frequency and stuff, or is the standard volts and ohms enough.Comment
Re: new multimeter
yes.
ESR is usually a separate meter, some will also do capatence.
if you need all things, I'd find an esr meter that does the ESR and capatence and a digital multimeter for the rest.
If you ever get into power supplies, an anlalog meter and perhaps even a home brew tester (I have pics of mine somewhere) are helpful.sigpic
(Insert witty quote here)Comment
Re: new multimeter
Check out these videos comparing meters in the $50 and $100 dollar price range:
$50.00 multimeter shootout:
http://www.youtube.com/watch?v=ZoeUgMFLyAw
$100.00 multimeter shootout:
http://www.youtube.com/watch?v=3-_dUB8vy8U
Make sure you get a True RMS meter it's a function you'd rather have and not need than need and not have.Last edited by Krankshaft; 07-16-2011, 04:47 PM.Elements of the past and the future combining to make something not quite as good as either.Comment
Re: new multimeter
Guys,
I am way over the top with DMM's.
For normal stuff I use a Fluke 77III meter.
For more advanced stuff I have had a fluke 8060A for years.
For off the wall stuff I have this thing. Got it cheap on Ebay
http://www.flickr.com/photos/9010884...n/photostream/
In the one volt range it can see all the way down to one microvolt (1x10-6 volt). I can watch the chemical decay in a D cell with it.
A very handy tool for once in a while work.
The four wire ohms feature don't hurt either.
For casual repair duty, the Fluke 77 is very hard to beat.
The other two take some doing to use well.
Where did all this come from, ages ago I used to repair and calibrate instruments. HP745 AC calibrator and 746 amplifier. Fluke 335 DC standards, all kinds of wacked out stuff.
Most people don't need nor want that level of detail, yet it comes in handy at times.
Jack Crow"You are, what you do, when it counts"
The Masso
"Gravity, the quickest way down"
Mayor John Almafi
"You ever drop an egg, and on the floor you see it break?
You go and get a mop so you can clean up your mistake.
But did you ever stop to ponder why we know it's true?
If you drop a broken egg you will not get an egg that's new?"
MC HawkingComment
Re: new multimeter
Haha Jack so I'm not the only one who went nuts and bought a Fluke
? I've got an 87-5.
Alex on my Fluke I've got a Min / Max / Average and a hold function I love both of them as well
A great example of this functions usefulness.
I had to check a magnetic position sensor on a car a few days ago. They only generate a voltage with the engine cranking and I couldn't crank and check the meter under the car at the same time.
So I hooked the meter up to it on the AC scale activated the hold function and cranked the engine for a few seconds. The meter held the value and I was able check the sensor output voltage.
Turns out the TDC sensor was shot and the ECU didn't throw a code for it. It's the little things like not having to leave the work area and haul someone outside to help that makes these extra meter functions so valuable.Last edited by Krankshaft; 07-17-2011, 10:08 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
Re: new multimeter
KS
Your so right.
Like anything else in life, owning tools is not the same as being good with them.
J"You are, what you do, when it counts"
The Masso
Mayor John Almafi
MC HawkingComment
Re: new multimeter
@Jack Crow: your tools are far from being cheap. They are maybe ten times more than the user started this tread's budget.
I have a Fluke 189. Nice meter, but much more expensive than requested. A 179 is my backup meter, also too much for his budget.
Sure, the most expensive meters are feature-rich, but that's what the advanced users expect.Comment
Re: new multimeter
I put some links a few posts up the videos review meters in the 50 and 100 dollar ranges.
If you can't afford that save up. If you spend any less than 50 dollars you're getting a horribly designed (partially current unfused if it has a 10 amp range) possibly dangerous Chinese piece of crap.Last edited by Krankshaft; 07-18-2011, 04:50 AM.Elements of the past and the future combining to make something not quite as good as either.Comment
by dj8452000I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
by trex66My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...3 Photos
by Sofian75I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
I fixed some of them and some I ve made things worse by blowing components.
Every time while taking measurements with my multimeter.
Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
So my question is are there things I should not do with my multimeter?
Or measurements I should do only with the charger and battery unplugged?... -
by max_smartHi all,
First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...3 Photos -
by DrDosI'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
Channel: General Capacitor Questions & Issues
- Loading...
