About 6 months ago, after about 4 years of use, my computer just wouldn't turn on anymore.
I tested all components and they all worked, so the mobo (intel D845GVSR I think) must've failed, I suspected bad caps but could not see any indication of damage, I just put that motherboard away and used another computer.
Recently I was just cleaning and came upon this mobo again, I gave it a quick inpection and this time I could clearly see a row of 6 bulging caps.
So now I'm trying to replace the bad caps, I would really like to continue using this computer.
A couple of weeks ago I replaced 3 caps on a power supply for my LCD TV, it was very easy.
However, I'm having a hell of time time trying to do the same on this mobo.
First I tried with a 40w soldering iron, that didn' work so I got 60w one.
With the 60w soldering iron one of the the caps came out very easlily, but that's the only one. I couldn't remove the other ones correctly.
The other 5 caps just came off their leads. So now I have the mobo with just the leads from the caps.
I try heating on one side and pulling the leads with pliers from the other side, but the darn things won't come out.
The 60w iron seems hot enough, but still doesn't seem enough to do the job.
Should I use one with a higher wattage? I have a 100 watt one.
What other suggestions do you have?
Thanks very much.
Thanks very much.
