Thinking outside the box. Disassemble capacitor without removing the leads?
  • gregr
    • Oct 2009
    • 6
    I searched the FAQ. I read all kinds of warnings about overheating a motherboard with the soldering iron, mechanical desoldering devices, warning this, warning that, etc, etc, etc.
    If (and that's a big IF ) it was safe to disassemble the capacitor and leave just the leads poking out the top of the motherboard, why not just parallel solder the new capacitor to the old leads. If I remember my electrical engineering 101 class in college, the length of the lead shouldn't change the properties of the capacitor. Right?
    Tell me where I'm going wrong in this line of thinking...
    Greg
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Thinking outside the box. Disassemble capacitor without removing the leads?
    Length of leads affects ESR big time.
    To test that I measured ESR with the test leads right at the bung and then again with the test leads ~ 3/4" from the bung.
    ESR about doubled.
    Of course depending on what caps you try this with your mileage may vary.
    I was using an MBZ if I remember correctly.
    Mann-Made Global Warming.
    - Dr Seuss
    • gregr
      • Oct 2009
      • 6
      PCBONEZ, that is amazing that you've tested that. Brilliant.
      Ok... That begs the question, wouldn't it then be easy to screw up how tight to pull the new capacitor to the board when you are recapping? I'm facing a recapping job on the wife's computer, and failure means many more years of pain (vs. just getting fired from my job if it were at work). I've done a lot of small PCB work, but never a motherboard.
      If each lead DID have a mark on it indicating "pull this lead level with the PCB to here", how many people know what that mark really means? Based on your test results, the length plays a MUCH bigger role than I would have EVER thought.
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Most caps sit all the way down on the board. The bung on good brands usually has a protrusion that bottoms on the board before the can does anyway. That's more to allow it to dry under there after a cleaning than anything else though.
        Tyan is the only brand I know that seems to consistently space caps off the board. I'm not sure if space is underneath is their goal or it's just a result of their process. If you ask me it just makes their boards look sloppy because caps end up leaning every which way.
        There should be no pulling force on the leads when you solder them in. Some people bend the the leads against the hole to get them to stay put for soldering. I do that sometimes too but usually I use an assortment of small blocks and random items [coins, bottle caps, sockets] and sort of stack the block, then the cap, then the mobo insofar as weight distribution goes. [That's functionally backwards. I flip the board solder side up, prop the board, then slide the blocks in underneath the cap as needed. Depending on the layout I can sometimes prop 6-8 caps at a time that way.] Some folks will use tape on top the caps or even glue under them. I'll pass on the glue method but other than that whatever works.
        If you know how to solder already the only thing that might take some getting used to is how thick the boards are. They'll suck the heat right out of the tip and if you don't have enough watts behind it to reheat it quickly the result is you slowly heat the whole area of the board instead of quickly heating just the joint.
        You want to use the fact that PCB material transfers heat slower than the materials in the joint.
        Think like: lots of heat, on and off it quick.
        Too long a time due to not enough heat in the iron allows the heat transfer rate of the PCB material to catch and keep up with the joint's temp before the joint's temp is high enough to melt solder.
        Without using the fancy air sucking solder gear what works best for me is:
        a 60 watt iron + rosined solder wick for 'off', use the wick before you pull the cap, then alternately heat the leads and 'walk' the cap out, then use wick again if needed, then clear the hole [if need be] with an appropriate sized sewing needle [needle on one side, iron on the other], then I usually use a 40 watt iron and .022" diameter or smaller solder for soldering the new ones in.
        Mucho big deal!! - Make a cap map BEFORE you pull any caps.
        Make sure you mark the polarity in addition to uF and volts.
        Some board silk-screens have errors so if you don't do this before you pull caps you can end up with a cap in backwards and it will take forever to figure it out.
        Lead length might not matter if ESR isn't a concern.
        ESR is kind of like Capacitive Reactance only if you plot both on a curve against frequency they mirror each other's shape.
        When ESR is high Xc is low, and vice versa.
        On motherboards the frequency of concern is <~200 kHz and is due to the SMPS's switching action. Down there ESR is the biggie.
        - Dr Seuss
        • ratdude747
          Black Sheep
          • Nov 2008
          • 17136
          just desolder the dumb thing... ive never overheated one... didnt pentium have a thread about his friend doing that on a gigabit switch and how it didn't work.
          sigpic
          (Insert witty quote here)
          • gregr
            • Oct 2009
            • 6
            ratdude,
            Thanks for the perspective. I'm definitely going to desolder the dumb thing and recap it. I'd rather throw it out the window across the yard. I'd feel a whole lot better, but it for sure wouldn't post after that.
            I'll post the results.
            BTW, it's an ASUS T2-R Barebones combo, purchased about 3-4 years ago. It uses nichicon HD(M) 1500uF 6.3V 20mm tall capacitors. Here's the obligatory pre-surgery pic:
            • Toasty
              • Jul 2007
              • 4171
              >>purchased about 3-4 years ago<<
              It was likely 2-3 years old by then, which puts it squarely in the midst of the crap cap production era.
              Manual was out in late 2003, last update to the BIOS file was 2005.
              I presume they're 10mm diameter caps, so get the Rubycon MCZ series from badcaps.net:
              https://www.badcaps.net/store/produc...products_id=40
              Toast
              veritas odium parit
              • gregr
                • Oct 2009
                • 6
                Ok... Time flies when you're having fun (and kids). Maybe I did buy it in 2004... Thanks for the link, Toast. They are 10mm diameter, but 20mm tall, not 13mm. The 20mm Rubycons are the ZL series. I get the feeling from reading the boards that the MCZ series is the better choice, even if they are only 13mm tall. I have plenty of vertical clearance so it really doesn't matter to me.
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Are you sure the ones in Vcore aren't HM(M) ?
                  - Dr Seuss
                  • gregr
                    • Oct 2009
                    • 6
                    Here's a pic. They are definitely HD(M)'s. They are 8mm in diameter. As you can see by the date code, they were in the 2003 timeframe.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      hd are not low enough esr to last long term in a p4/a64 vrm.
                      i have seen them before blown.cant lay the blame on the caps as they are not the right choice for this app.esp seeing this is a sff that can use a 3ghz prescott.
                      • gregr
                        • Oct 2009
                        • 6
                        That's really unfortunate for my opinion of ASUS design. For years I have trusted ASUS for my personal builds. So, I picked them for the wife's board so there would never be a complaint (you know the cobbler's children story). It would be easier to forgive them if they had a good electrical design and just happened to be victim of a bad supplier.
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          Asus was better in the '90's.
                          After ~2000/2001 they quickly eroded to average and stayed there.
                          Even though they've probably had over 100 affected models, Asus has STILL never even admitted there was a problem with bum electrolyte or to the HN/HM problem.
                          - Deliberately ignoring the existence of a serious problem is the same as lying to their customers. PARTICULARLY when they ran customers with models with known caps issues through extra whoops to minimize RMA's.
                          - Asus turned into: "You bought it, you got it, now go away."
                          - Dr Seuss
                          • berniedd
                            • Mar 2007
                            • 119
                            Gregr, that's exactly what I did to my Asus P5V800-MX motherboard. It would often hang and I quickly traced it to be many bulging 820 uf/6.3 v caps. They were all over the board. I've recapped many many boards over the past few years, but this is the first time I've had problems melting the solder on the leads. Then I noticed that many of these caps were installed in a slightly raised position, not flush with the board. So I just rocked the caps side to side till they snapped off on the leads, and I had 2 mm or so of bare lead sticking out of the board. To these I soldered my replacement caps. I ended up with a total lead length of about 8 mm between each cap and the board. A total of 9 capacitors were replaced.
                            I did it this way only because I couldn't desolder the old caps well enough, for some reason I can't identify. I cheated a little, because I used 1000 uf as replacements. The board is now back in service, and performs flawlessly.
                            To give you a glimpse back in the old days (1960's and 1970's), replacing resistors and capacitors on printed circuit boards routinely meant crushing the body of the old part with cutting pliers and soldering the new part on the leads left after removing the remnants of the old part.
                            • PCBONEZ
                              Grumpy Old Fart
                              • Aug 2005
                              • 10661
                              That's okay as long as you realize the when you mount caps with long leads like that you raise the ESR, so you need caps with even lower ESR to compensate.
                              To test that I measured some 16v 1000uF MBZ right at the bung and then again about 3/4" from the bung.
                              ESR went up 0.01 ohms from 0.02 to 0.03 and it was consistent.
                              [I wish I had a 3 decimal point ESR meter, but I don't.]
                              - Dr Seuss
                              • ygorsan
                                LG 55NANO77SRA TV – Menu scrolling by itself even after removing button board (Main Board EBU66792103)
                                by ygorsan
                                Hi everyone,
                                I’m looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
                                🧩 Problem Summary:
                                • The TV keeps scrolling through the menu or selecting items by itself.
                                • I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
                                • The remote control is not in use (batteries removed), and the TV still shows the same behavior.
                                • I
                                07-28-2025, 08:34 AM
                              • nicktasios
                                Macintosh Quadra 840AV PSU
                                by nicktasios
                                I had my Quadra 840AV (which I recapped and had working) plugged in for some time without using it and randomly decided to turn it on today. Unfortunately it did not turn on. After checking the PSU, I found out I was not getting anything from 12V, only from the 5V rail. After a few minutes, I removed the PSU and plugged it back in the electrical outlet and it suddenly started making a weird sound and soon after smoke started coming out. I quickly unplugged it. I opened it up but on first instance I didn't see anything out of the ordinary really. I later turned it back on and one of the MOVs blew...
                                12-22-2024, 05:07 AM
                              • spleenharvester
                                Making a Handskit hot air station a bit less stupid
                                by spleenharvester
                                I bought one of these as it was the only one I could find that is compact enough to fit in my toolbox (though I've since found KSGER make a substantially safer looking one). It's one of those fan-in-handle things that has the 230V element in the handle. Quecoo briefly sold a similar unit but discontinued it.. maybe they couldn't find solutions to these problems. I'm aware these fan-in-handle things are garbage compared to a good air pump station but I only really use this for occasional QFN work etc.
                                I did not realise at the time of buying that its design is... interesting, to say...
                                05-09-2024, 09:09 AM
                              • questore
                                XPS 13 9370 CMOS battery voltage always low
                                by questore
                                Hi Everyone,
                                I have brought you a mistery item
                                This laptop have come with some strange faults.
                                1. CMOS battery was flat 0v
                                Symptoms:
                                - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                                Amp drawing was stuck at 0.005 milliamps.
                                - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                                After inverstigation RTCD1 diode had a low value...
                                09-30-2025, 05:47 AM
                              • howardc64
                                Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
                                by howardc64
                                TV was fixed just after removing Samsung's rear snap cover.
                                This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
                                Maybe PSU->backlight connector didn't have a good contact?...
                                07-23-2025, 12:34 AM
