Weird SSD Issue
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Weird SSD Issue
    Long story short, I pulled a working SSD out of a system (upgraded it to a larger one) and connected the old pull to another controller. Ever since, the drive is no longer accessible, even in the system it originally came from. BIOS's see it, but it can not be initialized, read, partitioned, etc. I've tried a couple utilities on it, which see the drive....but some say 'lost partition', and timeout attempting to recover it. I can care less about the data on it, I dumped it before I started diddling with it.....but is there any way to recover/reuse the drive itself? It was perfectly fine before..... It's a 240gb OCZ TRION150.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Weird SSD Issue
    ESD? Was it used as part of a RAID array? The latter has done this to me, had to "remove" the drive from the array on a compatible controller before it would work right.
    sigpic
    (Insert witty quote here)
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16959
      Re: Weird SSD Issue
      If it was ESD, that'd be a first in all my years...but I suppose it's possible. DBAN seems to be communicating with it....so I'll let DBAN zap it and see if it comes back to life.....last ditch effort before it ends up in the trash.
      Team : 49813
      Join in!!
      Team Stats
      • goontron
        5000!
        • Dec 2011
        • 4108
        • US
        Re: Weird SSD Issue
        ^ Ive had SMART erases bring SSDs back to life. Last ditch effort if DBAN fails
        Follow the white rabbit.
        • RJARRRPCGP
          • Jul 2004
          • 6304
          Re: Weird SSD Issue
          ATA secure erase time! Parted Magic is the easiest Linux distro to do that with!
          ASRock B550 PG Velocita
          Ryzen 9 "Vermeer" 5900X
          Arc A770 16 GB
          eVGA Supernova G3 750W
          Alienware AW3423DWF OLED
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            Re: Weird SSD Issue
            If you toss it, can I have a crack? I'll pay shipping...
            sigpic
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16959
              Re: Weird SSD Issue
              Yea. I'll let you know in the next few days if it comes back to life.
              Team : 49813
              Join in!!
              Team Stats
              • kaboom
                "Oh, Grouchy!"
                • Jan 2011
                • 2507
                Re: Weird SSD Issue
                I've had some strange issues caused by dirty SATA plugs and contacts on drives, both mechanical and a brand new SSD. The SSD in question is actually running perfectly in the E6400 I'm posting from. After imaging the original HDD to the SSD, this laptop didn't even see the SSD when placed into the internal bay. Yet it worked fine in the ext enclosure...
                Spray the SATA cable plugs with Deoxit or your favorite substitute. Also scrub the SATA connector, both power and signal, with a Deoxit-dampened swab.
                A few months ago, the HDDs (it would've seemed) in my main PC got slow. Sometimes holding the IRQs, just as a bad drive would in the old days. Re-enabling UDMA would always revert back to PIO, after any attempts to copy. I pulled the drives and cleaned the HDA-PCB contacts, and connected them to another system & backed them up. Great speeds now...
                But in the main system, back to slow-ville. An 8 hour+ ETA for what should've been an hour's worth of copying. Tried several combinations of drive/SATA cable, finally discovering one which was suspect. Sprayed the ends of all 3 with 2-26 and cleaned the SATA contacts.
                That did it. We were off, to the moon, Alice!
                "pokemon go... to hell!"
                EOL it...
                All style and no substance.
                guilty,guilty,guilty,guilty!
                guilty of being cheap-made!
                • junktv
                  • Nov 2010
                  • 3065
                  Re: Weird SSD Issue
                  That deoxit is expensive. Any stuff cheaper and available at stores? I'm sure I could use something like that. I know I have some pots and switches that need cleaned.
                    • 31316
                    Re: Weird SSD Issue
                    it's probably in secure mode - like a password - send a full erase sequence to it.
                    • kaboom
                      "Oh, Grouchy!"
                      • Jan 2011
                      • 2507
                      Re: Weird SSD Issue
                      Borderline overpriced, actually.
                      But I had to get mini squeeze tubes of the "red" and "gold" to clean a tape deck rec/play switch.
                      It wouldn't stay "good" after repeated attempts with CRC 2-26.
                      https://www.homedepot.com/p/CRC-2-26...2004/100398344
                      Also works good on DIMM and card edge contacts with either sturdy paper towels or swabs.
                      EOL it...
                      • RJARRRPCGP
                        • Jul 2004
                        • 6304
                        Re: Weird SSD Issue
                        If the utility in Parted Magic shows that it's frozen, use the desktop menu to put it to sleep for some seconds, then wake it back up.
                        Don't use the "Sleep" button in the Parted Magic disk utility menu-> There's a bug that makes the BIOS state fucked up and apparently causes motherboard BIOSes to keep falsely reporting an overclock failure, possibly until you clear the CMOS!
                        Arc A770 16 GB
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          Re: Weird SSD Issue
                          Topcat sent me the SSD... and yup, the SATA password somehow got set. Seems to be a common OCZ issue (why friends don't let friends buy OCZ?)
                          I tried to use an OCZ boot disc to secure wipe it but it immediately fails (forgot what the error was). Likewise, I couldn't find any OCZ master passwords online.
                          I'm all ears to other suggestions (or if you happen to have the OCZ master password, no it's not Toshiba's 32 spaces, I tried).
                          sigpic
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8354
                            Re: Weird SSD Issue
                            Was the error something like "drive is security locked"?
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              Re: Weird SSD Issue
                              Well, it's not really a OCZ this drive, but a rebaged Toshiba drive.
                              So you might need to use Toshiba's tools for it (if such exists).
                              If not I've had success with Linux hdparm: https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
                              However please exhaust all other options before you try that.
                              For example the MS-DOS utility hdderase.exe is a "safer" tool...
                              • ratdude747
                                Black Sheep
                                • Nov 2008
                                • 17136
                                Re: Weird SSD Issue
                                One issue... I don't have either the user or the master password! Both methods seem to require one to know the password already... which I don't since it wasn't set by a conscious person.
                                Topcat didn't set it... it set itself due to a glitch of some sort?
                                Bricked?
                                sigpic
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  Re: Weird SSD Issue
                                  This is a piece of cake under Linux. With ATA secure erase, you set the password, then let it complete.
                                  Arc A770 16 GB
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    Re: Weird SSD Issue
                                    Can't... if you don't have the current password, you can't set the new password. If this isn't the case, please give me the command for such, as all the hdparm stuff I found required the existing password and running off a live arch stick I couldn't get anywhere.
                                    sigpic
                                    • Sparkey55
                                      • Jan 2010
                                      • 1523
                                      Re: Weird SSD Issue
                                      Bricked?
                                      I think HDAT2 or MHDD32 have options to unlock passwords and to reset the drives.
                                      • RJARRRPCGP
                                        • Jul 2004
                                        • 6304
                                        Re: Weird SSD Issue
                                        Normally, that don't happen, unless someone powered down during an ATA secure erase.
                                        And you can normally set any password, just not too long, I would try 12 characters. (normally without an existing password)
                                        And if it shows "frozen", put the PC to sleep, with the desktop menu, then wake the PC back up.
                                        Arc A770 16 GB
                                        • SuperJames
                                          Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                                          by SuperJames
                                          This one's a weird one, and still unsolved despite it having gone back to Dell once.
                                          Specs
                                          i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                                          Backstory
                                          I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                                          10-23-2023, 04:09 PM
                                        • ugamazing
                                          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                          by ugamazing
                                          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                          04-10-2024, 08:06 AM
                                        • lukkihapsi
                                          Asus Vivobook X515JA Weird Boot Issue
                                          by lukkihapsi
                                          Asus Vivobook X515JA Laptop
                                          Issue :
                                          Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
                                          Tried :
                                          Cleaned inside for dust, applied fresh thermal paste. No Change!
                                          Removed keyboard, Trackpad, fingerprint sensor. No Change!
                                          Removed Internal SSD. No Change!
                                          Updated BIOS to latest version. No Change!
                                          Removed battery and pressing power button for 1 minute. No Change!
                                          Weird Part :
                                          Upon turning laptop ON, screen lights up - stays black,
                                          I...
                                          07-07-2025, 12:07 PM
                                        • tommygun26
                                          Hp 6510b weird issue
                                          by tommygun26
                                          Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
                                          02-26-2023, 06:00 AM
                                        • Stephen
                                          A2141 Weird Issue But works
                                          by Stephen
                                          Got an A2141 MacBook Pro 16" computer turns on however the track pad clicks but the keyboard has no life, NO LIQUID DAMGE whatsoever. Trackpad does click but the OS loads but the trackpad won't move the cursor, the keyboard is unresponsive. I replaced the cable and the trackpad to see if that was the issue but it was not, I went to see if the CAPS LOCK would turn on but it does not. Any indication what this is? I went and tested the lid sensor but nothing else. Battery holds a charge, fans spin normally, and lcd is good. I can use external mouse and keyboard without issue....
                                          05-06-2025, 10:23 AM
