Dell 5480 Bios need urgently
  • salawayon
    • Nov 2012
    • 572
    • philippines
    #41
    Dell Inspiron 5480 bios needed
    board info:
    Bucky/BenSolo WHL/CNL MB
    TVMHG
    17859-1
    i attached my backup. the unit got burned capacitors and after replacing those capacitors it powered up but only for a few seconds with no post then off... thanks
    • salawayon
      • Nov 2012
      • 572
      • philippines
      #42
      Re: Dell 5480 Bios need urgently
      i tried with Cleaning ME instruction but with same status.. maybe the main bios need to be reflashed with a good one... anyone had a good backup?
      • hoaca388
        Badcaps
        • Jan 2022
        • 11783
        #43
        Try
        • salawayon
          • Nov 2012
          • 572
          • philippines
          #44
          Originally posted by hoaca388
          Try
          it works... thank you very much for your time and effort...
          • desmobob
            • Feb 2021
            Hi folks, have an ME disabled 5480 (yup! Apparently you can order them like that) - which I need the admin password for. Unsure if the ME disablement will be a problem and the reason the uploads that I've tried from this thread not working. I have now end-up restoring my original bin as I get the fan, power-up dead screen, but really need to get rid of the pesky admin password.
            Is the password held within a fixed offset like my HP Zbooks are, that I can null out?
            I've tried to locate the offending offset by comparing versions posted here with mine, but the offsets for fixed regions of the BIOS appear to differ from the start.
            Here's my BIOS main anyway, if anyone could take a mooch.
            • kyzer
              Nson
              • Jul 2020
              • 9
              • Cameroon
              #46
              Thanks Lucky12
              • hoaca388
                Badcaps
                • Jan 2022
                • 11783
                #47
                https://beta.bios-pw.org/
                • richardsmr
                  • Aug 2021
                  • 25
                  • england
                  #48
                  can some kind person remove bios password lat 5480 please let me no what info you need
                  st 12DNWT2
                    VIP Moderator
                    • Aug 2018
                    • 4386
                    • Bulgaria 🇧🇬
                    #49
                    st 12DNWT2
                    Here you are
                    Master pass:
                    Ryr2M3IEQQZ64zGP
                    XUzB3mZMQGG86rk8
                    Become a Badcaps supporter
                    Thanks to all supporters.
                    • richardsmr
                      • Aug 2021
                      • 25
                      • england
                      #50
                      worked a treat thankyou
                      • Verlengsnoer
                        • Sep 2016
                        • 109
                        • Netherlands
                        #51
                        my laptop fixed with the file that Murtaza527 has posted.
                        but the only problem i have with it, is that the lan(ethernet) doesnt work
                        the system tells my identifing, the leds on the lan port are on,
                        but no internet connection
                        i dont have a orig backup, because i got the laptop as broken (it turn of, and off after few seconds) and after flashing this file the machine is up and running
                        hope someone can fix the lan issue in the file
                        https://www.badcaps.net/forum/showpo...17&postcount=9
                          • 20966
                          There is no need to attach the same bios thats at post #9 all you had to do was post the link to it...
                          Whats your service tag ?
                          • chhabi kenwat
                            • Nov 2020
                            • 7
                            • india
                            #53
                            There is one more bios chip U7205 Size 1024kb In 17859-1 DELL 5480 Any have working bios please share
                            • hoaca388
                              Badcaps
                              • Jan 2022
                              • 11783
                              #54
                              This is not a bios chip (I don't know what it is). Your bios chip usually has codes as 25Q64..., 25Q128..., 25Q256..., 25Q512... Find it, read it, make a backup and upload it here.
                              • chhabi kenwat
                                • Nov 2020
                                • 7
                                • india
                                #55
                                I also don't know about this but i think this is a bios chip i have backup and check datasheet pdf file https://cdn.badcaps-static.com/pdfs/...744336155e.pdf
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11783
                                  #56
                                  No, this is definitely not a chip that contains a bios file, this model has a 16MB bios so please find a chip with code 25Q128...The chip you uploaded may be the firmware of Thunderbolt.
                                  • omaryou
                                    • Aug 2017
                                    • 81
                                    • mexico
                                    #57
                                    HELLO
                                    PLS ANYONE HELP ME TO UNLOCK MY DELL 5480 I5 7The FLTMYM2
                                    • omaryou
                                      • Aug 2017
                                      • 81
                                      • mexico
                                      #58
                                      All is ok thx all
                                      • rickjansen01
                                        • Feb 2016
                                        • 129
                                        • nederland
                                        #59
                                        Hello Sir
                                        Can you remove password from this dump
                                        5480 cmd70-la-e081p rev 2.0
                                        Regards Chris
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11783
                                          #60
                                          Originally posted by rickjansen01
                                          Hello Sir
                                          Regards Chris
                                          What's your suffix ?
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • mikeybass
                                            by mikeybass
                                            04-23-2025, 04:30 PM
                                          • jhanra
                                            by jhanra
                                            11-02-2024, 04:19 AM
                                          • gizaha
                                            by gizaha
                                            02-13-2024, 07:18 AM
                                          • mrrubik
                                            Dell Optiplex 7010 micro bad BIOS flash?
                                            by mrrubik
                                            Hi folks,
                                            I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                                            After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                                            Steps I took:
                                            1. Read BIOS with CH341a, verified hash twice
                                            2. Patched
                                            12-23-2024, 04:11 PM
