Dell 5480 Bios need urgently
  • Murtaza527
    • May 2018
    • 257
    • Malaysia
    this is his original bios with computrace Plz clear
    thanks in advance
    • 21605
    Re: Dell 5480 Bios need urgently
    Try the bios at post #29 , if it doesn`t work then you need to flash the EC as well .
    https://www.badcaps.net/forum/showth...highlight=5480
    • imranromi
      • Jan 2015
      • 1290
      • Pakistan
      No... Computrace activate in bios not need to ec flash..
      • imranromi
        • Jan 2015
        • 1290
        • Pakistan
        My tool this exe file not extract correctly..
          • 21605
          Ok ,thanks ,i`ll remember that .
            • 21605
            Which exe do you mean .
            • imranromi
              • Jan 2015
              • 1290
              • Pakistan
              Dell bios exe 2 methods 1 change bios region remove and 2nd inside the bios and find.Bios region is easy just replace...
                • 21605
                If its lbe i don`t use it myself, i just use a few tools and hxd.
                • Murtaza527
                  • May 2018
                  • 257
                  • Malaysia
                  i tried that link bios but with that bios display comes but after few seconds off
                  i download this bios from internet but with this bios all otherthings working fine but trackpad only works in bios only i try update bios now fully updated but still trackpad not working
                  • Murtaza527
                    • May 2018
                    • 257
                    • Malaysia
                    anyone plz
                    • Murtaza527
                      • May 2018
                      • 257
                      • Malaysia
                      plz give me solution
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Just use the bios which works fully and clean me region to fix late display issue.
                        • Murtaza527
                          • May 2018
                          • 257
                          • Malaysia
                          that bios trackpad not working only working in bios
                          i dont know how to clean can you tell me bios me region and password how to remove and which software have to use
                          • foulou0238
                            • Mar 2014
                            • 109
                            • France
                            hello
                            test this one and let me know
                            • Murtaza527
                              • May 2018
                              • 257
                              • Malaysia
                              i have download this file earlier with this display comes but after few seconds its off
                                • 21605
                                Try this one. Consumer LP firmware, for the U version CPU`s
                                The EC is extracted from the bios update, its not the full size,it would need merging using a hex editor
                                • foulou0238
                                  • Mar 2014
                                  • 109
                                  • France
                                  Hello
                                  What’s is the ref of ur motherboard exctely ??
                                    • 21605
                                    @foulou0238 , the bios you posted at #14 has a dirty ME region, i took your bios, updated it with the latest bios update and cleaned the ME with the VPro_LP firmware ,it should be ok.
                                    • Murtaza527
                                      • May 2018
                                      • 257
                                      • Malaysia
                                      Try this one.
                                      with this totally no power
                                        • 21605
                                        Whats your service tag and motherboard id
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          Dell 9010 MT BIOS Update Always Fails
                                          by mikeybass
                                          Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                                          04-23-2025, 04:30 PM
                                        • Akhlz001
                                          Dell Pro 13 Plus PB13250 Bios Unlock
                                          by Akhlz001
                                          Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...
                                          09-20-2025, 07:15 PM
                                        • jhanra
                                          by jhanra
                                          in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
                                          11-02-2024, 04:19 AM
                                        • gizaha
                                          Dell Latitude 5580 possible bios corruption
                                          by gizaha
                                          Dell latitude 5580, motherboard cdp 80 la-e151p
                                          3 amber 3 white blinks. Dell website sais it's problem "bios recovery" and suggested solution "recovery image not found"
                                          (from here https://www.dell.com/support/manuals...e7a&lang=en-us)
                                          I try plugging charger while pressing ctrl+esc, machine turns on, nothing and after 20 seconds it gives 3 amber 3 white blinks again.
                                          Since ssd is replaced and had clean install windows, i've...
                                          02-13-2024, 07:18 AM
