Hello,Ersa,Metcal or Hakko?.
  • deckart
    • Sep 2009
    • 67
    My first post so be gentle!.I have been an avid reader of this forum for ages,it's informative,non-patronising and genuinely helpful.I have been recapping Imac G5 for the past year or so using middle ground equipment but I am now in the position to upgrade all my equipment.The topic title is what I'm interested in.Any thoughts on the desoldering/soldering ability with preferences and especially experience with any of these would be greatly appreciated!.
    I live in the UK and have accounts with RS and Farnell if that helps.
    Thanks,
    deckart
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Re: Hello,Ersa,Metcal or Hakko?.
    Hi deckart.
    Welcome to the Forum!
    I have experience with both the Hakko 808 desoldering gun and the Hakko 936 soldering station. (as well as a multitude of cheaper tools like Weller, Velleman, etc..)
    For desoldering, the 808 does very well and is probably the least expensive pump-style pro-quality desoldering tool. It will happily suck nearly all of the solder out of just about anything including multi-layer mainboards. I wrote a review on it here:
    https://www.badcaps.net/forum/showpo...75&postcount=7
    The 936 soldering station is another great Hakko tool. I haven't used this as much yet but so far it's great. It has much better heat recovery than my old Velleman cheapie. Actually, it hasn't had to "recover" yet!
    One of the great things about Hakko is that replacement parts are available. Even most of the teenie-tiny ones.
    So, my vote is for Hakko.
    Have Fun,
    Keri
    The local Mac User
    The More You Learn The Less You Know!
    • Krankshaft
      • Jan 2007
      • 2328
      Depends on how much you're willing to spend.
      If you're looking for a temperature regulated soldering station I'd second Hakko.
      Once you've used one you won't want to use anything else. That's how it was with me anyways.
      The 936 (50 watts) is a great station you can usually find it for 80 bucks shipped. It's an all around workhorse for not much money.
      If you want to go digital the Hakko FX-951 (70 Watts) all the way unfortunately it will set you back about 200 bucks plus tips which are not included at around 9-15 bucks each (they include the heating element for hot swapping).
      I just purchased it a month ago and I'm very satisfied with it.
      I've never had a need for desoldering equipment braid has always worked for me although like soldering using it takes practice.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        ive had good succes with the xytronic 258 iron. it may not be a station, but ithas the feature of a non digital one in a more portable and cheaper form. it may be ony 30w, but iw does the job well, as the tips are both replaceable and plentiful, not to mention cheap. it includes a mini-chisel, which both stays tinned easily and has very good heat transfer. info on it here
        i bught mine at a local shop, i paid 20 bux usd. looking online, you can get one for 17 bux usd, id reccomend the sponge/stand to go with it. i fount that here
        as for desoldering, i use a vellman spring poweed sucker, as i have no money for the 808.my only compaint was that i had to sand down the edges on the tube as i got cut... be sure to by the aluminum ruby colored one... its the high-quality model, it will do you fine for work. the only trces it destroyed were ones that were already peeling... i have yet to suck out a port with it. info on it here
        mine only cost me 5 bux, online it was the same. look here
        sigpic
        (Insert witty quote here)
        • deckart
          • Sep 2009
          • 67
          Thanks so much for the response!.I've had a look at Hakko and it looks like they are being sold from someones lock-up in sarf London.Importing them from the States wouldn't be cost efficient!.I've had a look at this: http://www.ersa.com/art-i-con2-with-...-347-2138.html
          And this:http://www.conro.com/MFR-SDX_SDI.html
          The DSI version with pump.
          Above all considering the cost of these puppies is a bit of piece of mind.The Metcal has a built-in system that detects the heat needed rather than choosing the temp manually,not sure if anyone has tried this,but if it works,no more lifted traces due to strong arm tactics with my Weller!.
          Are they worth it?.
          Any help would be greatly appreciated.
          deckart.
          • KeriJane
            Mac Enthusiast
            • Sep 2008
            • 681
            Hi Deckart
            Those two stations that you linked to look very nice.
            "Are they worth it?"
            That depends on you. If you work professionally then absolutely yes.
            These expensive tools can provide you with superior results for less effort and time.
            They are expensive, so you would have to do a little work to make them pay off. Not as much as you would think.
            The way I look at it is:
            If it saves you ONE lifted trace on an expensive board it probably just paid for itself right there.
            That is, if you're the one that has to pay for the replacement board.
            Good tools=
            • Better Results
            • Less Time Spent
            • Fewer Re-works
            • More Satisfaction
            • Better Reputation
            • Higher Tool Payments!
            Have Fun,
            Keri
            • deckart
              • Sep 2009
              • 67
              Went for the Ersa kit.The stock desoldering iron tip was way too big for 0.5mm leads on a 2-2.4mm pad so was struggling a bit.Got on the phone to Blundell who supplied the kit and they sent me a couple of more suitable tips.Gratis.
              Had a couple of Imac G5 boards to play around with,decided to desolder all caps and resolder new,I was blown away,suck,clean,new cap,solder,under an hour!.
              What can i say,if you have the kit,know what you are doing,all the pain goes away.
              Should have done this years ago!.
              Let me know if you want pics!!.
              • Jon B
                • Nov 2009
                • 30
                Hi, what size tip are you using for the imac recap?
                • deckart
                  • Sep 2009
                  • 67
                  Hello!,I use the 22mm chisel tip.
                  • Jon B
                    • Nov 2009
                    • 30
                    Sorry I was not clear, desoldering tip. I tried my hakko 807 style and did not have much luck.
                    I was thinking the tip size was wrong. I just could not get it to melt.
                    Thanks for any info.
                    Jon B
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      22 mm !!!
                      I think he meant 2.2 mm.
                      Tips between 1.5 mm and 2.5 mm work best for most people I think.
                      Mann-Made Global Warming.
                      - Dr Seuss
                      • deckart
                        • Sep 2009
                        • 67
                        Err,yes that's what I meant!.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Figured as much. I was just teasin'.
                          - Dr Seuss
                            • 31087
                            http://www.rapidonline.com/ is a great place for xytronics stuff in the u.k.
                              by sam_sam_sam
                              07-01-2024, 06:34 AM
                            • corrize
                              Desoldering - soldering BGA chip close plastic mini fpc connectors ?
                              by corrize
                              Hello, I need your advise please ? I need to remove and replace the BGA black chip with fpc connectors around. The PCB is small, from camera.
                              There is no plastic component directly under, on the other face, (only fuse and oscillator I can remove if they are sensitives to heat), but there is a lot of very small smd components I don't want to desolder by mistake.
                              I have :
                              - hot air, and a
                              ll stuff around
                              - true kapton tape
                              - 140 and 180 degree soldering paste
                              - bismuth
                              - little hot plate 250 degree max
                              - the new BGA chip with probably
                              05-20-2025, 01:26 AM
                            • Azurain
                              Elitebook 840 G5 Bios Chip Soldering Question
                              by Azurain
                              Hi everyone,
                              I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                              Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                              04-14-2023, 06:58 PM
                            • Peter_1402
                              Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                              by Peter_1402
                              Hi Everyone,
                              I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                              1. Soldering iron works great
                              2. There is a burnt mark on the hot air gun handle.
                              I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                              Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                              Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                              Reed switch tested ok with a magnet.
                              From the above test, I can conclude...
                              07-12-2025, 11:50 AM
                            • chth96
                              What soldering station should I purchase for 900M-TJ-I tip?
                              by chth96
                              hello.
                              A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                              https://ko.aliexpress.com/item/4001275635593.html
                              Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                              Any reply would be appreciated.
                              11-24-2023, 05:08 PM
