The TV is a 39" LG 39LN5700 "Smart" LED LCD TV that is about 2-3 years old. The picture went out, but the display still seemed to be working as the picture was visible when using a strong flashlight. I have some basic knowledge of electronics and wanted to see if it was fixable and looked up a bunch of troubleshooting info. Unfortunately I fried the power supply board by accident while testing voltages
Anyway, before it burned out I was getting around 22.7v at the 24volt output to the main board, which looked close to spec, but the "93.2~118.5V output" (I'm guessing to the LED backlights) was way off. The TV had it the Input listed as "100-240~ 50/60Hz 2.0A" and Output listed as "133.2V - 0.37A 39 Inch", but with the TV on I was measuring a cycling voltage at the LED+ lead that went from 232V down to 214V, no change whether the LED cable was connected or disconnected.
After frying the power supply board, I gave up and decided to strip it for parts and see what was worth salvaging. When I started taking apart the panel housing I was greeted by a nasty smell, and then saw what I'm guessing was the source of the backlight failure (picture attached). My question is if this is common/normal? I don't expect LEDs to last forever, but to fail so spectacularly?
I've tried contacting LG about it, but only got one reply from them asking for contact info (which I put in an email reply) and have yet to hear back from them. I was worried it could be a potential safety issue with other LGs with the same parts. The TV is well outside of warranty and I don't think the display wasn't made by LG (I think they outsourced it to Heesung Electronics).
