A2141 Weird Issue But works
This topic has been answered.
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    Got an A2141 MacBook Pro 16" computer turns on however the track pad clicks but the keyboard has no life, NO LIQUID DAMGE whatsoever. Trackpad does click but the OS loads but the trackpad won't move the cursor, the keyboard is unresponsive. I replaced the cable and the trackpad to see if that was the issue but it was not, I went to see if the CAPS LOCK would turn on but it does not. Any indication what this is? I went and tested the lid sensor but nothing else. Battery holds a charge, fans spin normally, and lcd is good. I can use external mouse and keyboard without issue.
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Answer selected by Stephen at 05-06-2025, 01:20 PM.
    Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 676
    Well T2 chip is the issue. RIP I got the DFU restore error with the U67 chip removed to verify and you can tell it failed. Going into parts I guess.
    • mon2
      • 14994
      Keyboard decoding is performed by:
      U6701
      U6702
      Review they are being powered and mating properly with the connectors / cabling.
      Review the SMBUS line voltages for each of these IO expander chips.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 676
        I believe I resolved... before you got back to me...I will test this if not. I was thinking about the T2 chip is the issue.
        sigpic
        • Stephen
          Meow Meow MEOW!
          • Apr 2020
          • 676
          Ok so yes DFU restore forced it to fail. Meaning I have an SPI issue somewhere. I am going to look around and find. I know these U67 chips need to work to communicate with the T2 which results why it was failing the restore.
          sigpic
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 676
            sigpic
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
              🛠 Original Issue
              The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • yaya3gmax
              Laptop Power Issue – Works on Battery, Fails on Adapter Load
              by yaya3gmax
              Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
              Symptoms:
              • Laptop works normally on a pre-charged battery.
              • Battery does not charge when adapter is connected.
              • Without battery:
                • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                • Speakers “pop” when power cut occurs indicating harsh sutdown.
                • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
              08-21-2025, 07:16 AM
            • SuperJames
              Dell G3 17 3779 Weird power cycling and shutdown/restart issue
              by SuperJames
              This one's a weird one, and still unsolved despite it having gone back to Dell once.
              Specs
              i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
              Backstory
              I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
              10-23-2023, 04:09 PM
            • Stephen
              A2141 MacBook Pro 16" lid sensor issue.
              by Stephen
              Just like the title states. I have been confused at this point. Computer won't turn on when lid angle sensor is plugged in, when unplugged it turns on immediately, however I have tried 4 different lid angle sensors all OEM and calibrated without issue. I even pulled one from a donor computer and still nothing. I know the M1 Pro sensors are married to the board however I do know the 2019 intel are not as long as they came from a donor LCD etc. What I do not get is why is the lid angle sensor forcing the computer to not turn on, another issue I see when the lid angle sensor is disconnected...
              11-01-2024, 03:45 PM
            • ex250
              Kenwood SW-505D no sound issue and pops from time to time when it works
              by ex250
              Hello mates,
              I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
              It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
              12-29-2024, 03:27 PM
