new multimeter
  • testas86
    • May 2010
    • 140
    new multimeter
    Hey guys i want to get a new multimeter cus the one i have is giving me issues (mastech mas830L) and since i have no idea what a good one would be i was wondering if someone could give me some advice on which one to buy. I mostly like to tinker with tvs (LCD/Plasmas) and various computer components.
  • ipman
    • Jul 2011
    • 159
    Re: new multimeter
    It depends on your budget.
    Best one are from Fluke, Agilent, Gossen-Metrawatt, etc. But they do cost several hundreds dollars/euros.
    Narrow your search and maybe we can work something out.
    • digge
      • Apr 2006
      • 296
      Re: new multimeter
      I recently got an Agilent 1242B, very happy with it and its about the best i could find to my specs and budget. However as ipman said, give us more details on what budget you have what you are going to use it for, what kind of circuits are you gonna measure. What kind of measurements do you do, like do you need to measure frequency and stuff, or is the standard volts and ohms enough.
      • ipman
        • Jul 2011
        • 159
        Re: new multimeter
        Also Uni-T, known also as Uni-Trend, sell nice meters if you are taking in account value.
        But don't expect quality like those hundred dollar ones.
        • testas86
          • May 2010
          • 140
          Re: new multimeter
          well i would like to spend the most 100-200 and i just try to fix tvs and computer components. so ill need to test volts, ohms, and capacitors if possible
          • ipman
            • Jul 2011
            • 159
            Re: new multimeter
            You can get a used Fluke on e-bay for that amount.
            Will measure capacity, but not ESR.
            • ratdude747
              Black Sheep
              • Nov 2008
              • 17136
              Re: new multimeter
              yes.
              ESR is usually a separate meter, some will also do capatence.
              if you need all things, I'd find an esr meter that does the ESR and capatence and a digital multimeter for the rest.
              If you ever get into power supplies, an anlalog meter and perhaps even a home brew tester (I have pics of mine somewhere) are helpful.
              sigpic
              (Insert witty quote here)
              • testas86
                • May 2010
                • 140
                Re: new multimeter
                ok so i guess ill invest in a multimeter that can do capacitance as well. do you h ave any model suggestions to look up on ebay?
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Re: new multimeter
                  Check out these videos comparing meters in the $50 and $100 dollar price range:
                  $50.00 multimeter shootout:
                  http://www.youtube.com/watch?v=ZoeUgMFLyAw
                  $100.00 multimeter shootout:
                  http://www.youtube.com/watch?v=3-_dUB8vy8U
                  Make sure you get a True RMS meter it's a function you'd rather have and not need than need and not have.
                  • alexanna
                    • Mar 2010
                    • 1346
                    Re: new multimeter
                    A feature on my DMM that I really like is the Min/Max record.
                    • Jack Crow
                      It's a CLASOB!
                      • May 2008
                      • 823
                      Re: new multimeter
                      Guys,
                      I am way over the top with DMM's.
                      For normal stuff I use a Fluke 77III meter.
                      For more advanced stuff I have had a fluke 8060A for years.
                      For off the wall stuff I have this thing. Got it cheap on Ebay
                      http://www.flickr.com/photos/9010884...n/photostream/
                      In the one volt range it can see all the way down to one microvolt (1x10-6 volt). I can watch the chemical decay in a D cell with it.
                      A very handy tool for once in a while work.
                      The four wire ohms feature don't hurt either.
                      For casual repair duty, the Fluke 77 is very hard to beat.
                      The other two take some doing to use well.
                      Where did all this come from, ages ago I used to repair and calibrate instruments. HP745 AC calibrator and 746 amplifier. Fluke 335 DC standards, all kinds of wacked out stuff.
                      Most people don't need nor want that level of detail, yet it comes in handy at times.
                      Jack Crow
                      "You are, what you do, when it counts"
                      The Masso
                      "Gravity, the quickest way down"
                      Mayor John Almafi
                      "You ever drop an egg, and on the floor you see it break?
                      You go and get a mop so you can clean up your mistake.
                      But did you ever stop to ponder why we know it's true?
                      If you drop a broken egg you will not get an egg that's new?"
                      MC Hawking
                      • Krankshaft
                        • Jan 2007
                        • 2328
                        Re: new multimeter
                        Haha Jack so I'm not the only one who went nuts and bought a Fluke ? I've got an 87-5.
                        Alex on my Fluke I've got a Min / Max / Average and a hold function I love both of them as well .
                        A great example of this functions usefulness.
                        I had to check a magnetic position sensor on a car a few days ago. They only generate a voltage with the engine cranking and I couldn't crank and check the meter under the car at the same time.
                        So I hooked the meter up to it on the AC scale activated the hold function and cranked the engine for a few seconds. The meter held the value and I was able check the sensor output voltage.
                        Turns out the TDC sensor was shot and the ECU didn't throw a code for it. It's the little things like not having to leave the work area and haul someone outside to help that makes these extra meter functions so valuable.
                        • Jack Crow
                          It's a CLASOB!
                          • May 2008
                          • 823
                          Re: new multimeter
                          KS
                          Your so right.
                          Like anything else in life, owning tools is not the same as being good with them.
                          J
                          The Masso
                          Mayor John Almafi
                          MC Hawking
                          • ipman
                            • Jul 2011
                            • 159
                            Re: new multimeter
                            @Jack Crow: your tools are far from being cheap. They are maybe ten times more than the user started this tread's budget.
                            I have a Fluke 189. Nice meter, but much more expensive than requested. A 179 is my backup meter, also too much for his budget.
                            Sure, the most expensive meters are feature-rich, but that's what the advanced users expect.
                            • Krankshaft
                              • Jan 2007
                              • 2328
                              Re: new multimeter
                              I put some links a few posts up the videos review meters in the 50 and 100 dollar ranges.
                              If you can't afford that save up. If you spend any less than 50 dollars you're getting a horribly designed (partially current unfused if it has a 10 amp range) possibly dangerous Chinese piece of crap.
                              • dj8452000
                                How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                by dj8452000
                                I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                02-18-2025, 08:28 AM
                              • trex66
                                Craftsman 82345 Multimeter broke!
                                by trex66
                                My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                03-04-2025, 04:26 PM
                              • Sofian75
                                Things not to do with a multimeter?
                                by Sofian75
                                I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                                I fixed some of them and some I ve made things worse by blowing components.
                                Every time while taking measurements with my multimeter.
                                Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                                So my question is are there things I should not do with my multimeter?
                                Or measurements I should do only with the charger and battery unplugged?...
                                06-27-2024, 05:13 AM
                              • max_smart
                                T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                                by max_smart
                                First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                                Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                                06-01-2024, 03:27 PM
                              • DrDos
                                Wierd reading on my multimeter
                                by DrDos
                                I'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
                                09-12-2025, 04:44 PM
