Question about removing the BIOS lock
  • mustardcheese
    • Jun 2025
    Hi all, I have a Dell Latitude 7300 with a locked BIOS and I was curious about the process of removing the lock by editing the hex values of the bin and how to do it. Is editing the hex values of the dumped bios any different than flashing a new one that's already been unlocked? (I currently don't have the correct bin because I realize I accidentally dumped the wrong thing). I am very new to this any help or advice or references would be greatly appreciated. Thanks
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    It depends. By flashing another (unlocked) dump you tend to lose SN, windows key and such information. It's usually best to modify.
    • reformatt
      • Feb 2020
      • 1675
      You can use a donor BIOS and transfer the DMI data (S/N etc) and Windows key from the old to the new. You also need to take into account that Intel machines need clean ME firmware if you are going to use a donor. Some BIOS structures are different between manufacturers, and it's a black art in knowing all the ins and outs.
      While I can patch them myself, I don't have all the tools and knowledge to do it on every BIOS, especially if it's just a one off. That's why we have the BIOS group, and there are some wonderful people who do this work for you...for absolutely nothing. I recently put up a password protected BIOS in the group for an Acer machine. Someone in Vietnam removed the password within the hour, and I was on to the next job. Same BIOS, so no need to muck around with DMI, ME F/W etc.
      • lorby
        Acer SP-514-54N Bios editing gone wrong
        by lorby
        Hi everyone! Hoping to gain some knowledge from this very helpful forum . I'm new to this stuff and I'm obviously missing some important steps.
        I have some Acer Spin SP514-54N laptops I wanted to make some changes to the BIOS for.
        Using a CH341 USB Bios tool I read the bios successfully. Downloaded a backup copy. Copied that and opened it in a hex editor (HxD). I changed the windows key in the bios after following the guide to find the hex marker. Changed the 25 digits and then compared to the original bios file, and made sure that was the only differences.
        01-25-2026, 12:13 AM
      • cr4zychriss
        by cr4zychriss
        • Rebrand: PC Specialist
        11-14-2025, 04:04 PM
      • sssssssssssssss
        Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
        by sssssssssssssss
        I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
        Symptoms:
        • Laptop powers on but no display at all (completely black screen)
        • Caps Lock blinks twice with a pause, then repeats continuously
        • F12 LED stays on permanently
        • No POST, no boot sequence, nothing on screen
        Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
        What I've tried:
        • Hardware reset (battery removal, power
        09-04-2025, 06:45 AM
      • Kentsfield
        Lenovo Thinkcentre M75n DMI Data extraction from dumped BIOS
        by Kentsfield
        I got a Lenovo Thinkcentre M75n (MT-M 11G5 PF3XG5V3) with a semi-bricked bios.
        Short recap: I want to add an external GPU via the M.2 slot (Oculink). It does work but has some problems with the onboard GPU of the Ryzen 3 3300U. So I used Smokeless_UMAF to disable it. Since then I don't get any video via the external GPU nor the iGPU and Can't access the BIOS, but the PC does boot to the OS.
        I desoldered the flash IC MX25U12872F and dumped the flash.
        I also downloaded the newest BIOS and have it as a .bin file (I loosely compared the contents...
        08-04-2025, 07:46 AM
      • haitham sharabati
        by haitham sharabati
        Hello engineers 😀,
        🔧 Device Info:
        - Model: HP 15-da2007ne
        - Product Number: 8XF55EA#ABV
        - Serial Number: CND0338P0D
        - CPU: Intel Celeron N4000
        💀 Problem:😅
        08-07-2025, 04:54 AM
