Caps on the connectors
    Topower does this, puts little 100uf or so caps on the molex connectors
    Would it be worth doing on a rebuilt power supply that dosen't have enough filtering caps on the secondary? The trouble would be getting them in there, you would need a tool to remove the pins from the connectors.
    Re: Caps on the connectors
    What?
    That just looks too stupid IMO
    And very easy to knock the capacitor off, or worse short it, since as we know Molex connectors can be so stuck you need a V8 truck and a towing wire to pull them out!
      Hi 370
      Oh, those regular Molex connectors are easy to remove from the connector.
      Just get either a small pair of needle-nose pliers and squeeze in the tabs, or get a small piece of tubing from your local Hobby/Crafts store and push it down to compress the tabs and pull the terminal out the back.
      Once out, you could solder a cap to it.
      But wouldn't it be better just to get a good PSU?
      Have Fun,
      Keri
      The More You Learn The Less You Know!
        Have Fun,
        Keri
        Some people will refuse to buy a good power supply on the grounds of money. So they keep their sunpro, or other real POS power supply that has 1 filtering cap on each rail, and the cap size is 10mm so no real chance of just putting a large value cap in there.
        @Per Hansson, you put shrink wrap over it. That connector in that pic had it at one time, but it was peeled off to show the caps on the connector.
          yes. get a good psu. no matter what you do, a piece of crap is a piece of crap.
          sigpic
          (Insert witty quote here)
            No wonder so many of the reviews on newegg say their units are DOA.
            Like Per said, this is a sloppy design and it's just too easy to knock off something.
              That just looks hideous.
              My gaming PC:
              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
              ASUS M4A77TD AMD 770 AM3 Motherboard
              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
              ASUS Xonar DG 5.1 Channel PCI sound card
              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
              Antec Three Hundred Mid-Tower Case
              Microsoft Windows 10 Pro 64-bit
              Microsoft Windows 7 Ultimate SP1 64-bit
                yes. its the law that reads "an item will fail the day after the warranty expires."
                thats called a shit design. total shit.
                sigpic
                  These are what they look like with the sleeving on them.
                    still could get damaged if some dumbass used pliers to remove a stuck plug. also, if one used a y cable then you could get problems.
                    sigpic
                      If you have a small cap inside PSU does adding a 100uF make difference?
                      I think it is completely useless to add caps on connector: if you want to minimize ripple you have to put good caps close to the transformer/rectifier. Read some PSU application notes from ST, Onsemi, Unitrode, Fairchild, etc... all of them tell you to reduce current path between power element (transformer/rectifier/caps) to have good regulation, good performances and low ripple/noise.
                      Like Keri wrote: but wouldn't it be better just to get a good PSU?
                      Ciao
                      Gianni
                      "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                      H. J. Brown
                        but wouldnt having it right by the connector mean less interference?
                        im thinking ADDDING this to a good psu for added protection.
                        sigpic
                          Maybe... I'm not quite sure.
                          What do you mean with "interference"?
                          AFAIK every piece of hardware has his own input filter capacitor so if the voltage/power comes from a good PSU there's non need for extra cap.
                          Large capacitor reduce ripple and voltage fluctuation but if you want to reduce/eliminate spikes and high frequency noise you need MLCC.
                          Ciao
                          Gianni
                          H. J. Brown
                            just a thought. thats all.
                            sigpic
                              Uh... isn't that 100 picofarads?
                              Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
                                any way you slice it its shit.
                                  Topower can't be bothered to do it right, but they'll gladly do this so they can make people think they're doing it right. It's one of the things that drives me nuts about them.
                                    http://www.hypermicro.com/itemdesc.a...SAB001&eq=&Tp=
                                      Tagan does this as well... some blocking and some operating capacitance.
                                        Caps with that small a capacitance are there for EMI, not ripple, and from an engineering standpoint it's a great idea.
                                        Mann-Made Global Warming.
                                        - Dr Seuss
