Hp 6510b weird issue
  • tommygun26
    • Oct 2022
    • 5
    • uk
    Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot into win installer.Bios battery is new installed.Date n time is set correctly in bios options.Another weird issue is laptop wont turn on at all after setting only one core in bios settings.Cpu 7250 intel core duo and Intel GMA sits inside.Had it dissasembled to bare mb,no burnt component found.Regards Chris.
  • mon2
    • 14634
    Re: Hp 6510b weird issue
    Confirm the usb function. Attach a USB mouse or keyboard. Does that work?
    • tommygun26
      • Oct 2022
      • 5
      • uk
      all usb ports functional.connected external usb keyboard works fine.No issues with internal keyboard too.
      • mon2
        • 14634
        What is the brand of your USB thumb drive?
        Is it Kingston? Many of their memory sticks are crap and cannot boot on cold boot. You can with a warm boot. Try the three finger salute (Ctrl+alt+del) after turning on the unit.
        We found this with the Rufus tool and have 100++ keys to flash the firmware we apply onto our adapter designs using FreeDos.
        What does work everytime is the Lexar brand. Manufacturers in Asia we met said it is the compatibility of the flash drive that is lacking in the Kingston brand.
        • tommygun26
          • Oct 2022
          • 5
          • uk
          swaping thumb drive for different brand did not resolved an issue,booting system from internal optical drive with working windows install same thing.Laptop just switches off randomly and forth back boot looping.noticed when shuts off machine blinks one time orange charging light.Battery is charging fine.Not a chance even to see message "no boot device found" its just reboots or cuts off power.
          • tommygun26
            • Oct 2022
            • 5
            • uk
            Hello fellas quick note for the record.Dusted off that Hp6510b buggy laptop,just to give another try.Found cheapo intel celeron 530,same socket cpu for replace.And laptop boots fine,with no issues.Seems org.cpu T7250 was shoot someway alloving enter to bios but not entering boot mode & shutting off machine.Only small issue to solve.Laptop wont switch off fully by windows shutdown menu option,and hibernation wont wake hardware again.Windows logs off no issues.Screen,hdd,fan turns off,but light diodes on keys stays lit.Only long press on/off button can completely turn off laptop.Cheers.
            • lukkihapsi
              Asus Vivobook X515JA Weird Boot Issue
              by lukkihapsi
              Asus Vivobook X515JA Laptop
              Issue :
              Upon turning laptop ON, screen lights up - stays black & about 30+ minutes later ASUS logo is shown & boots to windows, then laptop works fine.
              Tried :
              Cleaned inside for dust, applied fresh thermal paste. No Change!
              Removed keyboard, Trackpad, fingerprint sensor. No Change!
              Removed Internal SSD. No Change!
              Updated BIOS to latest version. No Change!
              Removed battery and pressing power button for 1 minute. No Change!
              Weird Part :
              Upon turning laptop ON, screen lights up - stays black,
              I...
              07-07-2025, 12:07 PM
            • abajor
              Alienware Area-51 R2 Boot Loop issue.
              by abajor
              I have the above mentioned Alien Ware A51 R2, currently it randomly will boot into the OS but more often than not it boot loops, I'm assuming there's an issue with power regulation somewhere.
              It comes with Dual 180 Watt Dell PSU, which is ironic since the thing claims it requires 420 watts in the bios screen.
              To rule out the power bricks I've attempted to power up the Laptop with a 330W and 240W Dell PSU at the same time, it still has the same boot loop issue so the problem is definitely the laptop.
              Right now I'm trying to dig through the PDF schematics and Board...
              03-08-2024, 10:08 PM
            • SuperJames
              Dell G3 17 3779 Weird power cycling and shutdown/restart issue
              by SuperJames
              This one's a weird one, and still unsolved despite it having gone back to Dell once.
              Specs
              i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
              Backstory
              I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
              10-23-2023, 04:09 PM
            • ugamazing
              820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
              by ugamazing
              So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
              1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
              2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
              04-10-2024, 08:06 AM
            • Safio
              Asus Rog Strix g15 g512LI BOOT ISSUE
              by Safio
              Hello
              My asus rog strix g15 g512 keeps repeating the "Republic of Gamers" animation and won't power on. Anyone know what could be wrong with it?
              i tried to install new system on it but it is same issue , does the same thing when i try to boot from usb or externals hard drive, flashed bios still same issue , if its a hardawre issue please share your experience
              thank you
              06-08-2024, 08:43 PM
