QUICKO soldering station
  • nbdy
    • Aug 2015
    • 162
    • Croatia
    HI,
    Have a QUICKO soldering station with no numbers for the model ... (think it's a KSGER or similar copy)
    All worked nice, till some day it heats the iron till it was RED (HOT) ...
    Turned it off, and tryed today again, and all the same, even with a second iron ...
    The display shows that the iron is not connected, like not inserted in the handle ...
    The second thing is that it has 6 pins connector and can't find a handle that is similar for my station ...
    Has someone some advice what to do, where to look, even how to change the connector to fit a 5 pin or 4 pin handle ???
    THX
    • 31262
    probably the mosfet is shorted
    btw, quicko arent ksger clones
    found this:
    https://github.com/deividAlfa/stm32_.../BOARDS/Quicko
    • nbdy
      • Aug 2015
      • 162
      • Croatia
      Yes, I think that I updated the firmware with this, it was a time ago, a long time ago ....
      Will recheck the mosfet, thx
      EDIT :
      Now seen the pics on git, yes that is the station ...
      EDIT 2 :
      If I see, I can remove the middle pin from the 6 pin connector to remake it in 5 pin ???
        • 31262
        why?
        if your going to change stuff then use the connector with the most pins - for future expansion.
        i have seen people add a "boost" button to some of these stations.
        • nbdy
          • Aug 2015
          • 162
          • Croatia
          That is what I tought about, the 5 pin handle can be found everywhere ...
            • 31262
            mine has a 4pin,
            but anyway, they may all use 5pin connectors but it doesnt mean the pinout will always be the same
            • nbdy
              • Aug 2015
              • 162
              • Croatia
              I understand, but even if I can't find a 6 pin handle, then also I can't change the pinout :-)
              But 99% of the handles have the same pinout.
              • nbdy
                • Aug 2015
                • 162
                • Croatia
                Can someone help me with this controler ???
                Click image for larger version  Name:	KSGER-T12-Temperature-Controller-V2-3-Digital-DIY-Kits-STC-OLED-1-8-Inch-TFT-LCD.webp Views:	0 Size:	53.1 KB ID:	3216851
                Didn't manage to find out the right pinout for the handle ...
                Can someone help me connect the handle ???
                • redwire
                  • Dec 2010
                  • 3912
                  What handle do you have?
                  You can see the GX12-5 connector pins:
                  T+ heater(+)
                  T- heater(-)
                  S+ shake switch
                  N+ cold-junction compensation thermistor
                  C common (handle ground)
                  There are two 0R jumpers for either JBC or T12 handle/element.
                  I don't see this KSGER STC-V2.3 for sale. Where did you buy it from?
                  • nbdy
                    • Aug 2015
                    • 162
                    • Croatia
                    Aliexpress ...
                    https://www.aliexpress.com/item/1005...Cquery_from%3A
                    Looked at the picture and hoped that this will fit into my old case, but the measures are different ....
                    And then no manual, no soldering info ...
                    BOard, g12-5, diode, and some other parts ... but no connectiuon guide ...
                    THX for info
                    I have an 907 to t12 handle, and t-12 handle ...
                    https://www.aliexpress.com/item/4000...377218022wnlfb
                    t-12 handle works ... hmmm ,werry strange ... last time it would not work ....
                    now the 907 to t-12 the handle heats up, but the switch don't work, and the "ambient" temp is not shown on display ....
                    • nbdy
                      • Aug 2015
                      • 162
                      • Croatia
                      Click image for larger version  Name:	S0bcfda52c05a46bc802998a9b76c2cbaA.webp Views:	0 Size:	14.9 KB ID:	3217362
                      This one, how to connect on that board ???
                        07-01-2024, 06:34 AM
                      • Peter_1402
                        Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                        by Peter_1402
                        Hi Everyone,
                        I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                        1. Soldering iron works great
                        2. There is a burnt mark on the hot air gun handle.
                        I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                        Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                        Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                        Reed switch tested ok with a magnet.
                        From the above test, I can conclude...
                        07-12-2025, 11:50 AM
                      • caprider
                        Recommendations of quality soldering station and (separate) hot air station
                        by caprider
                        Hey,
                        I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                        I now have a TS100 and some soldering irons and looking for some better tools.
                        1. Soldering station, budget around 200-240€
                        JBC BT-2BWA seems to be a good product in the budget.
                        2. Hot air station, budget around 200€
                        Up to now I've found ATTEN ST-862D to be a good option....
                        01-15-2022, 02:05 AM
                      • rmjimenez455@gmail.com
                        Sumsour station 8586D error H-E
                        by rmjimenez455@gmail.com
                        Hello everyone, next I have the following problem with the Sumsour 8586D 110v dual station I bought it a year ago and it worked wonderfully, now it presents the H-E error on the soldering iron side, the hot air side works correctly..... I disassembled the soldering iron head because the manual tells me that this error is due to ceramic resistance problems, in effect, I measured it and it is open, I bought a new one that is working verified in a soldering iron and nothing.... The same error continues, I proceeded to open the station and check visually, I found a totally damaged 1R00 surface mount...
                        09-07-2024, 09:33 AM
                      • deep000
                        Looking for a budget hot air soldering station for hobby use
                        by deep000
                        I'm looking to get on Aliexpress a hot air soldering station for hobby use, nothing too fancy, just something "reliable" and budget-friendly.
                        Any recommendations for a "good" cheap one that gets the job done?
                        Thanks in advance
                        04-25-2025, 02:29 AM
