echo star "480w".just when you thought you had seen it all...
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    this pile of shit shows up.
    note the tiny board.missing parts,fuhkyuu caps,and wait for it..
    dummy weights!
  • jpdoe
    • May 2007
    • 237
    Re: echo star "480w".just when you thought you had seen it all...
    priceless!
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      LOL
      "No serviceable components inside" just got a new meaning!
      Most awsome PSU evvar!
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        if they keep this up they can simply say "no components inside"
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          here comes the recession
          • i4004
            • Oct 2006
            • 2029
            >dummy weights!
            fuckin' excellent!
            i was wondering if they were gonna say one day
            "huhm...good psus are heavy, so why the hell not!"
            just lol!
            oh yeah, it's seems extra weight is glued!
            priceless indeed!
            they really are worth their weight....in laughs!
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              The glued weights ... I keep laughing everytime I see that picture. Truly failblog.org worthy.
              And look at that +5vsb mosfet. I've seen bigger transistors on cheap toy RC cars!
              But at least you have a voltage switch (FYI, my L&Cs just have a "220v only" stickers), plus I see 4 Teapo caps there - you have to give them some credit for that... although without any filtering on the primary, they will be screwed pretty soon.
              Details aside, it's indeed priceless. You should send it to Jonnyguru for a test - what if it really makes it to the label specifications?
              • RJARRRPCGP
                • Jul 2004
                • 6304
                Looks like a 250 W at best! Maybe 300 W. Definitely not a 480 W! Look at the +12 V amp rating!
                ASRock B550 PG Velocita
                Ryzen 9 "Vermeer" 5900X
                Arc A770 16 GB
                eVGA Supernova G3 750W
                Alienware AW3423DWF OLED
                • KeriJane
                  Mac Enthusiast
                  • Sep 2008
                  • 681
                  Wow. That's "better" than the new 400w PowMax I keep around for a joke. (Or to sell to someone I don't like)
                  Where's the bridge rectifier on that 480w wonder?
                  I thought that teenie little primary side diodes like the one visible between the primary cap and heatsink were limited to maybe 150w. On a good day, and arranged so that they stand off the board so they could get some air on them.
                  I say it went boom under 100w.
                  It is obviously a rebadged First Regency Asian Union Duet Corporation unit (F.R.A.U.D corp)
                  Have fun!
                  Keri
                  PS. Oh! I broke the code! That there "480w" rating is a typo! It should read "480Mw" for MARKETING watts.
                  PPS. 400w PowMax for sale!
                  The More You Learn The Less You Know!
                  • Gianni
                    • Jul 2008
                    • 681
                    • Italy
                    You have no faith!!!
                    This PSU can sustain 480W load... for 1nS
                    On the label they didn't write 480W forever...
                    I have never seen a PC PSU with such small board as this one.
                    You know less components reduce the risk of failure, what is missing can't break
                    Ciao
                    Gianni
                    "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
                    H. J. Brown
                    • Silentbob
                      • Jul 2007
                      • 11
                      • Norway
                      They must have labeled it wrong. It's probably a 480 mW PSU.
                      It says "Do not remove the cover under any circumstances". Then people might find out they got royally hosed on their PSU purchase.
                      • Scenic
                        o.O
                        • Sep 2007
                        • 2642
                        i'd say 48.0W combined max. peak lol
                        looks like they just put a ITX "power supply" into a standard ATX PSU casing.. lol
                        • Junk Parts
                          Court Jester
                          • Jun 2006
                          • 8953
                          I used one of those PowerMax cases to build one in the past. I may have posted about it here on this forum before. Anyway the "PSU" didn't last three months. Caps took a crap. The system had two DVD burners, a modem, and maybe a LAN card in it. Pure Junk!
                          "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so."
                          Mark Twain
                          "I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way."
                          John Paul Jones
                          There is a fifth dimension, beyond that which is known to man. It is a dimension as vast as space and as timeless as infinity. It is the middle ground between light and shadow, between science and superstition, and it lies between the pit of man's fears and the summit of his knowledge. This is the dimension of imagination. It is an area which we call the Twilight Zone.
                          Rod Serling
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            you mean powmax?
                            good name to see on fireworks not on computer parts!
                            • zandrax
                              Hit and miss
                              • Dec 2007
                              • 1157
                              • Italy
                              Is it a toy? A 48.0 W psu
                              Zandrax
                              Have an happy life.
                              • Silentbob
                                • Jul 2007
                                • 11
                                • Norway
                                Looking it up, lowest price I could find was $15. And as usual, people with little knowledge about PSUs will buy it and think they got a 480W PSU at a bargain price. :S
                                • KeriJane
                                  Mac Enthusiast
                                  • Sep 2008
                                  • 681
                                  FIFTEEN DOLLARS? That's BEFORE the $20 mail-in Rebate right?
                                  There's one born every minute!
                                  Actually, I saw not one but two (suckers) once at Tiger Direct.... a couple of guys were looking over a "Diabolo" case with "450w" PSU.... for $29! There was a great deal of discussion about who gets to keep the PSU!
                                  Going halves on a $29 case?
                                  Have Fun,
                                  Keri
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    Have Fun,
                                    Keri
                                    if i order a cheap case for a customer who insists on it for the looks i request the vendor to remove and keep the psu.
                                    they are not worth the cost to ship as there is not much metal to recycle!
                                    only value in most of the cheapies is to take it apart,laugh,and post the pics here!
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      The fans and ferrite coils are probably the most worthwhile parts. Of course it's hard to find any ferrite coils in cheap PSU and fans are only good for case fans as they can't push much air. If you collect 5 cheap PSUs, maybe you'll have enough parts to complete one, and even then the PSU still won't have SC, OPP, and other protections.
                                      By the way, I have a 75 watt Mitac PSU from a Compaq Pressario. Has 5x the components of that "Echostar", and 2x bigger PCB, with Delta fan. Too bad it's an AT PSU.
                                      • jpdoe
                                        • May 2007
                                        • 237
                                        They must have bought it here:
                                          HP ProDesk ProDesk 400 G3 Microtower PC (ENERGY STAR) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 400 G3 Microtower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G3 Microtower PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G3 Microtower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                                          09-12-2024, 03:44 PM
                                          HP ProDesk ProDesk 400 G3 Small Form Factor PC (ENERGY STAR) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk ProDesk 400 G3 Small Form Factor PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G3 Small Form Factor PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G3 Small Form Factor PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly...
                                          HP 260 G2 Desktop Mini PC (ENERGY STAR) i5-6200U Specification for Upgrade or Repair
                                          This specification for the HP 260 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC (ENERGY STAR) boardview and 260 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          HP Z240 Tower Workstation (ENERGY STAR) i7-6700K Specification for Upgrade or Repair
                                          This specification for the HP Z240 Tower Workstation (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation (ENERGY STAR) boardview and Z240 Tower Workstation (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                          HP 260 G2 Desktop Mini PC (ENERGY STAR) 4405U Specification for Upgrade or Repair
