Caps on the connectors
  • 370forlife
    Large Marge
    • Aug 2008
    • 3113
    Re: Caps on the connectors
    Originally posted by Pyr0Beast
    Tagan does this as well... some blocking and some operating capacitance.
    IIRC Tagan=Topower, except for the new ones.
      by momaka
      03-12-2025, 03:42 PM
    • eryjus
      by eryjus
      05-10-2023, 11:21 AM
    • Paxman_Swede
      by Paxman_Swede
      Hello!
      01-14-2025, 09:51 AM
      Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
      by momaka
      This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
      Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
      Macron Power Technology Co. LTD.
      Let’s look at the PSU itself.
      The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
      06-02-2021, 10:05 PM
    • captain150
      by captain150
      03-16-2025, 07:34 PM
