sony kdl-46w5100 no red light standby, on green off red light flash 14 times
Re: sony kdl-46w5100 no red light standby, on green off red light flash 14 times
But what are the resistance reading of the original 15V Zener that you found it is bad?
I need reading in Ohm.Last edited by budm; 08-19-2018, 12:00 PM.Never stop learning
"What was the resistance of the that shorted 15V Zener that you first found in the beginning? ,, it read one side is 0.152 the other side VL"
That does not indicate as shorted because one way it shows 'OL'.
So what is the RESISTANCE reading between VCC and GND, I need that data?
The fusible should have blown too if it has shorted circuit that is why the fusible is in place.Last edited by budm; 08-19-2018, 03:18 PM.Never stop learning
"What was the resistance of the that shorted 15V Zener that you first found in the beginning? ,, it read one side is 0.152 the other side OL"
That does not indicate as shorted because one way it shows 'OL'. ( NOW BOTH SIDE has continuity 000.0
So what is the RESISTANCE reading between VCC and GND(VCC and GND which board? powersupply or D1N ), I need that data?( I alreay removed IC, zener diode and the rectify out of circuit D1N
The fusible should have blown too if it has shorted circuit that is why the fusible is in place.Last edited by mydang; 08-19-2018, 07:42 PM.Comment
It is only 0.46 Ohm, it is not shorted. that is normal.
I am looking for the RESISTANCE reading of the original 15V zener that you removed and and the resistance reading between the two pads on the board where that 15V Zener was. RESISTANCE, nothing else.
Why are you checking R6603???
1) Do not use continuity mode for testing for shorted circuit, use Ohm meter and report the resistance reading in both directions.
2) I am beginning to believe that that the 51V zener is OK and the IC may be still OK but I cannot tell until you provide the RESISTANCE READINGS as requested. R6636 for that 12V power supply line would have blown open circuit by now if the IC and the Zener were shorted out.Last edited by budm; 08-19-2018, 08:24 PM.Never stop learning
It is only 0.46 Ohm, it is not shorted ((used ohm tesed is no reading)). that is normal.
I am looking for the RESISTANCE reading of the original 15V zener(( used diode mode tested both side is 000.0)) that you removed and and the resistance reading between the two pads on the board where that 15V Zener was. RESISTANCE, nothing else.
I know the R6636 is blown used ohm mode tested it show not thing
used diode mode tested zener diode for both side it show 00.0
used continuity checked C6615 has soundComment
"R6603 on D1N is shorted too,," That is confusing DATA when you indicate that low ohm resistor is shorted. If that fusible for the 395V is blown then you have bigger problem, you need to check the resistance between Source and Drain pin of those MOSFETs to make sure they do not show low Ohm resistance.Last edited by budm; 08-20-2018, 09:43 AM.Never stop learning
by MOSSEPHi
Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
I have already tried replacing all of the...-
by MOSSEPHi
I have already tried replacing all of the... -
by lcdcaps1Hi
I have an 820-2610-A motherboard that has no green light.
I have noticed is when I do a SMC reset the light on the Magsafe blinks.
From My understanding, the sys onewire circuit is responsible for the green light on the magsafe
The sys onewire circuit on this model and others is more involved
I was hoping if anyone knows about this and how it works, can reply and let me know
I know this is an old model but I am sure there are people who still works on these or knows about them
I get 1.1v on the C7771 capacitor and will replace... -
by blazzeliaHi guys,
I have this 2011 MBP - the company I was working for, bought it at the time for a project and gave it to me after that. Later on, I gave it to my daughter which used it for normal internet browsing and office apps. At some point the, now famous, AMD GPU issue hit this laptop as well. I disabled the use of the AMD GPU following some information I found at the time (the one that, at the end, one moved AMD kext drivers to a backup location). So the laptop was using the CPU graphics and it was ok for the said daily usage. I even replaced the drive with an SSD one and it was operating... -
by shahnldGood Day.
I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite... - Loading...
