soldering station
  • sam67
    • 256
    soldering station
    Hi anyone reckon this will be ok for use on motherboards
    http://cgi.ebay.co.uk/50w-Soldering-...item45ed09e925
    Not a bad price ..I do have a soldering iron kit in a mouldered case but thought this might be worth a shot.
    Cheers
  • i4004
    • Oct 2006
    • 2029
    Re: soldering station
    i don't see a brand, and i wouldn't buy no-name soldering station...
    also, the price seems too cheap to be of any decent quality(that ties well with the no-brand problem..heh)
    • sam67
      • 256
      Cheers was thinking the same thats why i thought of posting it on here before i took the plunge, any good recommendations for one that ain't to pricey for a beginner to be going on with.
      sam
      • Bobdee
        • Jun 2008
        • 461
        I have that exact station (N78AR) unbranded yes but it used to retail from MAPLIN electronics uk for the price of £30 now £10
        http://www.maplin.co.uk/module.aspx?...C=SO&U=Strat15
        I have had no problems with mine (It was secondhand when I aquired it about 18 mths ago)
        It has repaired many Monitors, but only a few caps on a few M/boards without any problems
        The solder pump is maplins as well, I found it to powerful a suction bought another from a cheap shop that does the job better (with weaker suction)
        • i4004
          • Oct 2006
          • 2029
          discussed many times already, for example on first page of this subforum
          https://www.badcaps.net/forum/showthread.php?t=7863
          do a search on names mentioned there, also search for "goot" and you'll find plenty data.
          • Harvey
            • Apr 2007
            • 264
            They're not bad a basic solder station, but, if its the same as the one my mate had, its not true thermostatic. Its just a high-ish powered soldering iron with what is in effect a lamp dimmer connected to it.
            It works well enough, but it can be a bit of trial an error to get the settings right.
            • sam67
              • 256
              Have noticed that maplins now have this back instock http://www.maplin.co.uk/module.aspx?...FaBb4wodsznuJg Also you can buy 3 extra tips with it ..It also says the tip is grounded.will it be ok to use on motherboard caps and psu..usually maplin stuff ain't to bad.
              • willawake
                Super Modulator
                • Nov 2003
                • 8457
                • Greece
                need the extra tips cos 0.5mm is too small to hold good heat.
                no other comment, i dont like cheap tools
                • sam67
                  • 256
                  Hi thanks for takin a look ...I was also looking at this on ebay but i would need a better tip as this is to fine http://cgi.ebay.co.uk/CSI950-Solderi...item4a9a2f1116 It's hard trying to get the right tools ..some say use a normal iron and some say use a station..even some good tutorials on the web show using just a cheap soldering iron ..it's not like i will be using it day in day out..Guess i'll have to make a decision on an iron or station..
                  • i4004
                    • Oct 2006
                    • 2029
                    station and 3 bits for 15pounds?
                    i must admit i would take it and think "what if?" later, if i was displeased with it...
                    you probably get some warranty as it's new...dunno about if they would rma it just if you're displeased with it(?)
                    • willawake
                      Super Modulator
                      • Nov 2003
                      • 8457
                      • Greece
                      i like this stuff
                      http://www.dancap.co.uk/soldering/soldering.htm
                      http://www.greenwood-electronics.co....ngstations.asp
                      imho its good to have a soldering station so you can switch to 450oC for removal of capacitors then back to 350oC for nice soldering. doesnt have to be digital.
                      For wattage i would want about 60w.
                      For tip i would want 2mm chisel.
                      can use corded irons as long as they meet those last 2 specs.
                      heres another goot http://www.canford.co.uk/Products/55...SOLDERING-IRON
                      expensive though. i would probably go for the hakko 936 at that price.
                      • sam67
                        • 256
                        Might just get this for a test to see what it's like as i will be trying it on a test pc that i wanna recap ( it will either work or not lol) ..15 quid aint bad just to try it out ..i already have a 30w iron and 100w gun ..the 30 w has been ok on stuff that i have soldered and the 50w station is worth a shot for a noob like me he he..
                        willawake i like those links you have posted and have book marked them ..I can always go for a better model once i have had a few test runs so to speak..
                        • i4004
                          • Oct 2006
                          • 2029
                          willa's stuff is too expensive for me too...
                          between such things and this cheapo lays solomon stations that would be perfectly adequate, afaik.
                          http://soldering.com.tw/p1_all.html
                          but again, for a rookie that won't be using it very much anyway cheapo is a good beginning too...
                          • sam67
                            • 256
                            Thanks i4004 will take a look..
                            • Harvey
                              • Apr 2007
                              • 264
                              http://cgi.ebay.co.uk/Temperature-Co...item2c4e169fcc is a decent station for the price - I've got one that I brought at 'backup' when they were on offer and its perfectly OK for doing motherboards and anything that isn't too small like SMD caps as the tips aren't very fine.
                                • 31013
                                do not touch the £10 maplin iron.
                                it's a scam - i got one once.
                                it's "variable temperature", NOT "temperature controlled"
                                it's just a 40w(ish) mains iron connected to a dimmer unit designed for lighting inside the base.
                                then they stuck a lump of lead in it to make it feel like it had a transformer!!!!!!
                                i just use the base as a stand now for my xytronics iron.
                                • sam67
                                  • 256
                                  Hi guys ,
                                  Was thinking of buying either this http://cgi.ebay.co.uk/BK-2000-Premiu...item3357849b63 soldering station or this http://cgi.ebay.co.uk/Digital-Solder...item4a9d61d8e1
                                  Have been looking for a while anyone have any tips as to whether these will be ok for cap replacement and some small pcb work.
                                  Just can't make my mind up but i like either of these so any good points and bad points.
                                  Cheers
                                    • 31013
                                    first one says it's a 35w iron - that seems very low.
                                    second one dont say, but the iron looks very small and unusual - good luck with spare bits!
                                    i think your gonna need a 60w iron.
                                    what's your budget?
                                    • sam67
                                      • 256
                                      what's your budget?
                                      Hi stj about £70-75 at the moment as i have been buying stuff i need to get me going.
                                      Cheers
                                      sam67
                                        • 31013
                                        i'd recommend a xytronics unit,
                                        one of these 2.
                                        http://www.rapidonline.com/Tools-Fas...-station/80584
                                        http://www.rapidonline.com/Tools-Fas...-station/72316
                                        but shop around because i'v seen them cheaper.
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • caprider
                                          Recommendations of quality soldering station and (separate) hot air station
                                          by caprider
                                          Hey,
                                          I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                                          I now have a TS100 and some soldering irons and looking for some better tools.
                                          1. Soldering station, budget around 200-240€
                                          JBC BT-2BWA seems to be a good product in the budget.
                                          2. Hot air station, budget around 200€
                                          Up to now I've found ATTEN ST-862D to be a good option....
                                          01-15-2022, 02:05 AM
                                        • Peter_1402
                                          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                          by Peter_1402
                                          Hi Everyone,
                                          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                          1. Soldering iron works great
                                          2. There is a burnt mark on the hot air gun handle.
                                          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                          Reed switch tested ok with a magnet.
                                          From the above test, I can conclude...
                                          07-12-2025, 11:50 AM
                                        • deep000
                                          Looking for a budget hot air soldering station for hobby use
                                          by deep000
                                          I'm looking to get on Aliexpress a hot air soldering station for hobby use, nothing too fancy, just something "reliable" and budget-friendly.
                                          Any recommendations for a "good" cheap one that gets the job done?
                                          Thanks in advance
                                          04-25-2025, 02:29 AM
                                        • nbdy
                                          QUICKO soldering station
                                          by nbdy
                                          HI,
                                          Have a QUICKO soldering station with no numbers for the model ... (think it's a KSGER or similar copy)
                                          All worked nice, till some day it heats the iron till it was RED (HOT) ...
                                          Turned it off, and tryed today again, and all the same, even with a second iron ...
                                          The display shows that the iron is not connected, like not inserted in the handle ...
                                          The second thing is that it has 6 pins connector and can't find a handle that is similar for my station ...
                                          Has someone some advice what to do, where to look, even how to...
                                          01-07-2024, 05:44 PM
