Wierd reading on my multimeter
  • DrDos
    • Aug 2025
    • 93
    • U.S.
    I'm trying to read a capacito 2200uF on my multimeter. It keeps coming up 2,183 am I to assume that means 2 thousand 183? I expected it to be 2183.00? Thanks for the help.
    • 31260
    multimeters wont give the accuracy you expected, so yes - it's 2183uf
    • m1ch43lzm
      • Mar 2019
      • 969
      • Peru
      If your multimeter says 2.183 mF (milli farad, 10^-3), then technically it's correct, just a different metric (SI) prefix
      But sometimes capacitor manufacturers prefer to label it as 2200uF (micro farad, 10^-6) instead of 2.2mF, bigger number sells I guess
      Another example: 100nF (nano farad, 10^-9) or 0.1uF cap, same thing
      • DrDos
        • Aug 2025
        • 93
        • U.S.
        I get it, makes sense thanks to the both of you, I really appreciate the help. Cheers!
        • Agent24
          I see dead caps
          • Oct 2007
          • 5084
          • New Zealand
          Yeah you have to watch some meters, Uni-T ones often like displaying values in milli-farad when it could use micro-farad, just to be confusing.
          -David VanHorn
          • DrDos
            • Aug 2025
            • 93
            • U.S.
            Yes, I'm learning.
            • SuperAman
              PS5 HDMI port diode reading?
              by SuperAman
              I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
              02-03-2024, 10:16 PM
            • trex66
              Craftsman 82345 Multimeter broke!
              by trex66
              My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
              03-04-2025, 04:26 PM
            • Takeatry
              Yet another Samsung QLED Boot Loop
              by Takeatry
              Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
              10-04-2024, 02:57 PM
            • Sofian75
              Things not to do with a multimeter?
              by Sofian75
              I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
              I fixed some of them and some I ve made things worse by blowing components.
              Every time while taking measurements with my multimeter.
              Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
              So my question is are there things I should not do with my multimeter?
              Or measurements I should do only with the charger and battery unplugged?...
              06-27-2024, 05:13 AM
            • max_smart
              T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
              by max_smart
              First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
              Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
              06-01-2024, 03:27 PM
