sony kdl-46w5100 no red light standby, on green off red light flash 14 times
  • mydang
    • Aug 2018
    • 61
    • canada
    I need help any people know what wrong of my tv, please
    1- As soon I plug into power no red led standby show front TV, check voltmeter has ST-By 3..3 v
    2- As soon press power button green light on working but no backlight or sound then 5-10 second green light off by itself then
    3- Red light on and flash 14 times stop then keep flash 14 times keep cycling
    BUT one thing if as soon I plug tv to power the turn tv on then I use wire to connect pin st-by 3.3v to backlight pin then I see
    Backlight working bright and logo tv sony show on screen then off after a 4-5 second, every time I do that backlight on
    Please I need all people here to help and tell me what is wrong
    Thank you
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: sony kdl-46w5100 no red light standby, on green off red light flash 14 times
    Tcon most likely.
    • neilc6
      • Nov 2015
      • 1550
      Check for 12V on Tcon fuse.
      https://www.badcaps.net/forum/showthread.php?t=66995
      • mydang
        • Aug 2018
        • 61
        • canada
        Originally posted by neilc6
        checked t-con fuse is 12 volts
        Thank you
        • mydang
          • Aug 2018
          • 61
          • canada
          Originally posted by tvtimmy
          Tcon most likely.
          brand new t-con but no luck , Thank
          • neilc6
            • Nov 2015
            • 1550
            Thank you
            Did you check both sides of the fuse?
              If you do have 12V on both ends of the fuse with ref, to GND. What happen if you remove the cables between T-CON and the LCD panel?
              BTW, can we see the whole back side of the TV showing all the boards?
              • mydang
                • Aug 2018
                • 61
                • canada
                yes both side is 12v
                thx
                • mydang
                  • Aug 2018
                  • 61
                  • canada
                  Thank you all people help me
                  14times red light flash tell us is bad t-con or panel is not right so far
                  now I attached a picture I found the problem from the inverter board
                  Please take a look a picture
                    Can we get good clear straight shot pictures of the whole bottom side of this DN1 board?
                    SONY D1N_1-878-620-12
                    D6615 SONY P/N 6-501-776-01 DIODE P/N MAZ8150GMLS0 (15V Zener)
                    • mydang
                      • Aug 2018
                      • 61
                      • canada
                      thank here is the whole picture dn1
                      • mydang
                        • Aug 2018
                        • 61
                        • canada
                        Thank you for your help look clear , please tell me what value smd diode to replace for D6615
                          See post #10
                          • mydang
                            • Aug 2018
                            • 61
                            • canada
                            Thank I understand what is diode i need sorry i am new here to learn
                            • mydang
                              • Aug 2018
                              • 61
                              • canada
                              Hi! Budm
                              i attached the picture for you to look
                              can i use this kind of zener diode to replace D6615 instead of MAZ8150GMLS0
                              Thx
                                You can, you just have to solder it in place properly.
                                • mydang
                                  • Aug 2018
                                  • 61
                                  • canada
                                  Thank Budm your help is appreciated
                                    BTW, check the fusible resistor that feed that VCC pin of the IC.
                                    Also, are you sure it was 14-blink code?
                                    • mydang
                                      • Aug 2018
                                      • 61
                                      • canada
                                      Yes bubm i double check again red light linking flash 14 time then stop hafl second then flash 14 time then stop and keep flash every 14 times
                                      thax
                                      • mydang
                                        • Aug 2018
                                        • 61
                                        • canada
                                        Budm please tell me how come the BACKLIGHT pin even stand by and power on no Dc voltage on that pin, i think it should have volt to kick on backlight for tv
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light, but no sound
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:33 AM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          01-26-2025, 08:18 AM
                                        • lcdcaps1
                                          820-2610-A Sys onewire help, no green light. Please help from the gurus
                                          by lcdcaps1
                                          Hi
                                          I have an 820-2610-A motherboard that has no green light.
                                          I have noticed is when I do a SMC reset the light on the Magsafe blinks.
                                          From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
                                          The sys onewire circuit on this model and others is more involved
                                          I was hoping if anyone knows about this and how it works, can reply and let me know
                                          I know this is an old model but I am sure there are people who still works on these or knows about them
                                          I get 1.1v on the C7771 capacitor and will replace...
                                          11-06-2023, 01:28 PM
                                        • blazzelia
                                          MBP A1286 820-2915 green light only, no start
                                          by blazzelia
                                          Hi guys,
                                          I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating...
                                          09-30-2024, 07:20 AM
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
