Hot Air Gun vs Oven Reflow
  • bigbeark
    • Jan 2010
    • 661
    I read with interest Unique's oven reflow methodology and noted the need to remove the electrolytic caps before "baking".
    Can you avoid this step using the Heat Gun method? How do you tell when the chipset reflow is completed?
    I've got a stack of boards using Nvidia 7050 chipset, some don't power on at all, some spin the fans but no POST.
    Thanks, Barry
  • digge
    • Apr 2006
    • 296
    Re: Hot Air Gun vs Oven Reflow
    The answer is tricky to answer, i would say it depends on how it looks on the board. To some extent you can protect other components with tinfoil or similar things to lead the heat away from anything you're not working on. That is not a 100% solution for everything though, and its not without risks.
    So if the board you're working on is not anything important i would say go for it, however if its something expensive or something you're repairing for a third party maybe not risk it.
    How you can tell when its done, well when its reached the right temperature for the solder used. That can be a tricky one to know and measure.
    • jetadm123
      • 2169
      If you go on YouTube, you can watch various videos of how people "reflow" their boards. Some folks use the oven method, others a heat gun and some a small butane torch. Unfortnately, you only hear from the people where these methods worked, but not so much from those where it failed. So the success rate may be skewed a bit. Even if these methods work and you install a heatsink method to draw the heat away from the chip, this "fix" still might wind up being short term. Like digge says, if these boards are for yourself, then go for it. If they're being repaired for customers or a third party, then it's not worth the risk.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        You have more chances to screw up with the hot air gun rather than using the oven. This is a 100% honest comment from someone who has used both methods.
        As for it being temporary... Reballed boards fail too if they aren't done properly. Factory made boards fail too if they aren't done properly (that's why reflows and reballs even exist, duh). Yet, i know people who've had laptops with 8400GS for over 4 years, and they still work just fine to this day without ever being serviced. If adequate thermal transfer is achieved, the board will become obsolete way before it fails.
        Flux + oven is the best way to go if you don't want to shell out the big dough for an infrared station.
        A working TV? How boring!
        • Uranium-235
          Comrade Glimmer
          • Aug 2007
          • 5042
          • US
          i've been thinking about one of these
          http://www.frys.com/product/6389401?...H:MAIN_RSLT_PG
          or better
          http://www.frys.com/product/6389431?...H:MAIN_RSLT_PG
          i've seen youtube videos with similar ones, they take the chip off, clean, reball with good stuff and put it back on with this simple equipment. but it bet it takes some skill without a magnifier
          • jsog
            • Feb 2011
            • 220
            A scrap motherboard with a BGA chip can be used to get an idea of how long it takes to get the solder liquid with a heat gun. The chips won't just come loose because the solder's surface tension holds them, they have to be pushed.
            • severach
              • Aug 2007
              • 1055
              Both. A hot air gun won't take a large BGA chip off a room temperature board without destroying something. I can only get them off in a timely fashion if I set the temperature to 450*C where the chips will be damaged. Down around 310*C all day isn't long enough.
              Proper BGA equipment has a board heater along with an infrared chip heater. Better equipment has multiple board heaters because to do it right you must heat the entire board to a temperature safe for all components, heat the area being worked on to a higher temperature, then heat the chip to melt temperature. Then there's that pesky temperature profile.
              A hand held heat gun is great for a lot of stuff but against big BGA chips it will break the board, the chip, or you. I cheat on a lot of small chips but I'm leaving BGA alone until I have at least an Aoyue 732 and a reball station.
              sig files are for morons
              • Uranium-235
                Comrade Glimmer
                • Aug 2007
                • 5042
                • US
                do you have 1 1/2 grand to shell out?
                this is why I think those smaller aoyue stations might do the trick. theres a lot of youtube videos about reballing with those
                some don't even use stencils or balls. one used a find-point solder tip and filled in each hole with solder on the chip and the board. sure it took a long damn time, but it worked great
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5037
                  • New Zealand
                  That Aoyue 732 looks pretty nice... but do you trust the quality of it that much to actually buy one?
                  -David VanHorn
                  • kiddznet
                    • Jul 2010
                    • 176
                    And that ain't very long for me Im using a 2 speed hobby gun that I have built a nozzle on. Same sorta gun that is used to heat shrink plastic covering on model planes. Knocks off them little bios chips in about a minute or less.
                    939 DualCore AMD Opteron, 1800 MHz (9 x 200)
                    Abit AN8 / Fatal1ty AN8 SLI Series
                    3072 MB (PC3200 DDR SDRAM)
                    ATI Radeon HD 4300/4500 Series (1024 MB
                    Lian LI Aluminium mesh case
                    • Agent24
                      I see dead caps
                      • Oct 2007
                      • 5037
                      • New Zealand
                      But BIOS chips aren't BGA...
                      -David VanHorn
                      • Uranium-235
                        Comrade Glimmer
                        • Aug 2007
                        • 5042
                        • US
                        actually being sma makes them easier to knock off cause the leads are exposed to the hot air
                        • kiddznet
                          • Jul 2010
                          • 176
                          BGA I won't go there. There be madness and frustration.
                          • Uranium-235
                            Comrade Glimmer
                            • Aug 2007
                            • 5042
                            • US
                            yes, but how many computer technicians can do this kind of work? general nerdy techs will look up to you as a god, mwahahah
                            not only that, but you can make moneah
                            • inuyasha.rules
                              • May 2011
                              • 43
                              I tried using an old flat electric griddle once to preheat the board and a heatgun to melt the solder and pull the chip with good luck. Unfortunately when the chip failed it toasted some traces under it so I can't say if it would work good for reflowing or replacement, etc. YMMV
                              • bpjl
                                SEF 551.10 - Error starting the reflow oven.
                                by bpjl
                                When starting the SEF 551.10 reflow oven, the following problem occurs:
                                It seems to me that this is related to corrupted software. Does anyone have files that can fix this device? Or maybe someone uses such an oven and is able to make a sector copy of the memory card located in the computer controlling this oven?
                                PS.: Of course, appropriate emails for help have been sent to the manufacturer and distributor in my country. No response yet, but I don't expect much. It's a fairly old device and from what I know, it's no longer...
                                10-17-2024, 06:30 AM
                              • acedogblast
                                by acedogblast
                                11-02-2024, 05:13 PM
                              • Olvin1
                                Acer nitro 5 an517-52 reflow/rebal CPU
                                by Olvin1
                                I’m kindly asking for help and advice regarding a reflow procedure for my laptop — Acer Nitro 5 AN517-52, which is equipped with an Intel Core i7-10750H processor.
                                I own an ACHI IR 6500 infrared rework station and would greatly appreciate:
                                • A detailed temperature profile for reflowing this specific CPU
                                • Step-by-step guidance for a safe and effective reflow process
                                • Tips on what to watch out for during the procedure
                                If the reflow doesn’t resolve the issue, I’m also considering BGA reballing of...
                                08-01-2025, 01:59 PM
                              • tony359
                                Reflow equipment
                                by tony359
                                Hello all,
                                I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
                                I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
                                Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
                                12-25-2021, 01:29 PM
                              • Fsufan1391
                                LG Oven model LREL6325F
                                by Fsufan1391
                                Hello everyone my oven is less than 2 years old and all of a sudden recently when i run the oven for 15 minutes or so and i am done with it and shut it off. after about 10 minutes it starts chiming and randomly putting it in different modes like the touch screen is being touched but no one is around it. I have tried to reset it by unplugging it multiple times and no luck. I took it apart to see the main board and everything looks fine. I am wondering if i should replace the main board or if its in the control panel. the touch screen is very responsive and works like it should. its only acting...
                                04-23-2025, 05:42 AM
